Old 11-12-2007, 07:19 AM   #796
asw7576's Avatar
Originally Posted by Nitrorea View Post
Hey guys new member here!!!
I am in the middle of building the MTX4-R (my first RC kit) and I may be haveing a bit of trouble with the front dogbones (universals).
They seem to be just a hair long and they are binding up the front a-arms. Now I know what you are thinking.....he is using the rear dogbones for the front application. Well this is not the case, I have double and tripple checked that I am using the correct ones.
Any ideas???
I also noticed that the manual I have and the manual I downloaded from the Mugen website differ with this topic. The manual I downloaded from the website uses the dogbones and the manual in the kit uses universal joints.
I guess the easy thing to do would be to grind them down a bit but I do not want to do this if I don't have to.
Is there something I am missing here?
Thanks for any and all help.
If you are 100% sure that you didn't mixed up the front and rear CVD bones, then you should check these area :
1. adjust the front track width, with tires on should be around 198mm, 199mm, or 200mm.
2. remove the 1mm plastic shim inserted between the outdrive and one way unit. Perhaps this is the easiest solution.
3. No binding in suspension arms. The arms should be able to fall under its own weight, ---> free movement up & down.
4. Rebuild the CVD and put oil in CVD joints. The CVD should be able to rotate smoothly even at 45 degree angle.
Old 11-12-2007, 08:22 AM   #797
evostyle's Avatar
Trader Rating: 102 (98%+)
NITROREA don't grind anything! Keep in mind your building an onroad car that rides 5mm above the ground. The suspension travel will be very limited and may seem to bind the CVD's at the full compression / up travel by hand. But once on the car with the proper track width and ride height set NOTHING will bind due to the short amount of suspension movement that's need to work properly. IF you set you car up with about 2 mm of droop and 5 mm of ride height the TOTAL suspension movement would be ABOUT 7mm maybe 8 mm while in use.
You should not need to grind anything away. Also if your using the CVD's you will NOT need any orings in the out drives. These are used to keep the dog bones centered within the inner and outer out drives. The CVD being "hard mounted" will not slide around.
Hope that helps.
evostyle is offline   Reply With Quote
Old 11-12-2007, 10:35 AM   #798
Default MTX-4 parts for sale
Brand new and cheap.
http://www.rctech.net/forum/showthread.php?t=190481
gonad is offline   Reply With Quote
Old 11-12-2007, 12:46 PM   #799
Nitrorea's Avatar
It wasn't so much the CVD's binding as it was the front uprights binding a bit. It seems they were hard to turn from side to side especially when they were closer to center. Now that I think about it I think I have the pivot balls screwed in to tight. I think if I screw those out a bit (not to increase track width over 200mm) things will work more freely. Where they are now the CVD or dogbone was tight against the drive cup coming off the front one way. So when you turned the uprights closer to being straight it was pushing the CVD against the back of the drive cup....if that makes sense.
Sorry for the grinding thing, it must have made some people cringe. It's just the mechanic in me....if it doesn't fit, make it!!!
Nitrorea is offline   Reply With Quote
Old 11-12-2007, 01:27 PM   #800
Hey guys have a brand new MTX4R built and ready to go with a few goodies.
Kind of an impulse buy and need a few dollars at this point for indoor offroad. For sale on the for sale forum. Price is negotiable in order to get this thing gone. Pm me if interested, pictures available on request via email. Thanks.
cwalters is offline   Reply With Quote
Old 11-13-2007, 08:07 AM   #801
ShrekNZ's Avatar
I would suggest if you are worried about the binding at the moment that you need to get at least a basic setup over the front end before checking for binding by getting some wheels on it and doing the camber by eye - set the track width to 199mm
Before checking binding you need to do 2 things loosen the rollbar off and move the front arms up and down to make sure you have enough clearance in bot halfs and set your droop as you will find this moves the arms up quite a bit and reduces the travel.
ShrekNZ is offline   Reply With Quote
Old 11-13-2007, 06:17 PM   #802
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Mugenville View Post
World Q works well, but if you can get your hands on the mugen one get it, Pro Shop Futaba carry these as well as your Kawahara gear you need, top ppl to deal with and at a very good price and they ship to Aust (EMS) get my gear in 3 days to the door
hey mugunville do you know how much a mugen starter is delivered to aus from pro shop?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 11-13-2007, 06:22 PM   #803
CraigM's Avatar
yep you nailed it. You cant screw the pivot ball screws all the way in with the universals or they bind. As others have said, your track will be too narrow if you do anyway
Old 11-17-2007, 03:49 PM   #804
kreamUNO's Avatar
weeee, i'm almost done with the mtx, all i need to do is the shocks and paint my parma m.
notice the one-piece engine mount from kyosho?
enjoy.
Mugen MTX-4R-NINJA MR12TUNED-NINJA FLS || Kyosho v-one RRR evo.2-SirioXXX-Sirio 2611
Kyosho Inferno WC-JAMMIN' JP3 || Kyosho M3-Sirio CL7R-Novarossi
XRAY T3'-Novak 13.5/tekinR1 || Serpent S120-RP x11 3.5
Tamiya IFS-Novak17.5/SPX || Tamiya TT-01-LRP x11 17.5
kreamUNO is offline   Reply With Quote
Old 11-17-2007, 05:45 PM   #805
Send a message via AIM to NitroNubee
WOW, that is a thing of beauty! Nice work!! Be sure to show us the body when you are done. I hope to show a couple off in a few months.
NitroNubee is offline   Reply With Quote
Old 11-17-2007, 09:06 PM   #806
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Hey guys... Im selling my backup car and my backup engines... Heres the link:
http://www.rctech.net/forum/showthread.php?p=3877297
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 11-18-2007, 09:18 AM   #807
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
hey guys i need some help.... i finish building my mtx4r and im having a hard time finding a mugen pipe and manifold..... please help with any info where i can order one ..... you can also pm me with info as well
blaze
bobbyblaze is offline   Reply With Quote
Old 11-18-2007, 10:29 AM   #808
Seisick's Avatar
blaze
you can have your lhs order from mugen racing just the shimo efra 2609 pipe along with the ninja long header, since the pipe/manifold is no longer available
happy racing
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 11-18-2007, 10:47 AM   #809
bobbyblaze's Avatar
thanks, i have one more question someone mention that ofna have a pipe as well ....stock #10066 .....how is that pipe
blaze
Old 11-18-2007, 11:04 AM   #810
Seisick's Avatar
blaze
that;s the x12 pipe, the mugen 2609 is better quality and performance! match it with any engine and tha's a winner, some consider the 2609 one of the best all around pipes
HobbymaniA
GoT MuGeN?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
