Old 08-27-2007, 02:47 AM   #361
Default new car
Big smiles after finally upgrading from my mtx-3 prospecs. Taking out the final on it's first apperance has no doudt it a much better car esp steering wise.
My question: Is there a big difference changing the second pinion up 1 from standard (23) too 24 on big tracks? Don't think i'd play with first gear (17) but surely change 2nd gear pinions say: 22 smaller tracks
23 medium "
24 large tracks
Correct or not. Cheers.
rchopeless is offline   Reply With Quote
Old 08-27-2007, 03:57 AM   #362
johnypiston's Avatar
Default Clutch Bearings
After racing the RRR for the last year, I decided to move on and get the MTX4-R together with a couple of tasty hopups. The car is now assembled but something about the clutch is entirely different from what I experienced with the RRR. The two bearings on the inside of the clutch bell have such a tight fit on the crank, that setting the clutch gap by pulling and pushing the clutch bell has become an ABSOLUTE nightmare. I cannot possibly be doing anything wrong...I am using the correct bearings. Has anyone come across this before or is it just me?
If it is just me ...any suggestions on how I can ease the fit a little for the bearings?
johnypiston is offline   Reply With Quote
Old 08-27-2007, 05:00 AM   #363
Corse-R's Avatar
Is a brand new engine?, from time to time I find new engines with the crankshaft with a little too much diameter and they do a tight fit for the bearings. Bearings should enter on the crank without much hassle. Double check it.
The last time I found this, was a Nova with a defective crank who was exchanged without problems for a new crank.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 08-27-2007, 07:34 AM   #364
Jetforce's Avatar
Ive expierenced the same problem..
There was no problem with Picco and Ninja for that matter but there was a problem with nova engine..
Like the crankshaft is too big.I dont know for Novaplus 2 but by Plus 12-3SCT it stuck.
Jetforce is offline   Reply With Quote
Old 08-27-2007, 09:48 AM   #365
asw7576's Avatar
Polish the crankshaft tip with metal polish and put few drop of bearing oil.
Old 08-27-2007, 03:59 PM   #366
wallyedmonds's Avatar
23 medium "
24 large tracks
wallyedmonds is offline   Reply With Quote
Old 08-27-2007, 04:50 PM   #367
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Originally Posted by Tye View Post
I am stripping both spur gears, Not at the same time but they are both stripping. I feel that I am pretty good with setting gear mesh...maybe not. Any help would be appreciated. Thanks.
JUST AN OPINION check your 2speed 1way ,check for chassis flex,check the upper brace set the mesh by 2nd gear first but there are people that have a better idea of the problem then me also what chassis 3mm or 4mm good luck
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 08-29-2007, 02:14 AM   #368
Thanks guys. It is a Ninja MR12 TA01 engine ...which is surprising cause I thought the car was designed for it. I will try polishing and oiling the crank. Thanks.
Mugen Seiki MTX4-R | Ninja MR12 TA01 | Hitech| Kawahara Tyres
SAMWA M11
"Ah, but a man's reach should exceed his grasp, Or what's a heaven for?"
-Robert Browning
Old 08-29-2007, 02:25 AM   #369
Corse-R's Avatar
Doesn't matter if was a Ninja, Sirio, Nova or other brand of engines... from time to time, one crank goes a 0.001mm bigger (the last two that saw with that problem one had 0.003mm thicker and the other was 0.002mm of interference - so they didn't fit on the bearing) and those (and how small) are your problems fitting the crank bearings...
Talk with the LHS or distributor and ask for a replacement crank, don't try to force the bearing as you break them.
Cheers,
Corse-R
Old 08-29-2007, 04:35 AM   #370
va_connoisseur's Avatar
Send a message via Yahoo to va_connoisseur
Default steering rods and adjusting front toe
Is there an easy method to adjust the front toe? I can't find a pick small enough to get into that little hole in the steering rod.
va_connoisseur is offline   Reply With Quote
Old 08-29-2007, 04:40 AM   #371
PROVK's Avatar
Trader Rating: 14 (100%+)
Mod one of the little hex keys thats comes in the kit and presto
George V
Mugen Seiki
Max Power Engines GRP Tires Nitro X Fuels "Mugen Blend"
www.rrcsa.org.au
PROVK is offline   Reply With Quote
Old 08-31-2007, 04:40 AM   #372
Roger's Avatar
I just finished painting this body ( DNA 3 ) for my 4R. Gonna test this body tommorrow along with a little bling bling brass battery tray
Track to be tested on:
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 08-31-2007, 05:20 AM   #373
Looks like a really technical track. Nice paint job. Is the battery tray a custom piece you made or can I find it at my LHS?
Old 08-31-2007, 05:46 AM   #374
almost to technical
looks good for 1/12 mod though.
nice paint work on the body.
Old 08-31-2007, 10:45 AM   #375
JLock's Avatar
Originally Posted by wallyedmonds View Post
almost to technical
Nothing wrong with the track. Just slap a OS TG12 in the car you would be good to go. Don't needs tons of hp for that track, just driving skills.
JLock is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
