Old 10-24-2007, 11:24 PM   #721
CraigM's Avatar
Trader Rating: 34 (100%+)
hey juz most people use the 4mm chassis, but I'm using the 3mm one with the kawahara 1pc mount and CF stiffener and haven't stripped any
you going to offroad on sunday dude?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-24-2007, 11:25 PM   #722
CraigM's Avatar
oops forgot to mention the 2nd gear housings can also cause problems - make sure the bearing is properly seated before installing the engine by spinning 2nd and checking for wobble
Old 10-25-2007, 12:01 AM   #723
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
madjack is offline   Reply With Quote
Old 10-25-2007, 01:48 AM   #724
ViperSkull's Avatar
What brand 4mm chassis are you guys using? and which one is the best one to get?
BRCCC Wynnum
Mugen MTX4-R/Novarossi Max Power/Mugen Pipe/Futaba 3PK/Spektrum HRS System
*For Sale, CT4S with a heap of parts*
ViperSkull is offline   Reply With Quote
Old 10-25-2007, 02:16 AM   #725
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
kawahara nothing but the best
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 10-25-2007, 05:56 AM   #726
JetMD's Avatar
I have the 4mm chassis from 3 racing and it fixed my stripping problem. Also, mesh seems to be critical. What I usually do for that is i'll leave 2 eng. mount screws loose and then put the other 2 just to the point that they start to get tight. Then I push the motor over to where the gears are super tight together. Then i'l take off first gear spur and run a piece of paper between 2nd gear spur/pinion. It should open up just a hair. IF you see a big gap, that's too much, tighten the screws a little more and start over. Then i'll put the 1st gear spur back on, make sure it's still tight, then use the paper again on the 1st gear spur/pinion. I'll check the "feel" of the gap on both of them, then tighten up the eng. mount screws I left loose, then tighted the other 2. Hope that helps.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 10-25-2007, 06:17 AM   #727
Jetforce's Avatar
I found out what the problem was for me by stripping gears..
No 4mm chasis, no engine mount no nothing helped.. i saw that when engine perpendicular at chasis is it isnt nice fiting /gear-pinions. The engine has to be so that gears and pinions straight are! Not the engine.. Nothing else helped by me.. That is working like charm now! I didnt have it so and stripped a gear in 3 rounds (it was halfway stripped) then i corected it and from then i drove like 1.5 gallon, without fully stripping it.. So guys check it out if gears and pinions are nicely aligned..
Regards
Jetforce is offline   Reply With Quote
Old 10-25-2007, 08:25 AM   #728
typer's Avatar
Your right bro. Even the 3mm chassis is very stiff.
typer is offline   Reply With Quote
Old 10-25-2007, 08:31 AM   #729
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmm
my opinion i would never use 3racing anything for any car
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 10-25-2007, 05:48 PM   #730
xsxracing's Avatar
Trader Rating: 33 (100%+)
Send a message via Yahoo to xsxracing
Originally Posted by Novarossi View Post
Wow, I think this MTX-4R goes down as the longest build - 3 weeks
In all honesty, I have built a number of Mugens, Kyosho's, Xrays etc in the past, and I was suprised the amount of modifications I had to make to get things to work properly.
The 12-3SCT was also tricky because the carby rubber would bind with the top plate or side brace, so the old file and countersunk screws had to be used. The carb just clears the top plate by 1mm if less.
Then again, It could just be my old age
Look's really good(SEXY!)
MrDave3D
xsxracing is offline   Reply With Quote
Old 10-25-2007, 06:24 PM   #731
JetMD's Avatar
I mostly agree. A lot of 3 racing stuff is junk. In just a couple races I burned up the one way bearing in the front "multi-diff". Now it's just a solid and we'll see how long that lasts. The chassis is okay although with their one-piece motor mount, you'll have to grab a file to make it so that the clutch comes off easier. The titanium pillow balls and turn buckles haven't given me a problem yet either. But, like you, If you have the money, I wouldn't recommend them. If I had a lot of cash to drop on the car, i'd get the mugen/kawahara stuff for sure.
www.vorra.org
MINO Racing
Old 10-25-2007, 07:53 PM   #732
juzza99's Avatar
Thanks for the tips lads. Craig, yes i will be at liverpool sunday. I was just at the track this morning and the rain has helped out heaps. The dirt is now very tacky and there is heaps of grip. See you sunday.
juzza99 is offline   Reply With Quote
Old 10-26-2007, 02:14 AM   #733
Gseventeen's Avatar
Originally Posted by juzza99 View Post
Hi guys sorry about the newbie question but would anyone have suggestions as to why a mtx4 keeps stripping 2nd gear. I have checked the engine for movement but it is not moving and i have the play between the gears spot on. It last about 5mins then just strips the gear. Its got me beat. I did it 3 times on sunday.
Justin ,very important to keep ajusting 2 speed shoes, always large as poss ,without binding
Gseventeen is offline   Reply With Quote
Old 10-26-2007, 02:30 AM   #734
yeah, push the shoes out with the grub screw, and then keep an eye on the shift point as you may need to loosesn the other screws (the ones that us a 2mm hex wrench to adjust)
TomB is offline   Reply With Quote
Old 10-26-2007, 04:15 AM   #735
itchy b's Avatar
Wow,
Looks like this has become the Aussie MTX4r Thread
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
