Old 08-28-2007, 08:18 PM   #256
Suspended
pics please///
MERCCER4LIFE is offline   Reply With Quote
Old 08-28-2007, 10:42 PM   #257
Zootcapri's Avatar
A few hours into the build....
I did upgrade the disk rotor... still a Kyosho part... just not the stamped steel version included.
Kyosho Gas powered 1/12th pan car-spada-1.jpg   Kyosho Gas powered 1/12th pan car-spada-2.jpg
Zootcapri is offline   Reply With Quote
Old 08-28-2007, 11:31 PM   #258
bakaguyjean's Avatar
IFW122 is the upgraded brake disc part number just in case someone needs to know.
bakaguyjean is offline   Reply With Quote
Old 08-29-2007, 08:45 PM   #259
Suspended
nice...more pics
Old 08-29-2007, 10:22 PM   #260
Zootcapri's Avatar
Three things left to do:
Break in motor
Paint body
Smile when it kicks into second....
Kyosho Gas powered 1/12th pan car-spada-finished-left.jpg   Kyosho Gas powered 1/12th pan car-spada-finished-right.jpg
Old 08-30-2007, 05:57 PM   #261
Where are u guys finding does throttle servo horn i had to make one problem is its rubbing the body body will not sit where it needs to be
iceman76 is offline   Reply With Quote
Old 08-31-2007, 07:57 AM   #262
Zootcapri's Avatar
I added this brace. I used aluminum tubing as I didn't have any 2.5 or 3mm carbon fiber. I think that there is a weakness front to back with the chassis. Most nitro cars have a top plate that reinforces the fore to aft flex. It may be overkill.... but it was easy and I think it will help. By the way... breaking in the motor.... three tanks takes about 20 minutes.... I think that each tank took about five minutes or less... I will start to lean it tonight and will have it on the track tomorrow.
Kyosho Gas powered 1/12th pan car-spada-brace.jpg
Old 08-31-2007, 08:05 AM   #263
That brace is a great idea. Im going to steal,i mean use that idea. Im not the greatest driver and have re shaped my main chassis a few times. but i if i use a brace like your it should be alot tougher. Have you thought about some sort of X shaped brace across the two beams you have installed now?
Again a very nice idea.
Old 08-31-2007, 08:08 AM   #264
Where is your servo horn hitting the body at? You might just want to raise the body a bit as the fuel lines are all over the place and you need some room in there to keep the lines from chafing on all the other gear inside.
Post a picture of you set up and maybe we can help.
Old 08-31-2007, 08:15 AM   #265
Zootcapri's Avatar
I am glad you like the idea. You can tell Kyosho to send the check to me....
I wasn't as concerned with side to side flex... at least for now. The X brace would stiffen the side to side flex... some side to side helps rear traction. I did think about bracing from the screws just in front of the fuel tank to the front in a V shape... but I would have to pass over the belt and... for now... I am staying on the sides.
Old 08-31-2007, 09:43 AM   #266
tomkelley's Avatar
Do you think that maybe chassis flex not such a bad thing? As with all pan cars, some chassis flex is part of the vehicle's overall suspension.
Detroit Radio Control Car Club
www.drccc.org
tomkelley is offline   Reply With Quote
Old 08-31-2007, 10:18 AM   #267
Zootcapri's Avatar
The bottom chassis plate seems a tad soft. Any front impact will bend it up as there is nothing to stop it. This is not a carbon fiber chassis that will return to it's original shape during flex and I have read about people bending their chassis and seeking replacement or bending it back (??). I think... just me thinking again... that there is still a lot of side to side flex.... that is where the additional traction comes from. The front to rear flex will also mess with belt tension...
As I didn't finish engineering school.... or even start engineering school... these are just thoughts... your actual mileage may vary....
Old 08-31-2007, 10:28 AM   #268
I have bent my chassis three times. the first time i didnt notice it untill the front belt came off,the second time was after the front belt came off slammed the wall hard. The third time i bent it so bad that the steering servo mounting screws were touching the ground. i have bent my chassis back and it works for just driveing but of course a new one would be better for racing.The only times my chassis has bent was full frontial impact. You know the kinda where everybody at the circut goes OOOOOOH . So i like the two braces down the side,maybe now my car will go through the boards instead of stopping at them.
BUt most of the guys i run with can drive and have not bent thier chassis`s yet.
Old 08-31-2007, 10:34 AM   #269
Zootcapri's Avatar
Yet...
This is not a manditory change... I think it will make my car better ... If you think this is a waste of time... that's cool too ... I just posted 'cause I thought it interesting.
Old 08-31-2007, 11:04 AM   #270
tomkelley's Avatar
By all means go ahead. I think its a good mod you came up with. I'm just bringing it up for discussion.. Now that you mention it, wasn't there a Spada on display with a carbon fiber chassis? Why did kyosho ommit it?
www.drccc.org
Kyosho Silicone Lube for 1/12th Dampner Tubes noline Electric On-Road 4 12-20-2007 11:13 PM
wtb: rc gas powered jowel_men R/C Items: Wanted to Buy 10 05-13-2007 09:41 PM
1/18 Electric Powered bpandragon Electric Off-Road 5 04-07-2006 10:22 AM
24.7 powered RS4 Racer 2 bbb R/C Items: For Sale/Trade 2 05-25-2003 12:15 AM
which powered kit??? famous182 Nitro On-Road 2 05-07-2003 07:19 PM
