Old 03-08-2008, 03:59 PM   #1276
Sow&Steady's Avatar
Originally Posted by Nitrorea View Post
This is my first Mugen/on road kit so just bear with me here. So I just finished installing the engine and all of the gears and everything look fine but I have one question--let me try and explain.
Ok--so the car is sitting flat on the ground and I push it forward, while pushing forward I can hold the spur gears still with my thumb and the car still rolls.
If I roll the car backwards I cannot hold the spur gears still without stopping the car.
Does this sound right? I am positive that I put everything together the right way so I just want to make sure I am doing everything right.
Here is a video that I just did demonstrating what I am talking about. Sorry for the bad lighting but you can see that I can hold the spur gears still and still move the car forward.
Thanks for any help...
Yes that sounds right because there is a one-way in the 1st gear. The 2nd gear only engages at speed and pushing it by hand will not do the job. So all sounds fine...
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 03-09-2008, 12:10 AM   #1277
bboy's Avatar
I am new and just getting my MTX4R but am still unsure of the engine. I see that Ninja and OS TZ SpecII are favorites, but since I am just trading up from the Tamiya TG10.MK2, will these be good engines for me? Or should I try something mid-range? I am also looking at the OSTZ12 5 port.
Any suggestions welcome. Thanks!
Serpent 960-08 + Max XL9
XRay NT1 + Max XXL3
bboy is offline   Reply With Quote
Old 03-09-2008, 01:06 AM   #1278
Rc_Boy89's Avatar
Send a message via MSN to Rc_Boy89
There are many choices out there and since your moving up from the Tamiya TG10.MK2 i would first suggest looking at the os tz range. Either the tz12 3port or 5port like you say would be a good choice, very cheap engines with great performance and replacement parts are not overly expensive.
.:Team Extreme:.
Kyosho STRR / OS Speed
Mugen MTX-4R / RB Speedline Matrix
Jammin CRT.5 / Sirio STI
Rc_Boy89 is offline   Reply With Quote
Old 03-09-2008, 08:53 PM   #1279
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
I have a question about my clutch...the track i'm run on is kinda medium with tight turns i notice when i pull the throttle it hesitate just a tad bit then it launch and when i let off the throttle the car slow down to almost stop ....i adjust the brakes but still doing the same... so my question is do i need to tighten the clutch or any idea what i need to do?
thanks
bobby
bobbyblaze is offline   Reply With Quote
Old 03-09-2008, 09:21 PM   #1280
mugenracer68's Avatar
Send a message via Yahoo to mugenracer68
Thumbs up
Did you check your drag brake also.
mugen seiki mtx4r/mrx4r/futaba/maxy's fuel/GQ tires/ 301 raceway, where we crown champions
mugenracer68 is offline   Reply With Quote
Old 03-09-2008, 09:35 PM   #1281
bobbyblaze's Avatar
yes it pretty good ...but on the same track i drove my tc3 the car move more freely but the tc3 is using a regular 2 shoe clutch.....mugen is tighter ...just hard for me to explain ..not trying to compare apples to oranges ...but when i get on the throttle and let go car slows down....now when i get back on it is hesitate......i'm to get some understanding on the car on what i'm doing wrong
Old 03-09-2008, 10:15 PM   #1282
Team STPN's Avatar
Fairly new to Nitro racing and just getting back to racing RC cars again from a long layoff, but I do have a couple of Clutch questions too. Tightening the clutch does what?? Loosening does what to the clutch? What are the differences in the colors of the clutches, grey, yellow, and red by Mugen???
Team STPN is offline   Reply With Quote
Old 03-09-2008, 11:54 PM   #1283
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmm
tightening the clutch nut raises the rpm at witch the clutch engages loosening lowers the engagement point witch will make the car sluggish out of the corners on the clutch shoes grey is standard yellow shoe grabs more on the clutch bell red not sure of that but know that it is harder shoe hope im right & this helps mugen baby if im wrong maybe someone can help out
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 03-10-2008, 06:10 AM   #1284
bobbyblaze's Avatar
thanks you help alot because my car were sluggish coming out of corners
Old 03-10-2008, 06:30 AM   #1285
Sow&Steady's Avatar
What SOLOARTIST says above is correct but check the tune of your engine as well as the clutch gap. Lastly, to fine tune, look at gearing.
Old 03-10-2008, 07:07 AM   #1286
Trader Rating: 13 (93%+)
can someone please tell me how many teeth are on each of the mtx4 belts please?
thank you
John
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 03-10-2008, 07:41 AM   #1287
bobbyblaze's Avatar
one more question ........ i notice there are different color clutches which one is best or which one last the longest?
Old 03-10-2008, 09:10 AM   #1288
Default HMM
i would use the grey shoe it has average wear once you get that dialed in you can try the yellow i have not seen anyone run the red shoe
WILLIAM PENDERGRASS
Old 03-10-2008, 11:14 AM   #1289
JayL's Avatar
team STPN: at speedworld most of the guys are running 8.9-9.0mm for the spring and .35mm for gap with an extra thurst washer under the clutch bell for spacing
JayL is offline   Reply With Quote
Old 03-10-2008, 12:11 PM   #1290
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
I would suggest going .5mm for gap in Novarossi/OS engines and .6 gap for Picco/Sirio based engines. I have tried .4mm and .3mm in my TZ and it seemed like a OS CV I was trying to tune. The difference between .5 and .3 is huge. Also for the spring... The way I tighten it (depending on the engine) is to see like 2 threads of the nut. Then I keep tightening it from the outside to get the punch I want.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
