Old 06-13-2011, 10:50 AM   #3871
asw7576's Avatar
Originally Posted by shanwright View Post
Hi Guys,
I'm putting a new mtx4r together and only got as far as the front end before i found problems.
When i put the front drive shaft in with the bearing eccentric backed right off the belt is really tight, so tight the bearings are clicking.... !!
I have checked everything i can think of.
i have tried new belts.
urethane and rubber.
i have even cut the tag of the eccentric so i can roll them right to the min to get the front diff closer to the drive shaft.
I have tried different chassis's ( i have a few spares)
i ended up putting a few washers under the rear screws of the drive shaft housing to tilt it forward and this is still quite tight.
is this a problem any one else has had ?
Steve H
have you use original front mugen belt for mtx4 ?
it is impossible to get trouble like in your situation with the correct mtx4's front belt.
also make sure the pulleys are the correct pulleys !! i guess its 24 and 16.... i dont remember perfectly.
Old 06-13-2011, 03:02 PM   #3872
Default Clutch Adjustment
Last week I had to replace the bearings in my clutch including the thrust bearing. The clutch is really tight now with almost now play in the clutch bell. I've tried adding shims but it doesn't seem to make any difference. Any idea why it would be so tight now? Before it seemed like there was too much play but I guess that was because the bearings were on their way out. How do I know when the clutch is adjusted correctly?
Thanks.
Delawareguy is offline   Reply With Quote
Old 06-13-2011, 03:37 PM   #3873
Thanks.
thats weird, you must of put something together backwards or something is not sitting properly... make sure you got the right size bearings too... most likley something is not sitting properly... if its really tight i dont see why you would be adding shims.. check your engine collet make sure its the one from engine company not mugen kit
Ghett0 is offline   Reply With Quote
Old 06-13-2011, 03:47 PM   #3874
Seisick's Avatar
Thanks.
download the nt1 setup book or the 733, both explain easily how to adjust the centax
and if you still have issues perhaps is something to do with the flywheel cone which is too large in that case you should some 3x5 extra shims to have enough gap!
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 06-13-2011, 05:00 PM   #3875
shanwright's Avatar
Trader Rating: 25 (100%+)
I worked out why my front belt was so tight.
I had picked up a pullie from my spares and it must have been for a different car it was just one tooth bigger it was 19 teeth not the standard 18 tooth.
it just didn't add up and i ahd no idea i have pullies from other cars... doh !
Thanks for the replies anyway...
shanwright is offline   Reply With Quote
Old 06-16-2011, 09:03 AM   #3876
Default question about rebound and droop stop
i notice that on mugen seiki sheet up sheet there is no mention of droop stop setting or is rebound stop and droop stop one of the same?
bigtee is offline   Reply With Quote
Old 06-17-2011, 08:01 AM   #3877
Seisick's Avatar
rebound is the same as downstop, droop is another adjustment,
HobbymaniA
GoT MuGeN?
Old 05-04-2012, 10:03 AM   #3878
spenzalii's Avatar
Send a message via AIM to spenzalii
After taking a 3 year sabbatical I figure I may try my hand at some nitro racing this year. My MTX4R has sat in the case all that time, so I've got to change all the belts and fluids, rebuild shocks, and double check to see what spare parts I still have or need. Sure hope I can remember everything on this car!
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 05-04-2012, 11:03 AM   #3879
asw7576's Avatar
My mtx4 is the first original version. I am planning to take it for spin on the next available race. It has been sleeping for sometime. Everything are still good and working nicely. I cant wait to race this animal.
Btw, what are people suggestions to make the rear tires more stable ? The car has tendency to spin 180 degree on L and U corner off throttle. Perhaps suggestion on how much downstop on hudy block? Thanks
Old 05-04-2012, 01:43 PM   #3880
CurveTracer's Avatar
After taking a 3 year "rest"!
Spenz,
Great you are returning to the game! Hurry up change the fluids, bring spare belts and get busy racing!
"Yellow Jacket" Mugen MTX-6, Picco Torque
TeamNITRO RC Club, Lynwood, Illinois
CurveTracer is offline   Reply With Quote
Old 05-04-2012, 01:52 PM   #3881
spenzalii's Avatar
Originally Posted by CurveTracer View Post
Spenz,
What's good CT? Yeah, I'm going to try to do a few races this year. Get my feet wet again. Hopefully I won't look TOO bad out there. Most of the spare parts should be in today, the new p/s/r for the plus 12 should be in next week. Then it's getting the new (to me) radio set up and hoping for the best.
I even dusted off the CD3 and gave it a little bit of love. How's that for a blast from the past....
Old 05-06-2012, 08:37 AM   #3882
spenzalii's Avatar
Hmmm. That's odd. Post up your setup and what shore tires you're working with.
Most of the parts came in on Friday. Replaced the 2 speed clutch, rebuilt the motor and changed the gears. Today or tomorrow it's on to the belts and the shocks. Then finding time to break in the motor.
Old 05-07-2012, 05:07 PM   #3883
kmh
whats up Spence. Most of the old 301 crew has been racing at Blue Diamond. The track has been renovated and is very nice. If you can make your way up to practice or maybe we will see you at the next club race. Ken H.
kmh is offline   Reply With Quote
Old 05-07-2012, 06:44 PM   #3884
this is so cool!
VentureXero is offline   Reply With Quote
Old 05-07-2012, 10:09 PM   #3885
spenzalii's Avatar
Ken! What's good bro! I'm planning on making my trip to DE next month. I'll do the initial shakedown/race/embarrass myself down in VA on the 20th, but already plan on trying to make it up to DE in June. Just tell the fellas don't laugh too much when I get there! Let me know when you plan on going to practice and I"ll see what I can do.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
