Old 04-04-2008, 06:29 AM   #1381
quietstorm76's Avatar
Originally Posted by tony montana View Post
What would you guys suggest running for droop front and rear for a high bite fast flowing track? Also how do I measure it since I dont have any droop blocks
I would start with 2mm above ride height. Take your ride height(RH) gauge and measure the RH. Say it's 5mm, then lift the chassis. Chassis should lift to 7mm RH before the wheels leave the setup board.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 04-04-2008, 06:07 PM   #1382
gentleman81's Avatar
Originally Posted by asw7576 View Post
what happened ? got another stripping gear again ?
no my car should be good. i was listing for the other member.
i had worn pinions, and we havent raced yet, so i am hoping
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 04-04-2008, 06:25 PM   #1383
my 2 cent, the car is just good enuff not to strip all the time, but with the .8 gears, and something in the drive train, the gears just strip.
every screw must be tight, and bulkhead must stay in good shape. plus the motors getting stronger and more torque happy.
what are the factory guys doing?
Old 04-05-2008, 12:55 PM   #1384
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Originally Posted by JRGTR View Post
yeahh, the paper method sucks, I prefer to remove the 1st gear,then adjust the engine position only with the 2nd, then only with the perfect clearence I install back the 1st gear. posibly thats my scecret or I am a lucky Mugen owner
Exactly how I've been setting up my mesh. The paper trick doesn't work on Mugen which is why people still strip gears. Just set the second gear mesh first, then install the 1st gear spur and you're done. End of stripping problems, unless you forget to tighten and threadlock the chassis side engine mount screws.
HarKonnenD is offline   Reply With Quote
Old 04-05-2008, 05:28 PM   #1385
i am going over my car with a fine tooth comb. and i will see next sunday. i think it will be a good day
Old 04-07-2008, 02:11 AM   #1386
asw7576's Avatar
good luck, .... i hope you bring something from the race.
Old 04-07-2008, 07:37 PM   #1387
CraigM's Avatar
Trader Rating: 34 (100%+)
does anyone know a good way to get a little more turn in? My setup is working well at the moment and both on-power steering and steering under brakes are good, but my car pushes a when entering corners off throttle. Vitals are as follows:
front spool, 50k rear diff
1.5 deg rear toe
1 deg front toe
c ackerman plate
1mm spacer in front of front arms (caster)
4deg rear camber, 2 deg front
light blue front springs, dark blue rear
50wt shock oil, stock pistons drilled out to 1.2mm
front and rear shocks on middle holes
front sway flat, rear sway half up
lowest rear hinge pin location
obviously track is high grip (VHT)
Originally I had the front arms further back and moving them forward helped a bit so I was considering putting them all the way forward.
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 04-07-2008, 08:23 PM   #1388
asw7576's Avatar
1.5 deg rear toe
1 deg front toe
c ackerman plate
more steering at mid cornering off or half throtle : try one of the following
1. More caster ( more laid back )
2. I don't know A or B or C Ackerman block but you should look for the straightest steering linkages if you see from above.
3. Front tires : 1 degree toe out
4. Increase the height of upper front arm position by another 1mm
I think that's what I'm going to do with my MRX4-R. I'm having trouble with mid cornering too. I checked with Solhman, number 4 can help more steering off throttle.
Old 04-07-2008, 09:09 PM   #1389
Roger's Avatar
I would do this first. Or you can try the 0.5mm shims to dial it in.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 04-08-2008, 11:07 AM   #1390
JayL's Avatar
yep, totally agree with Roger: front roll center is highly overlooked
JayL is offline   Reply With Quote
Old 04-08-2008, 05:04 PM   #1391
CraigM's Avatar
Awesome thanks guys. There is 1mm under them at the moment so i'll go up to 1.5
Old 04-08-2008, 06:39 PM   #1392
I went from 1mm to 2mm and I could really feel the difference. only drawback is the car feels a little lazy in the chicane.
Primary Weapon: ?
Secondary Weapon: ?
Old 04-08-2008, 09:29 PM   #1393
great info guys.
lets push mugen to put out a setup guide : )
Old 04-08-2008, 10:04 PM   #1394
Francis M.'s Avatar
Try removing all the spacers out and go one shore softer in the front tires. You will gain steering w/ the softer front but still have the car run real flat and reactive. If you already like the set up and don't want to go to a softer front tire then just stand up the front sway bars
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 04-09-2008, 03:28 AM   #1395
Thanks both are good ideas, I'll have to try them next time.
Primary Weapon: ?
Secondary Weapon: ?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
