Old 05-10-2012, 01:01 AM   #3886
rcabj's Avatar
Originally Posted by asw7576 View Post
My mtx4 is the first original version. I am planning to take it for spin on the next available race. It has been sleeping for sometime. Everything are still good and working nicely. I cant wait to race this animal.
Btw, what are people suggestions to make the rear tires more stable ? The car has tendency to spin 180 degree on L and U corner off throttle. Perhaps suggestion on how much downstop on hudy block? Thanks
if u haven't why not try out these> 30k fr and 30k rear diff..i've been using this setup the entire year (2-3 different track) with minor adjustment to other setup..and making good runs too..(the only mtx4r in most races)..in addition the only car with the biggest flywheel compare to others
below r setup that i rarely touch..
fr/rear diff oil 30k
front rol center add 1.5-2mm shim
rear rol centre mid
track width 199 fr..200 rear
camber front 1.5-2deg , toe out 1 -1.5mm
rear camber 3-4 deg , toe in 2.5-3 deg
i use similar shore tyres fr/rear
i always play with droop,ride height and anti roll bar too fine tune.
i usually start out with fr 1 and 4 rear droop..at the rear i like to use wire type 2.1mm
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 05-10-2012, 11:01 AM   #3887
asw7576's Avatar
rear rol centre mid
ok, thank you for the advice.
Old 05-26-2012, 01:55 PM   #3888
GREGORY!'s Avatar
can someone tell me the diameter of the mtx4 t0214 joint shaft?
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 05-27-2012, 12:12 AM   #3889
asw7576's Avatar
T0214
I dont have digital caliper, it is between 4.3mm - 4.4mm.
Old 06-04-2012, 07:59 PM   #3890
DRRC's Avatar
Trader Rating: 57 (98%+)
I just bought a sirio but did not know it was a short shaft and not sg
What part do I need so I can use it in a mtx4
Team Wife
Mugen Seiki Racing
Mugenracing.com
DRRC is offline   Reply With Quote
Old 06-04-2012, 10:33 PM   #3891
FREELANCE_RCer's Avatar
Trader Rating: 27 (100%+)
Default Team Solar Kyosho 3D Clutch nut
Centax clutches can be fitted on standard threaded crankshaft using this type of clutch nut.
But the problem is most engines comes with threaded crankshafts have side exhaust, and this would may never fit the MTX4.
FREELANCE_RCer is offline   Reply With Quote
Old 06-05-2012, 09:15 AM   #3892
DRRC's Avatar
thanks for the info will try this
Team Wife
Mugen Seiki Racing
Mugenracing.com
Old 06-05-2012, 10:33 AM   #3893
ShermanSim's Avatar
You need to come back and Run On Road again!
Serpent America, 977 KO Radio, Nova Rossi Engine, Kosmic Fuel
ShermanSim is offline   Reply With Quote
Old 06-05-2012, 07:12 PM   #3894
Will do Sherman, see you @ Airtronics GP.
Old 06-15-2012, 06:33 PM   #3895
DRRC's Avatar
This is too big it is for a .15
Would you know of a .12
Team Wife
Mugen Seiki Racing
Mugenracing.com
Old 06-16-2012, 09:50 AM   #3896
The thread size are the same on all .12, .15, .18, .21 and other big block engines (from surface to aircraft nitro engines) with threaded crankshafts.
And even the thread on sg type crankshaft are the same. They also fit the same size collet too (except small block picco engine).
Did you bought your engine new or used? Are the threaded crankshaft cut too short? Please post pic of your sirio engine.
Old 06-16-2012, 10:20 AM   #3897
DRRC's Avatar
Yup bought it used and did not know it had the short shaft
I bought the pilot you posted but it is for a .15 kyosho engine hence it is too big for the sirio shaft
I think this was used for a nitro TC3 or RC10
I still am looking for the right part I don't want to give up on this Sirio motor
Will try to post pics
Team Wife
Mugen Seiki Racing
Mugenracing.com
Old 06-28-2012, 09:15 AM   #3898
Outdated car, outdated engine, untested setup.
Ready to race the Airtronics GP.
Mugen MTX-4R-ebay-sale-081.jpg   Mugen MTX-4R-ebay-sale-083.jpg   Mugen MTX-4R-ebay-sale-085.jpg   Mugen MTX-4R-ebay-sale-086.jpg   Mugen MTX-4R-ebay-sale-087.jpg
Old 07-02-2012, 01:59 AM   #3899
djiewie's Avatar
This car is still a strong contender. I see you have already done the flexi things and the spurstripping solution. Car looks good with the lowered servo and all. Have fun.
I would remove the second exhaust spring though, it will transfer heat to the carb because they are touching. Better to put 2 short springs with a piece of metal wire in between maybe.
djiewie is offline   Reply With Quote
Old 07-03-2012, 01:52 AM   #3900
rcabj's Avatar
hi, what type of clutch system ur using here...certainly not the stock mtx4 clutch system.
btw..i still have faith in this car hehe
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
