Old 11-15-2007, 03:37 AM   #481
bakaguyjean's Avatar
Originally Posted by gregmuri View Post
Ivan, the tank is from the LOSI XXX-NT part number LOSA9310.
Another option part for the Spada:
http://www.charge-rc.com/spada.htm
I got this bumper in, not much say as its just a bumper. Its 3mm plastic something and it pretty flexiable. But held its shape in the lets see how far i can bend it test.
But as i have broken my bumper i might have to get one of these.
My body projects blog http://rcbodyproject.wordpress.com/
bakaguyjean is offline   Reply With Quote
Old 11-15-2007, 10:00 AM   #482
What nitro % are you guys using? I normally use 30% in my 1/10 & 1/8, but I think it might be a bit too much for this little monster...I'm think 20%.especially since I don't have any head shims for this motor.
Also is anyone using the tuned version of the sirio .09 with black case and blue head? If so how different is the performance?
Thanks.
1FastVW is offline   Reply With Quote
Old 11-15-2007, 10:15 AM   #483
JLock's Avatar
Thanks.
Use 15% to 20% nitro fuel. 30% is way too much nitro for that small of an engine. I helped a friend break-in an engine for one of the nitro 18s made by Xray. We experimented with both 20% and 30% fuels. 30% jumped the temps 25 to 45 degrees above using 20% fuel. So, if you want to keep your engine for a while, use no more than 20% nitro fuel.
JLock is offline   Reply With Quote
Old 11-15-2007, 11:33 AM   #484
Zootcapri's Avatar
I ran three back to back 15 minute sessions at our track with:
the blue head
30% fuel
the Losi fuel tank conversion
Car was responding briskly, shifting consistantly and running cleanly for all 15 minutes.
Head temp never got over 200F.
The blue head made a big difference. 30% ran fine.
Your actual mileage may vary...
Zootcapri is offline   Reply With Quote
Old 11-15-2007, 11:36 AM   #485
Zootcapri's Avatar
One thing to remember. With the stock tank you will only get three minutes (or so) of clean running. Then it will start lean bog (ping). With the leaning the temps climb rapidly.
Old 11-15-2007, 12:42 PM   #486
the blue head
30% fuel
How is the top end on this motor...rpm??? i saw video where it looked like spada was keeping close watch on some RRRs. Kyosho indicates about 27mph+ for the mini inferno, but that's a buggy...jsur curious since I haven't started mine yet.
Old 11-15-2007, 01:16 PM   #487
Zootcapri's Avatar
I have no idea on the rpm or speed. It was a tad (quantifiable?) slower than a 19T 1/12th pan car on the straight. That is the only thing that I have run it against.
Old 11-15-2007, 01:23 PM   #488
19T Pan cars run about what...35-40 mph...
Also anyone using the sirio tuned motor...?
Old 11-15-2007, 03:06 PM   #489
Zootcapri's Avatar
I have no idea on the speed.
Old 11-15-2007, 03:37 PM   #490
Dan Woodford's Avatar
Originally Posted by rcfoolz View Post
this little 1/12th car looks very promissing. as for being underpowered, I've ran with .09 engines in a 1/10th pan car in oval.....They are just about as fast as a .12....the weight on the rear, not much to worry about with the pan car, as it can be set up to take care of that......This would be a great car to convert over to Oval, sure would draw intrest from the oval community....
You better believe it those will end up on ovals immediately!
Dan Woodford is offline   Reply With Quote
Old 11-15-2007, 04:01 PM   #491
Zootcapri's Avatar
Kyosho.... are you reading/listening? Here is yet another type of racing that this little rocket will work in. Get in gear.... bring it to the States ....
...and make the fuel tank bigger while you're at it.....
Old 11-15-2007, 08:21 PM   #492
Taylorm's Avatar
.what he said. KYOSHO, get your rear in gear and IMPORT this thing...............
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 11-15-2007, 09:04 PM   #493
JLock's Avatar
Kyosho will import this to the states like, NEVER!!!! Remember, they tell us what we want and like, puny American consumer!!
Old 11-16-2007, 05:43 AM   #494
Taylorm's Avatar
....more like puny Kyosho brains.........
Old 11-16-2007, 08:21 AM   #495
Default Engine Lag???
I've only gotton 6 tanks through this little monster, but it does appear to have a lag on the bottom when you punch the throttle.
1) Is this normal b/c there's no bottom-end neeedle?
2) Is this simply a function of my running in the engine rich at 3.5 to 4 turns on 2the top?
Also it didn't appear to shift into second (which could be driven by my two earlier points) , but I'll reset the set screw to stock and I'll try again.
Kyosho Silicone Lube for 1/12th Dampner Tubes noline Electric On-Road 4 12-20-2007 11:13 PM
wtb: rc gas powered jowel_men R/C Items: Wanted to Buy 10 05-13-2007 09:41 PM
1/18 Electric Powered bpandragon Electric Off-Road 5 04-07-2006 10:22 AM
24.7 powered RS4 Racer 2 bbb R/C Items: For Sale/Trade 2 05-25-2003 12:15 AM
which powered kit??? famous182 Nitro On-Road 2 05-07-2003 07:19 PM
