Old 01-21-2011, 02:27 PM   #3796
mugenize1's Avatar
I had the same problem with my MTX4-R and it was all stock with the O.S 12tz I had to add a shim under the engine, between the engine mount and the engine. the shim I used was the aluminum one that goes on the servos this worked well. Post a picture lets see the problem. Hope this helps
mugenize1 is offline   Reply With Quote
Old 01-24-2011, 01:27 AM   #3797
rcabj's Avatar
Originally Posted by FASRICK View Post
Try this out and let me know how you like it
Front Diff= 100,000 mugen diff oil
Rear Diff=50,000mugen diff oil
Droop= 2 front 4 rear
Shock Springs =light blue fr and rear
Shock Oil = front 700 rear=600
Track Width= front 198 rear 199
Roll Center= front 1mm spacer under upper arms: Rear= Low
Make sure your sway bar links are even and 2mm inward.
Shock position should be on the 2nd hole from the bottom.
For tires try this 40rear 37fronts. 60mm rear 58 front
Hope this gets you going in the right direction
thanks for the reply , but i didn't read this until today.
1st time racing with the mtx4r...previous was 733 and RRR. just wanted to feel the car again (i had a mtx3 few years back).
anyway i ended up copying more than 80% of fukuda's setup
well i was amaze..i believe it suits my driving style and the track condition & layout. i was in the 3rd position before my 1st gear spur strip 7 minutes towards the 45 min main...hard luck..i consider myself not a very fast driver. but i feel great coz the car&setup perform more than i expected( especially diving into the corners and exiting..still feel the sensation. i can also "attack" other cars with confident..
this is some of the setup ..
Front Diff= 30,000 diff oil
Rear Diff=30,000 diff oil
Droop= 0 front 4 rear
Shock Oil = front 600(one hole ) rear=600
Track Width= front 199 rear 200 ( i tried 198/199 , but i feel too aggressive)
Roll Center= front 2mm spacer under upper arms: Rear= mid
front sway blade 30 deg
rear sway blade flat
Shock position should be on the 2nd hole from the bottom. ( 2nd front, 3rd hole rear.
tyres>for the heats 37 front and rear
finals 61.5 mm(40 front) and 64.5 mm (42 rear) for the final
thanks...
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 01-27-2011, 10:23 AM   #3798
getpip's Avatar
Default Parts
Sadly my MTX4 is gone now..
I have put all my spares in a bundle on ebay if anyone is interested.
Cheers guys.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...STRK:MESELX:IT
Check out my blog: www.pipskiracing.blogspot.com
getpip is offline   Reply With Quote
Old 02-20-2011, 12:33 PM   #3799
just thought id share my car
mugen's are great
Ghett0 is offline   Reply With Quote
Old 02-21-2011, 01:04 AM   #3800
asw7576's Avatar
mugen's are great
Yepp, she is burly and beautiful.
Old 02-28-2011, 06:25 PM   #3801
Wynnum_Racer's Avatar
Just wanting to get an idea of what sorta diff oils people are using in the standard mugen diffs.
i have been racing on a low grip tight track.
i currently have 50 000 front 30 000 rear. But i found it would break loose on exit.
http://www.youtube.com/watch?v=canY93sF15I
http://www.youtube.com/watch?v=NmxE9udKKdA
Everyone watch my movies on youtube
Wynnum_Racer is offline   Reply With Quote
Old 02-28-2011, 06:30 PM   #3802
Trader Rating: 21 (100%+)
Try lowering the rear diff fluit to 10,000, also trying lowering the cg in the rear. Use the lowest pin position on the rear lower arms.
VA_Racer is offline   Reply With Quote
Old 02-28-2011, 08:02 PM   #3803
Francis M.'s Avatar
Add More Toe in initially, see if that helps. Going lighter on the rear diff fluid will also help....
Francis M. is offline   Reply With Quote
Old 02-28-2011, 10:52 PM   #3804
FASRICK's Avatar
Francis your car was on rails, you and Marco were both rolling
Mugen Seiki Racing U.S.A / O.S Engines / Flash Point Tires/ Protoform / Flash Point Fuel / G.L.A.R.C / Playing To Win
FASRICK is offline   Reply With Quote
Old 03-01-2011, 01:38 PM   #3805
GMartinez's Avatar
Trader Rating: 85 (100%+)
Default Superior Hobbies Clearance sale
best way is to call with your part# there are items marked up to 50% off on the MTX4R so far there are some odd ball items but I saw cvd's 1 chasis,gears arms www.superiorhobbies.com 1-407-834-9299
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 03-01-2011, 04:27 PM   #3806
Francis M.'s Avatar
Thanks, Marco's car was actually better.... You joining us at RCX right? MuUUgen in full effect...lol
Old 03-01-2011, 10:34 PM   #3807
blanks596's Avatar
Trader Rating: 14 (100%+)
ya, i'm curious as to what the hell you guys do to your cars - i'm getting faster but i'm still .5 seconds slower on average than you and marco
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 03-02-2011, 08:57 AM   #3808
Francis M.'s Avatar
I'm using a sirio clutch and I shortened the Front end of the car by 2mm... We have a pretty basic set up except for the clutch and the shortened front end...
Old 03-02-2011, 11:25 AM   #3809
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
So, you thinned the front A-arm. I have to try and run into a front corner to take you and Marco out.
See you at RCX. I will loctite my wheel nuts.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 03-02-2011, 12:45 PM   #3810
[QUOTE=Scott Fisher;8735517
See you at RCX. I will loctite my wheel nuts.[/QUOTE]
Make sure they are Mugen wheel nuts or you will run into the same problem again.
mrckymrk is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
