Old 11-04-2010, 08:04 AM   #3721
T-ROY22's Avatar
Aluminum pulleys don't have E-Clips.
How do you keep your pulleys on
T-ROY!
Mugen Seiki USA,Enneti Tyres, Murnan Modifieds, Airtronics USA
T-ROY22 is offline   Reply With Quote
Old 11-04-2010, 08:48 AM   #3722
mugenize1's Avatar
They have a set screw on them. Not an E-Clip.
Look at the back part that is where the set screw goes.
mugenize1 is offline   Reply With Quote
Old 11-04-2010, 11:24 AM   #3723
T-ROY22's Avatar
OK! I was refering to the stock looking aluminum pulley, not the one in the pic. And yes they both utilize a set screw to attach on to the shaft. The stock pullies use an e-clip to hold the gear on.
T-ROY!
Old 11-04-2010, 02:44 PM   #3724
mugenize1's Avatar
YEESSSSS LOL
Old 11-04-2010, 02:45 PM   #3725
mugenize1's Avatar
I am working on my car as I write here now. Any input on the build!!!!
Old 11-04-2010, 02:55 PM   #3726
geeunit1014's Avatar
Just typical things, make sure every suspension part moves freely, drivetrain is free, etc. When I replaced my brake pads, I put some small springs on the screws that hold them in (in between the pads) so that the pads dont drag on the rotor. Other than that its just getting the car dialed in to the track
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 11-04-2010, 03:35 PM   #3727
mugenize1's Avatar
Thanks so much you guys are pretty cool here.
Old 11-04-2010, 09:08 PM   #3728
T-ROY22's Avatar
mugenize1 Quote:
Yup- It's a Mugen thing!
T-ROY!
Old 11-05-2010, 09:49 PM   #3729
mugenize1's Avatar
Can someone tell me what kind of adhesive do I use on the pulley that goes on the front one-way axle, Also do I use the pins in the front what is the difference by locking the one-way or not? Also what glue do I use for the break pads assembly?
Old 11-05-2010, 10:12 PM   #3730
chippy's Avatar
For the pulleys just use CA (superglue)
For brake pads use a contact adhesive or i have used automotive silicone any thing that can handle a bit of heat.
The diff you are referring to is a multi diff It can be a one-way diff with out the pins ,only has drive when accelerating , both front wheels free wheel independently Off power braking is a lot harder need to brake in a straight line.
Pins inserted becomes a solid diff both wheels turn the same speed as other on and off power
chippy is offline   Reply With Quote
Old 11-05-2010, 10:43 PM   #3731
mugenize1's Avatar
So with the pins on them is better depends on the track your on correct?
Old 11-05-2010, 10:46 PM   #3732
mugenize1's Avatar
I never had to do this to my MRX-4X This locking Axle thing is new to me
Old 11-06-2010, 03:52 AM   #3733
getpip's Avatar
Dont glue the pulley on the front axle... you dont need to.
If you then swap to a diff you can use the pulley.
Check out my blog: www.pipskiracing.blogspot.com
getpip is offline   Reply With Quote
Old 11-06-2010, 07:30 AM   #3734
mugenize1's Avatar
So what you did with the lip that needs adhesive?
Old 11-06-2010, 09:43 AM   #3735
getpip's Avatar
I used to put a tiny drop of ca so that I could pop it off. (On reflection I was just being a little mean) Probably easiest just to get a spare pulley!
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
