Like Tree1Likes
Mugen MTX-4R
Old 03-03-2008, 09:16 AM
  #1261
Quietroit's Avatar
Questions?? high and low roll center
How do you change the roll center in the front for the mtx4r
Quietroit is offline
Old 03-03-2008, 09:37 AM
  #1262
lil-bump's Avatar
Trader Rating: 85 (100%+)
By adding or removing the spacers under the front upper arm carriers.
Race you later
lil-bump is offline
Old 03-04-2008, 11:30 AM
  #1263
va_connoisseur's Avatar
Default Rebuilding question
Hey Guys/Gals,
I am looking to rebuild the my car for the upcoming year. I am going to ditch the current chassis for a 4mm and add some new bearing all around. Any other suggestions to get the car ready?
va_connoisseur is offline
Old 03-04-2008, 11:50 AM
  #1264
Roger's Avatar
Originally Posted by va_connoisseur View Post
Hey Guys/Gals,
I would also consider changing the front and rear bulkheads since your gonna rebuild. This will make your car feel a little more tighter just because the whole suspension/differential assembly is attached to the bulkheads. I usually change out my bulkheads at least 3 times per year if im racing 2-3 times per month. Hope this helps.
Roger is offline
Old 03-04-2008, 11:56 AM
  #1265
Thanks for the info. I will look through my car parts and see if I have some.
Old 03-06-2008, 05:22 PM
  #1266
tony montana's Avatar
Trader Rating: 69 (100%+)
what belts seem to hold up the best and perfered ones to run the rubber or urathne
tony montana is offline
Old 03-06-2008, 05:31 PM
  #1267
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
So for the rubber are holding up for me
entitymugenmtx is offline
Old 03-06-2008, 10:12 PM
  #1268
chippy's Avatar
Default Belts
front and rear urethane
rubber for the side
I have tried the Kawahara Kevlar belts didn't think much of them.
chippy is offline
Old 03-07-2008, 02:20 AM
  #1269
Rc_Boy89's Avatar
rubber for the side
+1 good combo
Rc_Boy89 is offline
Old 03-07-2008, 04:48 PM
  #1270
how do I tell the diiference between rubber and urathane? What does the mtx4r come with
Old 03-07-2008, 05:44 PM
  #1271
chippy's Avatar
Rubber
chippy is offline
Old 03-07-2008, 05:47 PM
  #1272
chippy's Avatar
The rubber belts have a dull appearance
Urethane are shiny
chippy is offline
Old 03-08-2008, 10:21 AM
  #1273
SOLOARTIST 702's Avatar
Default race
congrats to BRIAN THOMAS on his TQ & win with his MTX4R in HAWII GOOD JOD
SOLOARTIST 702 is offline
Old 03-08-2008, 03:22 PM
  #1274
Nitrorea's Avatar
This is my first Mugen/on road kit so just bear with me here. So I just finished installing the engine and all of the gears and everything look fine but I have one question--let me try and explain.
Ok--so the car is sitting flat on the ground and I push it forward, while pushing forward I can hold the spur gears still with my thumb and the car still rolls.
If I roll the car backwards I cannot hold the spur gears still without stopping the car.
Does this sound right? I am positive that I put everything together the right way so I just want to make sure I am doing everything right.
Here is a video that I just did demonstrating what I am talking about. Sorry for the bad lighting but you can see that I can hold the spur gears still and still move the car forward.
Thanks for any help...
Nitrorea is offline
Old 03-08-2008, 03:58 PM
  #1275
quietstorm76's Avatar
It's normal due to the "one way" bearing in the first gear housing.
quietstorm76 is offline
