Old 01-06-2008, 08:51 PM   #1066
wallyedmonds's Avatar
Originally Posted by Scott Fisher View Post
Yes.. the rubber thingys that no one uses. I actually did use them a few years ago, but decided I did not like the little bit of flex that came with using them.
ya i dont and never have used them,think there called grommets or something like that.
wallyedmonds is offline   Reply With Quote
Old 01-06-2008, 08:53 PM   #1067
go to sleep walldo hey NINJAS R GARBAGE
nitro ho is offline   Reply With Quote
Old 01-06-2008, 08:57 PM   #1068
Originally Posted by itchy b View Post
Yes Wally, they mean those rubber thingys that nobody but you use!
i dont use.
Old 01-06-2008, 10:18 PM   #1069
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Originally Posted by Stoogey View Post
Thanks heaps, saved me from buying one and trying it myself. Cause i read that the v1 rrr belt fits (nitrokb) , and you can get belts that fit the mtx3, g4 and v1, so i thought they were interchangeable, thats all.
Unless your planning on running your mtx-4 without a belt tensioner... the kyosho v1rrr belt wont fit in the mtx-4 or viceversa... (just tried it right now)
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 01-06-2008, 11:00 PM   #1070
asw7576's Avatar
Originally Posted by TomB View Post
yeah, i'm not married yet lol...problem is when you get married i heard the fun ends!?
Some says life begin at 40
( if you are not married yet, then who is in your avatar ? )
Old 01-06-2008, 11:54 PM   #1071
Stoogey's Avatar
Well i guess nitrokb was wrong then , cause from the looks of it, i dont think i can run the belt without the tensioner without it rubbing against the manifold, unless i can find another manifold that would fit, but then again there would be no point.
Stoogey is offline   Reply With Quote
Old 01-07-2008, 03:02 AM   #1072
itchy b's Avatar
That pic was of the day that his olds took him to the playground last weekend!
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 01-07-2008, 04:17 AM   #1073
juzza99's Avatar
ive got 2 belt tensioners on my mtx for the side belt.
juzza99 is offline   Reply With Quote
Old 01-07-2008, 08:58 AM   #1074
Seisick's Avatar
i use rrr sp belt only when i use the 24 side pully and don want to use an additional belt tensioner, but i don't remember if it is the 384 or 387, cuz one of them is shorter that mtx4 belt, the rrr sp is similar tu mugen rubber ones.
for the 25t side pulley there;s no need for additional belt tensioner, btw when finish racing i take out the side belt, don't know if it works but i do the same for my clutch spring and it has been consistant for the last year with minimal need to adjust deeper the nut
happy racing
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 01-08-2008, 02:59 PM   #1075
Default clutch mtx 4r
Hello guys,
I may or may not have a problem, i finally came to assemble my clutch but in order to come as close as possible to the end play of the clutch bell of 0,3~0,5 mm i didnt used any shims at the end, and if i did use only 1 shim the clutch bell didnt move freely,
does anyone know how this is possible? or is this normal,
thank you in advance for your reply
dirk
oskamp is offline   Reply With Quote
Old 01-08-2008, 03:26 PM   #1076
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by oskamp View Post
Hello guys,
dirk
this type of thing usually occurs when you use the engine manufacturers collette rather than the one supplied in the kit (tho that said my CRF collette works fine). Also make sure you have tightened the flywheel nut firmly enough
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 01-08-2008, 03:27 PM   #1077
Seisick's Avatar
Hello guys,
dirk
perhaps your gap is too big, and it takes some runs to your clutch shoe to settle, then you can readjust your gap and endplay, .5 gap and .1 is normal
HobbymaniA
GoT MuGeN?
Old 01-08-2008, 03:31 PM   #1078
Francis M.'s Avatar
Pretty much what he said.
the collet used was a bit long, you can grind the back of the collet so you can have room for shiming.....
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 01-08-2008, 05:44 PM   #1079
FYI,
Just put the clutch together on my R.. when setting the end play i was having trouble getting the shims right. I noticed the 3X16 set screw felt funny while tightening down the clutch pack. When I removed the screw I noticed the tip was shiny and I realized the bolt was too long and bottoming out. I ground a few threads off the bolt, Now the end play is correct and the bolt tightened down perfectly..
Mugen MTX-4R, Airtronics, Speedworld Raceway...
Slotrc is offline   Reply With Quote
Old 01-08-2008, 06:06 PM   #1080
Gseventeen's Avatar
Hello guys,
dirk
If you are using a shim behind fly wheel this can cause your problem as well,take it out,if you are.
NEW CAR (watch this space) POWER:NOVA 353 TUNED, JP BLACK MODDED,OS SPEC11
SPONSOR= EDV ELECTRICAL!! 9699-9961
'' THE LAD COMING BACK SOON!!!!
Gseventeen is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
