Old 04-15-2008, 10:15 AM   #1411
Francis M.'s Avatar
Originally Posted by quietstorm76 View Post
I was using the stock housing but I realized too that it was heating up. I stripped one as i pulled into the pits. I got the car grabbed the gear and sure enough it was soft as hell. You can clearly see it was melted.
besides the motor moving forward and back the motor actually moves side to side also. just make sure that your clutch bell is not too close to the two speed housing all you need is a little more than .8 clearance so that the clutch bell can move back and forth without rubbing the two speed housing.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 04-15-2008, 01:24 PM   #1412
gentleman81's Avatar
are most of u guys running the solid up front?
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 04-15-2008, 01:35 PM   #1413
Francis M.'s Avatar
I do most of the time...
Old 04-15-2008, 01:45 PM   #1414
i heard that mugen has theirs a little cheaper now. where can i get one
Old 04-15-2008, 01:55 PM   #1415
Francis M.'s Avatar
I don't know where you can get it locally but Kamikaze seems to have a lot of nitro parts online....
Old 04-15-2008, 05:35 PM   #1416
quietstorm76's Avatar
Originally Posted by Canuck View Post
I'm curious, what is your gearing sizes ? Pinions and spurs ?
I ran 18/24 59/52. Yeah I know what your going to say.....your split is too big. Sooooooo I went back to stock gearing (17/23 59/53) and stripped spur #5,6, and 7.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 04-15-2008, 05:41 PM   #1417
Did all that. I even let several other racers look at my mesh and they all said nothing is wrong. 5 laps is all I could make before the gear stripped. I'm not new to this gear mesh thing. I race 12th scale with 64 pitch gears and rarely did I strip a gear.
When i set my mesh I slide the motor forward enough so that when the clutch is fully engaged, the gears perfectly aligned. There's no over hang..
Primary Weapon: ?
Secondary Weapon: ?
Old 04-15-2008, 05:41 PM   #1418
I am.
Primary Weapon: ?
Secondary Weapon: ?
Old 04-15-2008, 07:00 PM   #1419
thanks fellas.
Old 04-15-2008, 10:50 PM   #1420
asw7576's Avatar
Have you try to use longer screws ? eg. 2mm or 4mm longer screws to hold rear bulkheads, upper brake / stabiliser plate, rear carbon fiber suspension plate, radio plate tower, and engine mount ?
tips : use toothpick to measure depth. I suggest to have some collections of 3x12mm and 3x10mm counter sunk and button head screws.
check also throttle EPA for maximum throttle point and maximum braking point. Set it and leave it there.
Old 04-16-2008, 08:41 AM   #1421
I did all of that. I've already solved the problem. Like I said it was the pressure plate rubbing the 2nd gear housing. I shaved the housing with the Dremel and BAM!!! no more stripped gear. I've ran about an hour on the same gear so far and it shows little to no wear.
Primary Weapon: ?
Secondary Weapon: ?
Old 04-16-2008, 09:00 AM   #1422
asw7576's Avatar
glad you fixed it.
also check the 2nd gear housing not to touch the plastic brace ( plastic that connects rear bulkhead to upper graphite chassis. )
cheers.
Old 04-16-2008, 09:04 AM   #1423
Francis M.'s Avatar
What I meant was to make sure that your motor is adjusted to the point where the clutch bell is not touching the two speed housing when the clutch bell is fully extended out..... I didn't go through all the steps you mentioned except for using a shorter screw on one side of the motor mounts and just watched out for the clutch bell clearance relative to the two speed housing...
I've ran combos from 59-52, 59-53, 60-53, and 59-54 with out problems....
I beleive I ran my car in december bumping up from a 25 min b main, Ran the full 45 main on the same gears and qualified last month on the same gears except for first which I changed from 60 to 59 for ratio purposes.... ran the full 45 min main without problems.....
Old 04-17-2008, 07:52 PM   #1424
i ran all day sunday on my gears
new clutch bell, pinions and spurs. tightened all screws, new clutch bearings.
ran 2 qualifiers and a 20 min main, and my spur gears look brand new!!!!
yesssss!
Old 04-18-2008, 06:14 AM   #1425
Primary Weapon: ?
Secondary Weapon: ?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
