Old 02-20-2008, 08:08 PM   #1216
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
I figured something like that. Too bad I have some rubber belts in my parts bag. Ah well maybe I'll trade em in or just use em LOL.
HarKonnenD is offline   Reply With Quote
Old 02-20-2008, 10:20 PM   #1217
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
Could you provide with part numbers for these upgrades ? just wanna be sure i am getting the right parts, thanks !
Originally Posted by olev View Post
To convert a 4 to 4R you need new front uprights, front lower arms (or shave some off the original ones where the steering link mounts of new uprights will "meet" the lower arm) and rear upper link mount. That's all for handling & geometry change. Then you might want the cosmetic bits, new front spool/oneway and universals if you don't have them already.
Tag is offline   Reply With Quote
Old 02-20-2008, 11:43 PM   #1218
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Just use the belts. They don't last quite as long, and they tend to gum up the pulleys...over time, but despite all that I ran rubber belts exclusively after my first race with the car.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 02-20-2008, 11:47 PM   #1219
HarKonnenD's Avatar
Is there an issue with using Urethane and rubber belts together? I had to replace the rear belt and the only one I had was the rubber. The front and middle belt are fine, but are the stock ones.
Old 02-21-2008, 12:22 AM   #1220
Rc_Boy89's Avatar
Send a message via MSN to Rc_Boy89
The Urethane belts on front and rear with rubber side belt is a good combo. When I got my first mtx-4 they actually included a rubber side belt instead of the urethane.
I had a rear urethane snap on me during a race, replaced that then the front one didn't take long to snap to, so ive figured replace both fr & rr once one goes + keeping an eye on the side belt making sure still enough tension.
Its difficult to tell the condition of the urethane belts compared to rubber, they can snap on you.
Just what I've discovered
.:Team Extreme:.
Kyosho STRR / OS Speed
Mugen MTX-4R / RB Speedline Matrix
Jammin CRT.5 / Sirio STI
Rc_Boy89 is offline   Reply With Quote
Old 02-21-2008, 06:21 AM   #1221
Seisick's Avatar
T0151B FRONT LOWER ARM
T0164 FRONT UPRIGHT
T0161 REAR UPRIGHT
ARE THE ONLY CHANGES NEEDED IN PARTS TO BECOME R
THE REST, FRONT ONE WAY SPOOL, UNIVERSALS, ALUM ENGINE MOUNTS
AND BRAKE DISC ARE JUST UPGRADES WITH NO EFFECT IN GEOMETRY
MY MANDATORY UPGRADES
DOUBLE REAR SHOCK TOWER OR 4MM OPTION TOWER
TEFLON BRAKE PAD
AND IN HIGH TRACTION, YELLOW SHOE AND MSR CLUTCH SPRING
AND STEEL GEARS THAT LAST FOREVER
REGARDING THE URETHAN BELTS, NEED MORE TENSION THAN RUBBER IF YOU DO NOT WANT TO LOOSE TEETH, TOO MUCH TENSION IN THE OTHER HAND WILL MAKE IT SNAP WITH NO REASON WHATSOEVER
HOPE IT HELPS
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 02-22-2008, 07:06 AM   #1222
T0164 FRONT UPRIGHT
T0161 REAR UPRIGHT
The part numbers are correct, the descriptions aren't. T0161 is Graphite Rear upper Arm Mount. Rear uprights are T0153, same for 4 and 4R.
Bear in mind that you have to add shims under steering linkage on the front upright to achieve approx. the same steering geometry as the original MTX-4. The T0138-B "FRONT UPRIGHT WC" and T0164 have the steering linkage located 3mm lower that the original (while T0138-B is otherwise the same as original, T0164 is the new 2 degree kingpin option). The T-0138B was made to be able to tune bump steer, this is the part that was used on the World Champ winning car.
olev is offline   Reply With Quote
Old 02-24-2008, 11:55 AM   #1223
tony montana's Avatar
Trader Rating: 66 (100%+)
anyone know where to buy the is250 body? Cant find it anywhere
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 02-24-2008, 12:34 PM   #1224
lil-bump's Avatar
Trader Rating: 83 (100%+)
If that's a Kawahara body check with RC Nitro Nation
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 02-24-2008, 02:33 PM   #1225
I checked there and they said there not carrying kawahara anymore
Old 02-24-2008, 03:28 PM   #1226
lil-bump's Avatar
Wow... he was one of the biggest Kawahara dealers in the US
Elliott Hart
Serpent America
Desoto Racing Team
Old 02-24-2008, 04:18 PM   #1227
choisan's Avatar
pro-s-futaba.co.jp must have it. check it out.
choisan is offline   Reply With Quote
Old 02-24-2008, 05:38 PM   #1228
I have heard that Mugen Racing will be bringing in Kawahara again.
Old 02-24-2008, 09:11 PM   #1229
Tag
Tag's Avatar
thanks for the help
T0164 FRONT UPRIGHT
T0161 REAR UPRIGHT
TEFLON BRAKE PAD
HOPE IT HELPS
Old 02-24-2008, 09:29 PM   #1230
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmm
that will be beautiful whats up scott
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
