Old 10-04-2007, 09:50 PM   #586
Slo-MTX4's Avatar
Send a message via ICQ to Slo-MTX4
They fit so that if you remove the pins it turns back into a oneway diff instead of the locked diff that it is with the pins.
Daniel
Slo-MTX4 is offline   Reply With Quote
Old 10-04-2007, 09:56 PM   #587
Does anyone run it as a oneway diff?
Daniel
jj_spike is offline   Reply With Quote
Old 10-04-2007, 10:48 PM   #588
Slo-MTX4's Avatar
A couple of years ago they were what every one was using, but most people have gone back to geared diffs and lockers, purely for more consistancy, a oneway (most times) will give you a one off quicker lap and possibly quicker race time, but in longer races you cant beat the consistancy of a diff.
Old 10-04-2007, 11:54 PM   #589
chookgb's Avatar
Trader Rating: 26 (100%+)
the one way is better on tracks with sweeping corners and the diff and locked diff are better suited on tighter tracks
chookgb is offline   Reply With Quote
Old 10-06-2007, 04:16 AM   #590
itchy b's Avatar
So are you saying that the one way is the go for Mingara?
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 10-06-2007, 05:07 AM   #591
chookgb's Avatar
i prefer the one way at mingara and the lap times agree with me, i also tried both at lithgow with the one way coming out on top due to the majority of the corners being sweeping type turns,but on whalan and penrith the locker is the go as the corners are tight and quick changes of direction are required
Old 10-06-2007, 06:16 AM   #592
wallyedmonds's Avatar
well this is what iv seen
spool, open smooth high speed tracks
diff, short tight tracks or bumpy large tracks
1 way, any track you like but you can traction roll easier.
a diff is more consistent than a 1 way though you may get a good 1or 2 good laper with a 1 way.
never have driven on a track yet that a spool works so i have to go to the usa next summer.
but really its what ever you feel is right for you and what the best ave lap times you can get.
wallyedmonds is offline   Reply With Quote
Old 10-06-2007, 07:02 AM   #593
chookgb's Avatar
well yet again living up to your name wally, why comment on tracks that suit spools when you have written that you have not had a track that they work on, may i suggest if you are unsure it maybe better not to comment at all
Old 10-06-2007, 07:10 AM   #594
itchy b's Avatar
Onya Wally!
EX1.5-SC10 4x4
Old 10-06-2007, 07:55 AM   #595
its what ppl have said to me
and what has been said to me to run at such tracks.
the tracks i run at we use diffs,its the best overall way to run the car's.
Old 10-06-2007, 08:08 AM   #596
and yet again someone that dosent understands what im saying and bashes me
so funny
what i said was i ran a spool where others ran a spool and i found that a diff was better, so i have not run on a track where a spool is better yet RIGHT
you take what ppl say and you try things out and you do whats best for you to go as fast as you can and get the best lap times you can get.
Old 10-06-2007, 08:19 AM   #597
personal opinion;
the locker is easy to drive, and if you change your setup accordingly, you can get a very close, almost identical handling style of the oneway with a locker. you need more rear lift (ie droop screws wound out on rear) as well as the front. the oneway turns in smoother, and there is no "torque style" steering with a oneway that you get with a locker (ie that effect of the car turning into a corner and gripping then slipping, gripping and slipping that you get with a locker is not as evident with a oneway)
lockers also place alot of wear and tear on the front cvd's i found you really need to change the pins inside the cups of the cvd's every race meet to keep the entire cvd as tight as possible.
also i've run cvd's without grease and with grease. Grease them up, or else they wear out very quickly, but grease also requires you to clean and re apply the grease after every race day if you want to get the best life out of the cvd (along with changing the pin on the cup of the cvd).
for beginners, lockers are better, as droop setup is not as crucial. droop setup was one of the things i struggled the most with when i first started, and it is tricky to get your head around droop and it's effects on handling alot of the time when you are new to the hobby. with a locker you can run pritty much the droop screws wound all the way out with minimal effect to entry handling, yet with a oneway droop is vital to set properly to each track or else the car tails out entering a corner if there is too much rear lift.
TomB is offline   Reply With Quote
Old 10-06-2007, 11:36 AM   #598
quietstorm76's Avatar
Very good info TomB, thanks.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 10-06-2007, 02:39 PM   #599
Would anyone buy a used Teammagic G4S RTR?
NinjaRacer is offline   Reply With Quote
Old 10-06-2007, 06:30 PM   #600
Originally Posted by TomB View Post
personal opinion;
true
but if the track is bumpy a spool dose not work to good.
and i too grease my cvd's and it makes them last a lot longer.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
