Old 03-21-2008, 02:08 AM   #1321
itchy b's Avatar
Originally Posted by CraigM View Post
I don't understand how any of this helps you not strip gears. Putting half a thrust bearing inside the clutch will make a huge gap and wont work on some engines e.g. my OS speed's crank isn't long enough to put shims inside the clutch
The kawahara carbon fibre mid brace is the best protection, combine it with the kawahara 1 piece engine mount and a 4mm chassis and you'll be laughing
Also combine them with a good mesh and make sure that the spur housing bearings and 2 speed shaft are in good condition will make stripping gears a rare ocurrance
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 03-21-2008, 02:11 AM   #1322
itchy b's Avatar
I wonder if anyone has used the Kawahara front aluminium upper hinge mounts with 2 hinge position settings?
How does the different settings change the handling of the car compared to just using the standard plastic ones?
EX1.5-SC10 4x4
Old 03-24-2008, 07:53 AM   #1323
Francis M.'s Avatar
What are the hinge pin changes on the Kawahara set?
TQ-racing Yokomo BD7 Airtronics
Francis M. is online now   Reply With Quote
Old 03-24-2008, 08:20 AM   #1324
lil-bump's Avatar
Trader Rating: 83 (100%+)
It it allows for a short or long upper arm setup.
This post has been edited.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 03-24-2008, 08:41 AM   #1325
Francis M.'s Avatar
If it just straight up and down then I don't really see much use for it. since you can just use spacers for that......
Old 03-24-2008, 08:41 AM   #1326
spenzalii's Avatar
Send a message via AIM to spenzalii
Default Electronics questions
The build is almost finished. I'm trying to wire up the radio tray. Is anybody using a switch? I was considering it, but it looks like it would be an absolute mess to wire, since the switch is mounted at the top of the transponder mount.
This also begs the question of anyone running a Li-po in the car. Where and how would the regulator be mounted?
spenzalii is offline   Reply With Quote
Old 03-24-2008, 08:47 AM   #1327
Francis M.'s Avatar
I don't use a switch for the same reason........
Old 03-24-2008, 10:36 AM   #1328
Send a message via AIM to jeff whiting
I don't use a switch either.
JEFF
Thanks to our sponsors: Desoto Racing, Serpent, Ielasi Tuned, HobbyWing, Byron's Fuel, Matrix Tires, Protoform, Futaba, www.LEFComplex.com
jeff whiting is offline   Reply With Quote
Old 03-24-2008, 11:03 AM   #1329
lil-bump's Avatar
I've never seen these mounts not sure if it moves vertically or if it has any horizontal movement
Elliott Hart
Serpent America
Desoto Racing Team
Old 03-24-2008, 11:20 AM   #1330
Francis M.'s Avatar
If it moves the pins horizontal. I'm guessing it will be more reactive with a shorter link or pins moved outside.......
These type of options might be worth a try if you go to a lot of different tracks which I don't. I pretty much go to 1 to 2 tracks on a regular basis..
Old 03-24-2008, 12:19 PM   #1331
asw7576's Avatar
Old 03-24-2008, 12:54 PM   #1332
lil-bump's Avatar
I'd rather not add the weight so high up on the chassis
Elliott Hart
Serpent America
Desoto Racing Team
Old 03-24-2008, 01:19 PM   #1333
Francis M.'s Avatar
It's really not much weigh and not that high since it's pretty close to the upper deck........
I'm curious how it will work with the optional outer pin position.....
Old 03-24-2008, 01:27 PM   #1334
asw7576's Avatar
I think the horizontal design is pointless. If I put on the outer holes, two things will happen :
My front track width will be wider if I want to keep negative camber
My front camber will be 0 if I want to keep the same trackwidth
Old 03-24-2008, 01:31 PM   #1335
Francis M.'s Avatar
You have to reset your camber settings with the pivot balls.....
Although the MTX-4 is already good but I always get curios when things like this pop up....
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
