Old 11-15-2010, 09:16 AM   #3766
Trader Rating: 18 (100%+)
Default MTX4R
Originally Posted by lil-bump View Post
I've heard good things about Powermaster fuel. They also make all of Traxxas fuels. Just wish I could find some in my neck of the woods
You could call Sam at Kamikaze Toys and Hobbies and see what it would cost to ship a gallon to you location. Might be worth the shipping costs just to try it out.
I usually buy my fuel by the case, as it saves quite a bit of money.
Maybe Sam could tell you where to buy it closer to your home
[COLOR="Red"][FONT="Comic Sans MS"][/FONT][/COLOR]BRC358http://www.kamikazercracing.com
nearest barstool
brc358 is offline   Reply With Quote
Old 11-15-2010, 10:16 AM   #3767
asw7576's Avatar
Originally Posted by Bishop View Post
I put a brand new Mugen 4mm chassis on my MTX the other day, just fitted the engine today, and found the clutch bell now won't come off without removing the engine again, Mugen do some strange things.
You need to remove the upper brace, ( the plastic brace above the clutchbell ), before opening the clutchbell.
You could also put 3mm shims between the brace and bulkheads, so you dont have to remove the brace everytime you remove the clutchbell. However, you need to re-arrange the carburator throttle position. ( The linkage will hit the brace if you dont re-arrange the carburator throttle position ).
Old 11-15-2010, 10:58 AM   #3768
lil-bump's Avatar
Trader Rating: 83 (100%+)
I still don't think the clutchbell will clear the 4mm chassis. It's really hard if you have a new clutchbell with fresh bearings.There is no wobble
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 11-15-2010, 12:58 PM   #3769
mugenize1's Avatar
This is normal I dremeled mine also. There nothing wrong with the chassis; you just can't take the clutchbell off with the engine installed because of the added thickness of the chassis. You have a choice of dremeling the chassis or removing the engine everytime you want to remove the clutchbell.
Pass you soon...
ok I understand now the thicker chassis is the problem if I need to remove the bell got it thanks,
mugenize1 is offline   Reply With Quote
Old 11-15-2010, 01:01 PM   #3770
mugenize1's Avatar
Originally Posted by brc358 View Post
I have tried Byrons fuel also. Had no issues with it at all. I found that for me the Powermaster fuel seemed to run a little cooler, cleaner, but the run time was about the same with the Powemaster. Pretty much a toss up on the two.
I have also tried White Lighting, Mugen, and a couple other ones, but seemed to always go back to the Power Master. I have used this fuel for about 4 or 5 years now,and during tear down and rebuild, the piston, and internal parts were very clean. Just a matter of choice.
No power Master here where Im at. So I guess I'll stay with Byron it's not that bad.
Old 11-15-2010, 01:06 PM   #3771
mugenize1's Avatar
I still don't the clutchbell will clear the 4mm chassis. It's really hard if you have a new clutchbell with fresh bearings.There is no wobble
Pass you soon...
And I was going to buy the 4mm chassis I think I'll stay stock..
Old 11-15-2010, 02:48 PM   #3772
Seisick's Avatar
i use kawahara 4mm special chasis and did not need to dremel the chasis, but i use a
little wire to make sure to seat the 2 inner 5x8 bearings in once the clutch bell has been pulled, otherwise it wont let me take it out
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 11-16-2010, 02:20 PM   #3773
mugenize1's Avatar
I'll stay stock. No need for the 4mm chassis
Old 11-20-2010, 04:42 PM   #3774
mugenize1's Avatar
Default MTX4-R Pulleys
What will be the out come if I change the out side front pulley from 24T to
25T. Please help
Old 11-20-2010, 06:22 PM   #3775
s10dude's Avatar
a change in the final drive ratio of the front......
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 11-20-2010, 06:33 PM   #3776
Default MTX4R
25T. Please help
The car will have more power to the front wheels, due to the change in ratio.
Will change the handling of the car somewhat, as the front wheels will be pulling more
nearest barstool
Old 11-20-2010, 07:33 PM   #3777
mugenize1's Avatar
So stock is the way to stay.
Old 11-20-2010, 07:45 PM   #3778
Default MTX4R
I ran stock pullies in all my MTX4R, MTX4, and the MTX3
Dont waste your money on the aluminum pullies either. They seem to wear the belts out faster due to the sharp edges on the aluminum.
You can basically get the same results if you use a taller tire on the front.
I was running a 2 mm split . I started out with a 61mm on the rear, and a 59mm on the front. This was for a 45min, or 60 min. main
Some of the drivers were using a 1 mm split.
But to try out the difference in pullies, without actually changing the pullies, use set of tires that have already been run in.
Pick out a set where you can use a taller tire in front<either a 1 mm or 2 mm split. Of course with a 2mm split you will see more of a change in the front handling.
I dont know of anyone that runs a new set of tires without truing them first,so you may be able to borrow a set of used tires that already have the 1 to 2 mm split already cut to what you need.
nearest barstool
Old 11-20-2010, 08:18 PM   #3779
mugenize1's Avatar
Thanks for that I never knew that I will try that split the tires by 1 or 2 mm and about the aluminum pulleys I did not know they cut the belts. quess thats out the question. Thanks,
Old 11-21-2010, 06:07 AM   #3780
asw7576's Avatar
25T. Please help
Nope,
When you change to 25T pulley, the car will go under drive even more, ie. the rear wheels are rotating faster than front wheels. This is same effect when you run major split : small diameter front tires with big diameter rear tires. This is more like rear wheel drive type of car. The car turns smaller and (theoritically) get higher top speed at straight lane.
Do you ever feel mtx4 or mtx3 drive strangely after 20 minutes ? It feels horrible to drive, kind of push and pull within the car ? And between 30 minutes to finish, the car fbecome very tiring to drive because driver need to concentrate to drive even more smoothly ( drive slow ) ?
That's the sign of not enough underdrive.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
