Old 04-10-2007, 01:14 AM   #1
Ryan41's Avatar
Send a message via MSN to Ryan41
Default How do you remove the pinions off the clutch bell?
hey guys, I was just wondering how to remove the 1st and 2nd gear pinions off the clutch bell/housing? is there a nack to this?
thanks in advance.
Ryan
Ryan41 is offline   Reply With Quote
Old 04-10-2007, 01:21 AM   #2
PROVK's Avatar
Trader Rating: 14 (100%+)
Pinion remover or a rag on the gear with pliers and be gentle
George V
Mugen Seiki
Max Power Engines GRP Tires Nitro X Fuels "Mugen Blend"
www.rrcsa.org.au
PROVK is offline   Reply With Quote
Old 04-10-2007, 01:49 AM   #3
gashuffer's Avatar
Trader Rating: 48 (100%+)
Mugen makes a tool to remove pinions, you need that tool. For now place a small allen wrench in the whole on the bell and remove with rag and pliers. wear a glove then buy the tool
T-Sal
gashuffer is offline   Reply With Quote
Old 04-10-2007, 03:40 AM   #4
Ryan41's Avatar
hey, yeh I've snapped 3 allen keys so far haha..but now I have given up after getting the first gear off with a major fight..went on to the second..tried to grap clutch bell with pliers and rag..slipped and scored the inside of the bell..so I'm just gonna buy a new bell...I think the old gears/bell have seized together over time..
Old 04-10-2007, 05:30 AM   #5
Trader Rating: 15 (100%+)
I had someone show me that if you use some of the Mugen super grease on the threads before you put a new pinion on it comes off a lot easier when its time to remove it.
THE DOCTOR is offline   Reply With Quote
Old 04-10-2007, 03:31 PM   #6
It won't spin off when you run the car? Cause everywhere I see tells me to put a little bit of locktite on the threads to avoid that. It is supposed to be hard to remove.
Kyosho V-One RRR - JP Modified Mugen X12 - GQ Racing Tires - Futaba servos - KO Helios w/Spektrum Pro - Maxy's Fuel
Losi 8ight 2.0 RTR for fun times
Dredd is offline   Reply With Quote
Old 04-10-2007, 03:46 PM   #7
Wayne1one's Avatar
So does Team Magic!
http://www.teammagic.com.tw/en/profr...6055&pageNum=1
Wayne1one is offline   Reply With Quote
Old 04-10-2007, 04:07 PM   #8
bvoltz's Avatar
Trader Rating: 44 (100%+)
You should not need any locktite.... When the motor is running, it spins in direction you tighten the gears, therefore they should not spin off. I do not locktite mine, but I also have a tool at talked about above. No issues with getting them removed or installed...
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 04-10-2007, 04:52 PM   #9
ok well, I have never needed to remove them. I have the Kyosho tool anyway and even with a small bit of locktite it should not be a problem with the proper tool.
Old 04-10-2007, 04:53 PM   #10
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
My old r40 it had a plastic pinion gear removal tool....it was horrible , mugen has a metal tool and it works like a charm.
I think serpent also makes one , also if the cb is messed up just use some vice grips , it should come off then , you can also get like rubber tipped tools that wont mar as much.
Artificial-I is offline   Reply With Quote
Old 04-10-2007, 05:11 PM   #11
Rapid Roy's Avatar
I really like the looks of the Team Magic tool. Holds both the clutch bell and the pinion securely.
Rapid Roy is offline   Reply With Quote
Old 04-10-2007, 05:15 PM   #12
lil-bump's Avatar
Trader Rating: 83 (100%+)
Any one got a part# on the mugen tool
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 04-10-2007, 05:21 PM   #13
rmdhawaii's Avatar
B0532
http://www.amainhobbies.com/product_...oducts_id/9027
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 04-10-2007, 05:27 PM   #14
lil-bump's Avatar
Thanx
Race you later
Elliott Hart
Serpent America
Desoto Racing Team
Old 04-11-2007, 02:03 AM   #15
RayJ's Avatar
Default Removing pinions
Before I bought the pinion tool the toughest gear to get off was always secound gear. If you use a torch on the 2nd gear pinion and slowly heat it it will come off very easily. Aluminum expands faster that steel and will usually lossen it. Of course use OVEN gloves.
RayJ is offline   Reply With Quote
New kyosho flywheel and clutch bell plus 2 unopend clutch shooes tlxxx4driver R/C Items: For Sale/Trade 0 07-17-2007 03:54 AM
WANTED:Savage parts-clutch bell, clutch shoes, rear driveshaft,etc..Orlando, Fl. 10gter Florida Racing 0 01-26-2004 09:54 AM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 05:01 PM
How to remove pinion gears from clutch bell??? mav Nitro On-Road 6 09-09-2002 08:57 PM
How to remove pinion gears from clucth bell? mav Singapore R/C Racers 5 09-09-2002 08:08 PM
