Old 04-09-2008, 07:48 AM   #1396
asw7576's Avatar
Hi Francis or anyone with car setup expertise,
I'm about to do pro squat in my mtx4 and mrx4. My goal : I want to get more steering off throttle, especially mid cornering so I can turn tightly near the apex with higher cornering speed.
Can you confirm pro squat described by xray is correct and effective ?
That's all.
THANKS
Old 04-09-2008, 09:05 AM   #1397
Francis M.'s Avatar
That's all.
THANKS
I've only tried the Antisquat and it makes the car feel like it has more rear traction but it turns in better and has better forward bite. I've never tried the prosquat.....
I pretty much just run my car with two rear settings now. Lower arm possition and medium.... I try to stay away from all the anti and pro squat settings....
IMO you would be better off just trying some more traditional adjustments to get more turn in. I would start off by trying to narrow out the front
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 04-11-2008, 12:23 PM   #1398
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
adjustable rear swaybar question:
anyone care to share comments regarding testing or use on the MTX4R? (heard it makes the car lazy thru chicanes)
madjack is offline   Reply With Quote
Old 04-11-2008, 04:43 PM   #1399
MugenDrew's Avatar
Trader Rating: 30 (100%+)
See the new spur gears yet?
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 04-11-2008, 05:09 PM   #1400
madjack's Avatar
http://www.mugenseiki.co.jp/mugen/menuejfi.htm
more gearing choices is always nice, I'll be interested to see if these are harder material?
Old 04-12-2008, 09:49 AM   #1401
gentleman81's Avatar
it states its a harder material underneath
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 04-14-2008, 09:31 PM   #1402
quietstorm76's Avatar
Default Gear stripping nightmare
I stripped 9 2nd spurs at the Kyosho US Open this week. I was 1 spur gear away from buying a Kyosho
After I stripped the third one I did everything from nitrokb.......................everything. Still stripped
This is what I know for a fact. Gear spacing means nothing all the gears are the same diameter. You can run any combination you want.
Spacing the 2 speed shoes out did nothing. Yeah it shifted smoother but I still stripped.
New shaft same result.
New end bell and clutch bearings. Yep you guessed it......stripped
What did I find? The pressure plate was touching the 2nd gear housing. It was getting very very hot. You couldn't even touch the end of the shaft. I thought it was the sway so I put on the blade. Anyone else notice the groove on the 2nd gear housing?
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 04-14-2008, 11:19 PM   #1403
My 2nd gear housing has a nice groove on it, it occurs when your car jumps on the track, or if your revving your engine while lifting up the car. You can either use the bladed sway-bar, or wait till the groove is big enough so it won't rub.
Have you checked your engine mounts for any stripped threads, or your chassis if its bent?
jfro6512 is offline   Reply With Quote
Old 04-15-2008, 12:40 AM   #1404
Boz
Trader Rating: 23 (100%+)
it can be from the swaybar, only if your links are to short and you use alot of droop. Or from the clutch bell touching. I ran a 3Racing spur on the second housing on the weekend, the bell was rubbing on the housing causing enough heat that the screws melted out of the spur gear. check your gear mesh first.
Boz is offline   Reply With Quote
Old 04-15-2008, 04:07 AM   #1405
Canuck's Avatar
Trader Rating: 25 (100%+)
My swaybar was touching a bit the second gear so I added 1 mm or 2 of shims underneath the swaybar housing plate. Did the trick !
Canuck is offline   Reply With Quote
Old 04-15-2008, 04:32 AM   #1406
asw7576's Avatar
Or increase the height of turnbuckles that connects to stabiliser rod.
Old 04-15-2008, 08:23 AM   #1407
Canuck's Avatar
I like that better. I am going to remove the shims and increase the height of the turnbuckles. Thanks
Old 04-15-2008, 09:23 AM   #1408
It's not the sway bar.............how do I know? I was using the blade sway bar. I didn't have the problem until I put on a new 2nd gear housing. Thew old one had a nice groove around it and I never stripped with that one. The night before qualifying started I put on fresh parts, new housing, shaft, and first gear one-way. I stripped gears from then on.The groove comes from either the clutch bell or the pressure plate. I depends on how you setup the clutch. I run Picco's so I use the collet that comes with it. It pushes the flywheel out a little more than say one for Novarossi. So I build my clutch the pressure plate comes out just far enough to touch the 2 speed. I sat and blipped the throttle and watched it cut into it. Trust me on this............I'm trying to save my Mugen brothers the head ache. If anyone has noticed anything else chime in please.
Primary Weapon: ?
Secondary Weapon: ?
Old 04-15-2008, 09:27 AM   #1409
I was using the stock housing but I realized too that it was heating up. I stripped one as i pulled into the pits. I got the car grabbed the gear and sure enough it was soft as hell. You can clearly see it was melted.
Primary Weapon: ?
Secondary Weapon: ?
Old 04-15-2008, 10:10 AM   #1410
Canuck's Avatar
I'm curious, what is your gearing sizes ? Pinions and spurs ?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
