Old 12-08-2007, 11:16 AM   #931
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
Originally Posted by YLLIB View Post
Hello Bobby, SpeedWorld just received some more in last week, they are price-less. Use the station and home and not at the track, because if someone drops a part when loaning it out, it sucks they are made from alum past experience.
lil-bump- FYI if you cut a little piece of brass and stick on the flat spot of the tit shaft were the grub screw goes the wear factor is minimal and will last for ever.
SpeedWorld is carring K-Factory hop up parts for the MTX4-R has anybody used them?
I hope this helps
wwwspeedworldraceway.com
hey thanks for the information
bobbyblaze is offline   Reply With Quote
Old 12-08-2007, 06:48 PM   #932
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
I hope this helps
Thats a good tip Billy is fast, so if it works for him, you know its good advice, I have yet to get bad advice from him on my cars
Thanks Billy
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 12-08-2007, 08:36 PM   #933
wallyedmonds's Avatar
Originally Posted by Scott Fisher View Post
Titanium 2 speed shaft is not a good idea. I have seen many that wear out wher the 1st gear one way bearing rides. Just like the guy above talked about.
i dont have that problem, maybe im doing something wrong
but really i think for most a steel rear shaft is best.
i do change my 1st and 2nd gear holders often.
the bearings get wobbly
wallyedmonds is offline   Reply With Quote
Old 12-08-2007, 08:58 PM   #934
nitro rat's Avatar
Trader Rating: 5 (86%+)
how long did it take you guys to build your mtx4 r?
Ive got one on its way
SMC BATTERIES
ALPHA ENGINES
TEAM DURANGO
nitro rat is offline   Reply With Quote
Old 12-08-2007, 09:23 PM   #935
well now i can do it in one night but when i did not know the car good about 3 nights
just take you time and have fun.
understand all the parts and how it gos together.
Old 12-08-2007, 11:41 PM   #936
YLLIB's Avatar
Sorry pushed the button twice...
YLLIB is offline   Reply With Quote
Old 12-08-2007, 11:41 PM   #937
YLLIB's Avatar
I hope this works for the guys that e-mailed me. Track SpeedWorld TESTED on both conditions - smooth, tight, high traction w/ VHT and clean no spray asphalt.
Front End:
198mm width
4mm ride height
2 deg camber angle
2mm upper arm spacer
.5 toe out
1mm rebound stop
no bump stop
use to138 steering blocks w/1mm spacer on steering arm
front sway bar flat
Rear End:
199mm wisth
5mm ride height
5 camber angle
1.5 toe angle
3mm rebound stop
no bump stop
lower arm position
2mm upright spacer
2.5 wire roll bar
3mm in on wire sway bar ball
0 wheel hub spacer
use to144 mounted on lower hole
Frt Shock
stock piston
600 mugen oil
springs light blue
middle postion shock mounted
Rear Shock
stock piston
600 mugen oil
springs light blue
3rd from the bottom shock mounted
Front - One way
Steering Ackerman -- A
Rear Diff -- 50,000
Tires 40 front and 40 rear ----- I use Jaco
Body - Protoform Stratus and stock wing
Good Luck Billy
Old 12-08-2007, 11:46 PM   #938
Front End:
198mm width
4mm ride height
2 deg camber angle
.5 toe out
1mm rebound stop
no bump stop
front sway bar flat
Rear End:
199mm wisth
5mm ride height
5 camber angle
1.5 toe angle
3mm rebound stop
no bump stop
lower arm position
2mm upright spacer
2.5 wire roll bar
0 wheel hub spacer
Frt Shock
stock piston
600 mugen oil
springs light blue
Rear Shock
stock piston
600 mugen oil
springs light blue
Front - One way
Rear Diff -- 50,000
Good Luck Billy
AKA
THE BOMB Awesome set up
Old 12-09-2007, 12:45 AM   #939
nitro rat's Avatar
people at my club are having trouble with 2nd gear blowing up....... any reasons why?
SMC BATTERIES
ALPHA ENGINES
TEAM DURANGO
Old 12-09-2007, 01:33 AM   #940
Slo-MTX4's Avatar
Send a message via ICQ to Slo-MTX4
Yep plenty......I will be up there in 2 weeks so if you get in contact with Braz or brett i can show you all
Podified Picco/MRX5/Futaba/Savox
PODIFIED ENGINES/Trackside RC
Slo-MTX4 is offline   Reply With Quote
Old 12-09-2007, 01:59 AM   #941
JetMD's Avatar
Wow, you must be rich! At $33 a pop, that's a huge waste of money. I ran the ones that came wih the car for a full season with no issues. And I plan on re-using them next year.
Any new guys out there reading this, I don't think i'd take this guy Wally's advice. Unless you're rich like he is.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 12-09-2007, 05:00 AM   #942
YLLIB's Avatar
Hello NitroRat, Buy the 4mm chassis and that will solve 99% of the gear problem. I had the same problem, I blew 16 gears in 3 weeks and never had a gear problen the first 3 times out with the car. I tried making sure the engine was square and read everything about how to fix the gear problem on the KB - MUGEN web site when it started and non of those ideas worked. the 3mm chassis does flex a ton sideways and foward to back in the engine area even with that brace. I then bought the 4 mm chassis and the problem was cured. I have gone through two gears since, but those were my fault being in a hurry and making sure the engine was not perfectly square,, which is very important I asked Mugen that I think that they should raise the price about $10 and just stick the 4mm chassis in the kit and problem solved. That is the ONLY problem with the intire car. I have talk, helped and watched a lot of racers go through gears and some racers not go through gears, but I feel that every driver is faster than some and the problem is in general is the more experience drivers are having the problem were the more newer racer is not. I don not know if the newer racer is on the throttle as much, harder or earlier and that is the difference. I am not in any means trying to separate driverís ability or say one person is better, itís just that I own an on-road track and I always am helping the racers at our track and that is what I have experienced. Also the gear problem has not started it seems for a few races until the chassis seems to get a little broke in, it sounds funny but maybe the chassis gets weak even since it is made from alum. after a 3 or so races. I have not seen a gear problems on the car when it has been new, only after a handful of races or less like I mentioned.
Old 12-09-2007, 06:16 AM   #943
just when they get wobbly,some last longer than others.
and why is it that i dont have a problem with a ti rear shaft like others do and come to think of it why dont i strip 2nd gears like alot of ppl do.
dose anyone oil there bearings in there gear holders.
the oneways dont last forever,there could be a prob and you dont even know it.
but dont take my advice,
but i do have a good peace of advice and that is dont live in the usa unless you are rich cuz if you get sick you will die.
have a nice day.
and yes get a 4mm chassis,the 3mm is just not good enough.
Old 12-09-2007, 06:51 AM   #944
JetMD's Avatar
have a nice day.
I get sick sometimes and i'm not dead nor am I rich like you. I merely wanted the noobies out there to realize your wealth of knowledge might not be accurate is all. And you bring up universal health care on a rc forum? usa vs. can.?
Once again, new racers out there, Listen Up! Wally has no clue what he's talking about. Do Not take his advice no matter what it is. That is all.
www.vorra.org
MINO Racing
Old 12-09-2007, 09:15 AM   #945
Registered User
yllib, Thanks for the advice, I have seen it at our local track also. I will buy one this week because gears are almost the price off the chassis at this time.
slot99 is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
