Old 01-28-2008, 01:30 PM   #661
jbsmith1's Avatar
ok testing has started!!
I took a camera down to the track today and set it up at some corners for this short vid...
http://www.youtube.com/watch?v=s9bG0XdFJKo
The spool did the trick, the car was much more stable going through the chicanes, and into the hairpins i had brakes...woohoo!
Its the middle of winter in the UK, it was 8 degrees to day, so traction and overall grip was poor, but with the spool and additional changes (pictured below), the chassis was very drivable with no over steer, and just a hint of push/understeer in the high speed corners.
I noticed in previous testing the rear was skipping over the bumps, so I added some 1mm shims under the rear spring pan, this released some of the pre-load and softened the rear,
The chassis now sits level too, thanks to some 2mm carbon plates i made and put under the rear axle/bearing housings all in aid of getting a neutral handeling chassis...see pic
http://i24.photobucket.com/albums/c2...00275text2.jpg
...can't wait for the warmer weather now.
jbsmith1 is offline   Reply With Quote
Old 01-29-2008, 05:52 AM   #662
Taylorm's Avatar
.............jb..........good video........the Spada motors sound cool.....raspy..........man, Kyosho needs these here stateside..............
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 01-29-2008, 08:08 AM   #663
JLock's Avatar
Taylorm,
Its never going to happen, that is why I have chilled on the rhetoric. The best approach to this now is to get your LHSs involved. For those of you that have them and have been ordering parts for the Spada from overseas, you guys should take all of your receipts to the owners of the LHSs in your areas. Show them that because Kyosho refuses to bring this car to the states, this is the money that Kyosho USA is taking from their coffers and forcing us to send it overseas. Maybe the LHS owners could then put some heat to them to bring the Spada here. Just a thought.
JLock is offline   Reply With Quote
Old 01-29-2008, 10:04 AM   #664
n.e.r.d's Avatar
jbsmith1,
sorry for the late reply regarding the k-factory V1R fuel tank mod.
held up by work, yet to do the mod.
looks like it might work with some modifications..
the throttle servo deck will have to be cut, need to make braces for the fuel tank.
pics below
http://www.rcpics.net/view_single.php?medid=87881
http://www.rcpics.net/view_single.php?medid=87882
n.e.r.d is offline   Reply With Quote
Old 01-29-2008, 11:12 PM   #665
Suspended
so i cant get one here in the usa?thats sux!!!
ocktoberfest00 is offline   Reply With Quote
Old 01-30-2008, 04:24 AM   #666
jbsmith1's Avatar
the engine is running on 16% Tornado and power is good
Originally Posted by n.e.r.d
jbsmith1,
pics below
arh yes...the fit looks good m8...hmm i see i would need to use a low profile steering servo, I'am still tempted though, good work keep us posted
Old 01-30-2008, 05:49 AM   #667
n.e.r.d's Avatar
yup jbsmith1, gotta use a low profile servo.
i'm using the futaba 9550.
ko 2413 will do the job too.
will keep you guys updated once i get it sorted out.
looking forward to 15mins runtime..
Old 01-30-2008, 06:15 AM   #668
JLock's Avatar
You can get one, but have to order it through Hong Kong or other Asian markets. Kyosho has told us that there is no market for the car here in the states and will not import it here. Funny, because there are at least 50+, and counting, guys that I have seen on this forum that have bought the car and many parts for them. In the mean time, your local LHS that Kyosho and other say they support have been left out in the cold, again losing monies to overseas suppliers, hobby shops, and the internet. But hey, you can get that cool new model Mini Z that they are importing to the states.
Old 01-30-2008, 02:55 PM   #669
Zootcapri's Avatar
The spring for the rear is the exact same size as the spring for the front of the AE rc12l4 1/12th pan car and is available in at least three spring rates... atleast one of them is softer than the stock spring.
Zootcapri is offline   Reply With Quote
Old 01-31-2008, 05:44 AM   #670
jbsmith1's Avatar
yes thanks zoot, the stock kyosho rear springs mic out at 0.021' and 0.275' length, the L4's are a little shorter but still fit...I will try their 0.018's
I noticed i have around +1 deg of off camber wear (see pic)
http://i24.photobucket.com/albums/c2.../camberpic.jpg
Has any one tried this Team Honest part that gives -1.5 deg?
http://www.redrc.net/wp-content/uplo...estspada-2.jpg
Old 01-31-2008, 07:19 AM   #671
Zootcapri's Avatar
I have observed similar wear and no..haven't tried the camber adjusting top plate.
You are doing some good work testing. We are still in Deep winter here... lots snow. The only track time I have had was in Vegas and I blew out a 6x10 bearing (rear axle) after about 4-5 minutes. But... on that big track.... was a ton of fun!!
Old 01-31-2008, 05:02 PM   #672
masterrch's Avatar
Default new spada owner
well Iam another for the list of US spada owners,I have yet to put it together.
I have a few questions; 1)are the hop-up items(aluminum/carbon bits from kyosho) needed.2)I have read most of this thread but how do you place an
order w/RC Rainbow?and is this the best place for hop-ups and spare parts?
TIA
Rich
masterrch is offline   Reply With Quote
Old 01-31-2008, 05:32 PM   #673
MugenDrew's Avatar
Trader Rating: 30 (100%+)
You guys are killing me with this thing. Warming up the credit card...
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 01-31-2008, 05:41 PM   #674
Zootcapri's Avatar
Originally Posted by masterrch View Post
how do you place an
TIA
Rich
PM Ivan "bakaguyjean" and he will take care of you.
Old 02-01-2008, 03:47 PM   #675
border r/c's Avatar
here the photo of the new tuned pipe from Sirio on my car
Tuned motors and pipe back at stock
part nr inline pipe set s0920010
Kyosho Gas powered 1/12th pan car-01022008023_resize.jpg   Kyosho Gas powered 1/12th pan car-01022008024_resize.jpg
http://www.the-border.com
Europe's largest 1/8 scale 1/10 rc car warehouse.
3Racing-Ride-BRP-Team Orion-XRAY-HUDY-Serpent-Kyosho-Lrp-Speed Passion-MR33-JG-and many more
border r/c is offline   Reply With Quote
Kyosho Silicone Lube for 1/12th Dampner Tubes noline Electric On-Road 4 12-20-2007 11:13 PM
wtb: rc gas powered jowel_men R/C Items: Wanted to Buy 10 05-13-2007 09:41 PM
1/18 Electric Powered bpandragon Electric Off-Road 5 04-07-2006 10:22 AM
24.7 powered RS4 Racer 2 bbb R/C Items: For Sale/Trade 2 05-25-2003 12:15 AM
which powered kit??? famous182 Nitro On-Road 2 05-07-2003 07:19 PM
