Old 10-15-2007, 09:09 PM   #691
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by JayL View Post
nope
tamiya 415mre electric on-road
mugen mtx-4 nitro on-road
tamiya 501x off-road electric
Then you were then one that sat next to me with the buggy that one day right?
So you guys say run it stock, I will do that if I go through with nitro, I may buy more elec stuff, so we will see
Im pretty set on nitro though... Then I can race nitro one month, and then elec one month all at the same track
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 10-15-2007, 10:03 PM   #692
BOR:
We're having a club race/swap meet at SpeedWorld this coming Sunday. So if you get a chance, come check out the guys running the MTX-4R.
James "Nel" Nelson
SpeedWorld Raceway & Hobbies | DesotoRacing.com | R1 Wurks
neltime64 is offline   Reply With Quote
Old 10-15-2007, 10:36 PM   #693
Originally Posted by neltime64 View Post
BOR:
I am coming out
Racing fri, Another sat hang out with my buddy, and then back again for the swap meet
I have been to several races, and the mugen cup, so I have seen the races... But id like to meet some people
Old 10-17-2007, 08:51 AM   #694
Joe Tanto's Avatar
Default set up
hi here localy we have a track which is a bit bumpy and quite technical, with my MTX4 I am suffering of a bit of a loose end, I have put the shocks down on the inner last hole, still I have to try it since the weather its not nice at the moment. front diff is spool diff and rear is with 10,000 diff oil. If I remove the anti roll bar will it improve more? I gave it toe in aswell from the rear. the engine that I am using is IDM Picco 12.
Joe F
Xray T4 2014
Joe Tanto is offline   Reply With Quote
Old 10-17-2007, 08:58 AM   #695
YBSLOW's Avatar
Joe F
I am assuming you are loose on power exiting turns? try to loosen the clutch a little at a time and run a higher front droop value to allow more rear weight transfer. Rear toe should probably not be higher than 3 each side.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 10-17-2007, 11:56 AM   #696
Joe Tanto's Avatar
and what do you think about the anti roll bar, if I will remove it?
Joe F
Xray T4 2014
Old 10-17-2007, 12:17 PM   #697
YBSLOW's Avatar
you can take it off to get more roll in the rear, but I would first make sure your rear lower hinge pins are in the bottom hole.
YBSLOW Racing
Old 10-18-2007, 04:11 AM   #698
ViperSkull's Avatar
Hey guys, I'm using the solid axle and using diff oil in my rear diff (50,000 grade). Now my question is, would 50,000 grade diff oil be over powering the front solid axle?
BRCCC Wynnum
Mugen MTX4-R/Novarossi Max Power/Mugen Pipe/Futaba 3PK/Spektrum HRS System
*For Sale, CT4S with a heap of parts*
ViperSkull is offline   Reply With Quote
Old 10-18-2007, 04:45 AM   #699
Wynnum_Racer's Avatar
shouldn't be over powering a solid
http://www.youtube.com/watch?v=canY93sF15I
http://www.youtube.com/watch?v=NmxE9udKKdA
Everyone watch my movies on youtube
Wynnum_Racer is offline   Reply With Quote
Old 10-18-2007, 06:15 AM   #700
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Wow, I think this MTX-4R goes down as the longest build - 3 weeks
In all honesty, I have built a number of Mugens, Kyosho's, Xrays etc in the past, and I was suprised the amount of modifications I had to make to get things to work properly.
The 12-3SCT was also tricky because the carby rubber would bind with the top plate or side brace, so the old file and countersunk screws had to be used. The carb just clears the top plate by 1mm if less.
Then again, It could just be my old age
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 10-18-2007, 06:31 AM   #701
vikingen's Avatar
Trader Rating: 27 (100%+)
ran my first meet with my mtx4-r.. love it... despite losing a set screw and therefore drive to the rear wheels during the final and costing me a potential win (still came 2nd) ...must have forgotten the good old loctite on that set screw..
anyhoo.. does anyone know where I can find an RC SCREWZ kit for the MTX4-R ? (RCZMUG015) everywhere seems to be out of stock
vikingen is offline   Reply With Quote
Old 10-18-2007, 06:51 AM   #702
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Wow! 3 weeks??? Mine took like 3 days with me working on it about 6 hours a day... What kind of modifications have you had to make?
Riketsu is offline   Reply With Quote
Old 10-18-2007, 06:52 AM   #703
Riketsu's Avatar
Im looking for it too... My LHS says they have it in backorder... Lemme know if you happen to find it
Old 10-18-2007, 09:32 AM   #704
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I just logged onto Rcscrewz.com and while I did not buy the screw kit, I did get all the way to the payment part of the checkout procedure and it never told me the screw kit was backordered.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 10-18-2007, 11:55 AM   #705
Seisick's Avatar
Default run time
guys
regardless of what servo or receiver!
whick rx pack will provide longer runtime
a 4 or 5 cell, or the same runtime? considering they have the same capacity
and the fact that my servos will be slower and less torque
happy racing
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
