Old 10-06-2007, 07:12 PM   #601
YBSLOW's Avatar
Default lite-weight diff gears
O.K. so I was a little bored and wanted to make my MTX4R's drivetrain a bit lighter.
this saves almost 3 grams from the diff when all six gears are done. I will post a pic of the little gears later but here is a pic of the larger diff gears I did for 3 diffs.
Brad
www.YBslowInc.com
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 10-07-2007, 01:02 AM   #602
wallyedmonds's Avatar
nice.
i was just thinking (ya i know) can you cut them more on a angle to get more off.
wallyedmonds is offline   Reply With Quote
Old 10-07-2007, 09:03 PM   #603
Hey All,
got the front all built and I am starting the rear. I am missing 4, 3x6 screws for the gear/clutch setup. I will have to visit the LBS for these. Crap!
Question regarding the rear diff. How tight is it suppose to be when not installed? The diff does not turn with ease and I do have to place some effort into it. I can turn it with 2 fingers however is seems too tight. Is this normal?
Cheers!!
jj_spike is offline   Reply With Quote
Old 10-07-2007, 09:16 PM   #604
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
It depends on the grease that you used on the rear differential... And if its new, it will take some time for the gears to wear a bit off so they loosen up. Also, by turning the cups by hand is a bit hard... but when you do it through the dogbone/wheel its easier...
Riketsu is offline   Reply With Quote
Old 10-08-2007, 12:54 AM   #605
ShrekNZ's Avatar
Originally Posted by jj_spike View Post
Hey All,
Cheers!!
I guess you used the 10,000 oil that is supplied with the kit. It is quite stiff, acts like a limited slip and stops the inside wheel spinning up coming out of a corner.
ShrekNZ is offline   Reply With Quote
Old 10-08-2007, 01:13 AM   #606
try 50000 in the rear and see how stiff it is then
Old 10-08-2007, 02:05 AM   #607
asw7576's Avatar
I would not bother looking 3x6mm screws...... I would rather use 3x10mm screws for extra security.
And double the shim thickness ( to make the planetary gears even closer ).
Old 10-08-2007, 10:10 AM   #608
Actually, the 3x6 screws are for the 2-speed gears. I will pick up a screw set and a bunch of other small parts that I will need to keep the 4R running.
Cheers!
Old 10-08-2007, 11:46 AM   #609
asw7576's Avatar
Cheers!
Oh I see..... I thought you were talking about the gear diff's screws.
Old 10-08-2007, 12:21 PM   #610
Riketsu's Avatar
I'll be traveling on the end of october to Kissimmee (KRaceway)... Anyone here can shed some light on what basic setting should I use? Im more concerned on what diff grease should I bring with me and what pinions should i put on my car's clutch bell. Anyone have filled up a setup sheet that have raced here?
Old 10-08-2007, 06:48 PM   #611
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by wallyedmonds View Post
i dont remember but you can look it up
my parts are 3racing but i think kawahara or jp are better.
the sway is k factory
and i use the k factory rear shaft
and a ti front shaft.
both lightened
the motor screws are TM
Can I get some links to the places that sell this stuff?
I still want to run gas cars
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 10-08-2007, 10:54 PM   #612
CraigM's Avatar
Trader Rating: 34 (100%+)
rc-mushroom.com has all the 3 racing and k-factory stuff... actully i think rcmart.com has more k-factory. I get my kawahara from pro shop futaba mail order. mushroom also has the sato seiki stuff
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-08-2007, 11:20 PM   #613
I want the nice stuff, at the price of 3 racing, not a lot more to go to the nice brands.....
I will look, Thanks
Old 10-09-2007, 05:39 AM   #614
CraigM's Avatar
I will look, Thanks
if you want nice stuff, you dont want 3racing. You're better off getting a few kawahara bits than a whole car of 3racing
Old 10-09-2007, 06:17 AM   #615
never use k factory or 3 laling, it's shit... trust me.
Sato seiki aint to crash hot either, it might be a japanese name, but i think it is chinese manufactured.
TomB is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
