Old 01-14-2008, 03:56 AM   #1111
chookgb's Avatar
Trader Rating: 26 (100%+)
Originally Posted by GIgahertz View Post
i just bought a mtx4r.i need some advice before buying extra belts,which is better rubber or urethane?
i run the rubber belt on the side and the urethane front and rear this gives the best durability and still provides a free drivetrain
chookgb is offline   Reply With Quote
Old 01-14-2008, 05:30 AM   #1112
RC=Realy_Costly's Avatar
hey guys,
well start of the new season was awesome, took the x4r out for its maiden and well wat can i say it preformed like a mugen.. AWESOME!
but i seem to be chunking my rear fomies on the outer side, can any1 tell me as to why this is happening and what to change to prevent it, something tells me its set up related???
thanks
Mugen mtx4R, powered by Ninja, Directed by JR, driven by Remo Siciliano....
HB Cyclone, powered by Komodo dragon 19T, run by LRP, Directed by JR, driven by Remo Siciliano....
RC=Realy_Costly is offline   Reply With Quote
Old 01-14-2008, 08:16 AM   #1113
musti72's Avatar
the outer tire is having more stress in corners...
you can use harder tires on the outer side. ex: 42 rear outer side, rest is 40
or, you can make a sidewall on the tire with ca, it also reduces wear but having less grip
musti72 is offline   Reply With Quote
Old 01-14-2008, 04:35 PM   #1114
Trader Rating: 57 (100%+)
What is the camber set at??
insanewulf is offline   Reply With Quote
Old 01-14-2008, 06:13 PM   #1115
CraigM's Avatar
Trader Rating: 34 (100%+)
more camber. If you already have a high value (e.g. 5 deg) then increase the camber rise by adding shims under the linkage on the rear upright or going to a lower position on the inner linkage
also use the stickers that come with the tyres as they help to prevent chunking
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 01-14-2008, 08:54 PM   #1116
thanks 4 ya input guys ill look into the harder compound and craigM's suggestion because i am running near to 5deg so that accounts for that.
thanks 4 ya help
Old 01-15-2008, 11:29 PM   #1117
GIgahertz's Avatar
Default suspension problem
i just finished setting up my car on a hudy tweak station.but i noticed something when i lift the rear left tire it has more travel than the right suspension just want to ask if this is normal.
GIgahertz is offline   Reply With Quote
Old 01-16-2008, 12:23 AM   #1118
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
no, check shock length, make sure your droop settings are correct. Last week one of my friends set up a car with the front droop settings on the left side of the car and rear on the right.. don't drink and assemble boys...
rx7ttlm is offline   Reply With Quote
Old 01-16-2008, 04:10 AM   #1119
I am trying to install the futaba S9452 for steering.
When using the S9451 the manual says to use the H0362C and H0362F spacers.
Shall I use the same for the S9452 ?
How about the grommets and those brass tubes that come with the servo. Shall I use those also?
sllo is offline   Reply With Quote
Old 01-16-2008, 07:31 AM   #1120
LogiK's Avatar
Trader Rating: 11 (92%+)
Yes and no I wouldnt.
LogiK is offline   Reply With Quote
Old 01-19-2008, 06:02 AM   #1121
Seisick's Avatar
got a too loose sidebelt when runing the 24t pulley?
just flip the tensioner (mtx4 came like that) and switch from 3x8 flat head to button head,
the carbon part will now be in front of the engines backplate allowing to have enoug tension to use the 24t pulley
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 01-19-2008, 02:15 PM   #1122
Is the 3-racing 4mm chassis any good?? I have heard that the quality of some 3-racing parts is poor. I don't know about the quality of the chassis??
Old 01-19-2008, 02:32 PM   #1123
chookgb's Avatar
don't get the 3 racing chassis it is not milled down to keep the bulkheads and mounts at the right height and the quality is also poor, the best 4mm chassis to get is the kawahara one it is milled and of the highest quality
Old 01-19-2008, 03:15 PM   #1124
I am trying to adjust rife height and I want to set the front at 4mm and the rear at 5mm.
However I can not lower the car that low. I can go as low as 7mm.
How do you guys set the ride height that low?
Do I have to trim the tires to a smaller diameter?
Old 01-19-2008, 06:01 PM   #1125
lil-bump's Avatar
Trader Rating: 83 (100%+)
You need to check the lower spring retainers on the bottom of the rear shock. The flat looking retainers go on the rear of the car. check your manual. You can not reverse these. Hope this helps
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
