Old 10-15-2007, 01:34 AM   #676
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Originally Posted by wallyedmonds View Post
the ib cells suck for this.the cells die and the pack discharges to fast.you cant run an hour main.
gp right now i think are the best for a rx pack.
I've been running and IB reciever pack for almost a year. No problems. 1 Hour main is no problem either. Wally Wally Wally
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 10-15-2007, 02:31 AM   #677
Serpentd's Avatar
Originally Posted by Scott Fisher View Post
I've been running and IB reciever pack for almost a year. No problems. 1 Hour main is no problem either. Walley Walley Walley
Dude, forgive my ignorance, but what is "IB"? Is this the brand of battery cells? I have like Sanyo's and GP's, but never heard of IB. Just curious, thanks.
Blessed are the SIC
Serpentd is offline   Reply With Quote
Old 10-15-2007, 04:05 AM   #678
itchy b's Avatar
IB are the INTELLECT Brand of cell and I've also been using their 1400s
in my Mtx4 without issues.
I've been running digital servos for both steering and throttle along with a personal transponder for the whole raceday and final 20-30 minutes without charging during the day!
I charge them at 1.2 amps and only use 500-600mah for the whole day
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 10-15-2007, 04:06 AM   #679
itchy b's Avatar
Wally has done it again!!
Where's Wally?
EX1.5-SC10 4x4
Old 10-15-2007, 06:31 AM   #680
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Ill go even further... Before I sold my MTX-4 and changed to a S-car... I used to race IB packs... And ran a 30 minute main then a 45 minute main... Didnt have problems with it. What doesnt work for someone does not necessarily mean it wont work for the rest.
Riketsu is offline   Reply With Quote
Old 10-15-2007, 11:53 AM   #681
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by ShrekNZ View Post
Honestly IMHO you don't have to go overboard to prevent second gear stripping just set the mesh well don't run pinions that are worn as they will start eating pinions and ajdust the second gear clutch so it changes smoothly. I'd suggest you run the car for a while first.
Well its the some people that have problems, and then they say after the 4mm no issues... And since im new, IDK what to belive... Its just esier for me to go 4mm right away as I will be going gas for Xmas, so it would be better get it then, insted on the race season when I have hardly any money
Originally Posted by Car Breaker View Post
I have stock 3mm and 3racing 3mm chassis (yes, 3Racing). I have hit manythings like solid pole, wall and other cars in teh track. Never strip a single gear at all. Just learn to mesh it properly and you should be fine. btw the only thing I upgrade is skyline engine mount (stock don't fit my STS engine).
Hmmm.... What do the boards look like at your track? My boards have no give lol, its like hitting a brick wall when ever you hit the wall
Thats what I would think, im my revo a 1100 pack would run 2 steering servos, shifting servo, and throttle servo for well over a LOOOONG days bash..... Just I want to get it right the first time, not buy the thing, and then need a new one, because a RX pack is money that could be into fuel or whatever....
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 10-15-2007, 12:13 PM   #682
Riketsu's Avatar
About the 2nd gear... I'll shed some light. Before I made the mistake on selling my MTX-4... I had about 12 aluminum hopups incluiding aluminum monoblock, 4mm chassis and the aluminum brace. I thought this would prevent me from stripping 2nd gear. And maybe it helped, because I didnt strip em unless it was by my mistake. Right now im running a close to stock MTX-4, i mean, 3mm chassis, plastic brace (the arm that goes over the engine), and everything else plastic... And have only stripped 1 2nd gear and it was my fault because i only tighten 1 screw instead of all of them. My advice is this... Take off 2nd gear, mesh it... put 1st gear and it should roll freely still. Also... the clutch should be shimmed from the inside so it doesn't touch the clutch shoe... This prevents the clutch being overheated, restricts the travel of the clutch bell and will help in avoiding to strip gears.
Old 10-15-2007, 12:45 PM   #683
Hmm
Thanks for the info!
Old 10-15-2007, 01:24 PM   #684
JCB
JCB's Avatar
I've seen these cars perform at our local track and they run great... how long has this version been out for and what's the street price??
thanks,
JCB is offline   Reply With Quote
Old 10-15-2007, 01:46 PM   #685
Car Breaker's Avatar
the "tracK' I run is made of road dishes but the place is surrounded by solid concrete walls and 4 light ppole in the middle. I survive all the walls and poles. no gear strip. (hit them so many times though)
just mesh it properly, the method use by the other guy is similar to mine. too many alu part will alter the handling of the car. build it right is the best trick to get a top car (MTX, G4S, RRR, 720...) to run good. it will save you a fortune by not buying too many replacement parts and alu blings.
Car Breaker is offline   Reply With Quote
Old 10-15-2007, 03:30 PM   #686
wallyedmonds's Avatar
nobody here run those cells
they blow
most run lipo or gp thats it.
yours work's thats great.
we have found that the cells die just like the c cells do.
wallyedmonds is offline   Reply With Quote
Old 10-15-2007, 03:41 PM   #687
Originally Posted by BlackedOutREVO View Post
So
If I get the 4mm chassis
Do I need all those alu parts so the chassis wont flex? I dont want to have issues, the cost for the 4mm chassis is worth it not to have issues with 2nd gear
4mm chassis the upper deck brace and the rear pod brace.
you dont need ti screws light rear shaft front shaft and all that other stuff.
and ill say again ib cells suck for a rx pack but i run the c cells for 1/12 for the voltage but im thinking of getting ep cells for 1/12
you know the cells suck when a guy charges them at .8A and a cell vents.
Old 10-15-2007, 04:46 PM   #688
JayL's Avatar
bor: just come out stock. I have never stripped a gear at speedworld and since I got Bread set right he has not either. we will get your set right, clutch and 2-speed.
JayL is offline   Reply With Quote
Old 10-15-2007, 07:27 PM   #689
Well as I said, the first time buying crap is easier then during the race season
JayL, you run the xray??? I know I know who you are
Old 10-15-2007, 08:18 PM   #690
JayL's Avatar
nope
tamiya 415mre electric on-road
mugen mtx-4 nitro on-road
tamiya 501x off-road electric
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
