Old 05-13-2011, 03:37 PM   #3841
there the same thing
Capricorn LAB C-01 / RBtj 10 / Spectrum DX3
Roadrash730 is offline   Reply With Quote
Old 05-17-2011, 10:34 PM   #3842
rcabj's Avatar
Default diff & roll center for low traction setup
guys, need some infos for medium size and low traction track...
i have this on my mind for a start>
>diff oil = 30k fr , 20k rear
>front rol centre = 1.5 mm shim at front upper arm
>rear rol center = bottom hole at rear lower arm
thanks
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 05-18-2011, 06:50 AM   #3843
geeunit1014's Avatar
I would go a lot thicker on the front diff. If in fact your track is low traction, a spool would be better (It will make the car easier to drive). A diff, especially that thin, will give too much rotation in the middle of the corner, and not enough drive coming out. If you dont have a spool, go as thick on the oil as you can, say 200k-500k.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 05-19-2011, 01:07 AM   #3844
ABGDjr's Avatar
Default mtx5
aloooo guy went mtx5 coming out
in used
*MUGEN SEIKI MTX5*SANWA M11x*2xFUTABA S9451(s)S9350(t)*POWERED BY SIRIO NEMESIS TUNED
ABGDjr is offline   Reply With Quote
Old 05-19-2011, 03:36 AM   #3845
rcabj's Avatar
thanks...what about the roll centre
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 05-19-2011, 09:58 PM   #3846
Those roll centers should be okay.
Mike Gee
Old 05-20-2011, 02:55 AM   #3847
rcabj's Avatar
thanks
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 05-25-2011, 04:24 PM   #3848
I'm chewing up gears on MTX-4R. Specifically second gear. At first it looked like my throttle servo was pulling too much and causing a little flex in the chassis so I adjusted my EPA and that seemed to solve the problem. But now I've gone through two more in two days. My mesh looks good and I've had some other more experienced people look at it to make sure. So what would cause this to happen? First gear has been fine but second is only lasting a handful of laps.
Thanks for your help.
Delawareguy is offline   Reply With Quote
Old 05-25-2011, 07:35 PM   #3849
Trader Rating: 21 (100%+)
It can only be 2 or 3 things. Your gear mesh, cheap ass 3 racing gears, or check your engine mounting screws they might be loose. All that crap of the mtx4 stripping gears is bull $hit. I have ran the same gears for over 2 years and only strip gears when I screw the gear mesh up.
VA_Racer is offline   Reply With Quote
Old 05-26-2011, 08:51 AM   #3850
Seisick's Avatar
check previous page, if you still strip gears let me know
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 06-01-2011, 02:12 PM   #3851
No more stipped gears. Thanks for your help.
Does anyone know if this clutch adjusting tool will work with the MTX-4R? Or is there on that is specific to the 4R?http://www.amainhobbies.com/product_...Adjusting-Tool
Old 06-01-2011, 03:00 PM   #3852
CurveTracer's Avatar
I use this tool on my MTX4R, it works well.
"Yellow Jacket" Mugen MTX-6, Picco Torque
TeamNITRO RC Club, Lynwood, Illinois
CurveTracer is offline   Reply With Quote
Old 06-01-2011, 04:51 PM   #3853
Seisick's Avatar
[QUOTE=Delawareguy;9196426]No more stipped gears. Thanks for your help.
Does anyone know if this clutch adjusting tool will work with the MTX-4R? Or is there on that is specific to the 4R?http://www.amainhobbies.com/product_...Adjusting-Tool[/QUOTe
ive got it and also i have the serpent one which is plastic but costs less
HobbymaniA
GoT MuGeN?
Old 06-01-2011, 09:44 PM   #3854
rcabj's Avatar
hi, what was the problem and how you did you overcome the issue??
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 06-01-2011, 09:48 PM   #3855
rcabj's Avatar
just sharing my experience....3 races with this car, 3 different track, and i find using 30k diff at the front and rear suits me. felt neutral the car. and seting the rear roll centre in the middle works for me too...the lowest position make the car feel "too responsive" for me
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
