Old 10-01-2007, 05:27 PM   #571
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by wallyedmonds View Post
with a ninja you wont have to mod or file anything.
just saying.
there also wont be rivalry between your chassis and engine
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-01-2007, 06:10 PM   #572
KoBe24's Avatar
Trader Rating: 26 (100%+)
Cool thanks craigm.
KoBe24 is offline   Reply With Quote
Old 10-03-2007, 08:04 AM   #573
Hey all,
I am just starting my MTX-4R build and the very first step is to use "rubber glue" to affix the break pads to the metal shoes. Is rubber cement the same as rubber glue? Is there a better choice? Will this hold-up under frequent breaking?
If anyone could provide other "gotchas" for the rest of my build, I would really appreciate it.
Cheers!!
JJ
jj_spike is offline   Reply With Quote
Old 10-03-2007, 08:33 AM   #574
Originally Posted by jj_spike View Post
Hey all,
Cheers!!
JJ
yes rubber glue, rubber cement, all the same thing, you can even use CA glue if you don't have anything else, although CA glue may eventually crack of.
things i do when building:
-if you like, sand edges of CF under water (to avoid breathing toxic dust) and then bead edges with a cotton tip and CA glue.
-make sure arms are free of binding.
-use a long screw instead of the grub screw on the rear hub. i also install a washer on the inside and outside screws of the camber links to avoid them poping out in a big crash. i installa small washer the diameter of the pivot nut before the washer though so that the ball end can move freely up without binding on the washer when the arm is fully compressed up. see picture
that's about it really.
TomB is offline   Reply With Quote
Old 10-03-2007, 10:16 AM   #575
Thanks for the tips! I am not 100% where all of these points are exactly however I should be able to figure it out when I get there.
Cheers!
Old 10-03-2007, 10:36 AM   #576
JetMD's Avatar
I wouldn't recommend sanding CF under water. Water and composites don't mix. If you plan on having the car for a long time (years), just buy one of those disposable masks and keep the water away.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 10-03-2007, 06:50 PM   #577
this is how all the electric guys have been doing it for ages, and anyone else who has sanded carbon fibre, it's the safest and best way. the glue's used are waterproof.
don't use a mask dude, the sh1t will go all over your skin and masks don't stop it unless you have a good one. do it underwater, just check the recommendations of the electric racers and you will see it's the best method, and the most commonly used.
i've used this method on electrics and nitro, never had an issue.
Old 10-03-2007, 07:08 PM   #578
wallyedmonds's Avatar
i dont sand at all
wallyedmonds is offline   Reply With Quote
Old 10-04-2007, 02:09 AM   #579
CraigM's Avatar
haha god damn you tom, I've been looking for gold washers to match my engine and servo horns but all i can find is bloody blue
Old 10-04-2007, 03:21 AM   #580
lol, i think kelletts actually have them dude! rc hobbies might as well...ive seen them somewhere don't remember where but...
Old 10-04-2007, 03:45 AM   #581
JetMD's Avatar
Well, I guess since you haven't had any cf fall apart yet, it must be okay. Those silly aircraft engineers must be worried about moisture getting into composites for no reason. I'll have to drop them an email to let them know they've been wrong the whole time.
Do what you want but if it were me, i'd get a mask and save the water for drinking.
www.vorra.org
MINO Racing
Old 10-04-2007, 03:57 AM   #582
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
I too have been using TomB's method for many years (beginning with the good old CF top deck for the RS4) to the MTX3, Xray T2, and now the 4R with never an issue.
I'd rather "risk" the possibility of CF splitting then breathing the stuff in (not to mention exposing two young kids to it)
Michael_T is offline   Reply With Quote
Old 10-04-2007, 02:11 PM   #583
Car Breaker's Avatar
I never send my CF part but I put multi layer of CA to seal up every cutting (cut off, screw holes, and outside edge) because I often wash it with detergent and water. i don't want them to split or the resin between each layer of CF to melt away (it might not happen but i rather be safe)
Car Breaker is offline   Reply With Quote
Old 10-04-2007, 07:49 PM   #584
I do not think carbon fibre and water are an issue. My road bicycle's frame, wheels and components are carbon fibre and it sees the rain quite often. Moisture should not affect the cured resin.
JJ
Old 10-04-2007, 07:54 PM   #585
I just built the front one-way tonight. I do not know what they are called off hand but they look like this --[ (the dog bones fit into them).
These parts fit into the one-way bearings and are locked into place via pins. If they are locked via the pins, why do they fit into the one-way bearings? They are unable to turn so why the bearings??? Am I missing something??
Thanks!
JJ
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
