Old 03-04-2010, 04:31 AM   #3541
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Originally Posted by OMAR PARIS View Post
good .... excuse me change the subject, but what is the serpent Transmicion of using for the MTX-4R? the 733 or 720? thank you ..
They are the same. Before the 720 changed, Serpent released a WC (wide contact) transmission which is the one Andy and JC are using on their car. Its the whole shaft with spurs and Serpent Centax.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 03-04-2010, 05:10 PM   #3542
JRGTR's Avatar
Send a message via MSN to JRGTR
mmm sound like some is looking every advantage point to start racing soon
MTX5/Novarossi engines!
Byron's Racing Fuels/Airtronics
Matrix tires
www.pitlanehobby.com
JRGTR is offline   Reply With Quote
Old 03-05-2010, 08:43 AM   #3543
kcrunchone's Avatar
I have had problems and would like to try and resolve this problem with actual Mugen parts. I have learned and observed from a few guys especially my pit partner how to make some decent power with the tranny but to be honest I often dial that power down( in throttle on the remote) so that I can actually finish the race without blowing the gear and or gears.
this sacrifice has cost races and positions down in races, If I can ASAP i am going to make trial projects if successful I will post specifics. If any one has made steps to correct the problem and would like to share by all means post it.
I am stocked up on parts and love the car and still feel with correction it can be better.
Rick Hill
"Failure Is Not An Option"
kcrunchone is offline   Reply With Quote
Old 03-05-2010, 09:25 AM   #3544
Seisick's Avatar
i saw swaugers car with a capricorn clutch on the winternats i believe or nationals!
fukuda on japan mentioned on his last nationals (which he won ahead of shimo) he used serpent clutch, dont know if stock or wc clutch!
tironi from italy runs sirio clutch but with 23t pulley!
so up to you, there are some rrr drivers over here that prefer sirio clutch
others, capricorn, even with rrr shimos edition!
up to you
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 03-05-2010, 10:03 AM   #3545
lil-bump's Avatar
Trader Rating: 83 (100%+)
up to you
Must of been the winternats. Swauger did not run 1/10 at the Nats in Toledo unless it was just there for show.
23t pulley???? Where was this used on the car????
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 03-05-2010, 01:27 PM   #3546
Riketsu's Avatar
Swauger's car was using Capricorn Clutch with Kyosho Pinions. I saw it in my hand and still don't know how he achieved it. A friend of mine tried it but wasn't able to get a good mesh, so good luck with that.
The Serpent Transmission has seen zero stripping issues. No matter how much power the engine puts out or the clutch handles, it isnt a problem.
Old 03-05-2010, 01:30 PM   #3547
Seisick's Avatar
side belt, so to use a 4mm split i believe! he told me so via some weeks ago while chatting!
HobbymaniA
GoT MuGeN?
Old 03-05-2010, 01:31 PM   #3548
Seisick's Avatar
side belt, so to use a 4mm split i believe! he told me so via fb some weeks ago while chatting!
HobbymaniA
GoT MuGeN?
Old 03-13-2010, 03:13 PM   #3549
Default Diff oil
Hi all
I need a little help to choose a front diff oil for my MTX4.
I allways used one-way in front with 30K rear diff oil, and the car is not bad. But i want to give front diff a chance.
What should i start with?
Thks in advance.
Luís Cortez
Luís Cortez is offline   Reply With Quote
Old 03-13-2010, 05:48 PM   #3550
lil-bump's Avatar
Originally Posted by Luís Cortez View Post
Hi all
Thks in advance.
Luís Cortez
50K should be a good starting point
Elliott Hart
Serpent America
Desoto Racing Team
Old 03-13-2010, 06:35 PM   #3551
rmdhawaii's Avatar
Below are some tips from the MTX-4 knowledge base. Based on the traction of the technical track I raced on, I ran 30K front (Kysho oil) and 10K rear (Kyosho oil) in my MTX-4 and the car was good to go. I could go full throttle 2/3 through the sweeper leading into the straight and the car would track like it was on rails!
Differential, Rear
Q: What diff oil do you use?
A (Tag): 30,000 is a good starting point but generally speaking if your car pushes try a bit heavier oil like 50,000, if you need more traction at the rear or if your car feels twitchy then go with 10,000.
A (THE DOCTOR): I usually run 30,000 in the rear diff, but that is to keep the rear inside wheel from diffing up so much on these untreated parking lot tracks. When we ran the take off rubber tires I ran 10,000 in the rear and 30,000 in the front but that is the only time that I ever ran a front diff.
A (kidDynomite): If you choose to go diff, 100k up front and 5-10k in the rear works pretty good too with no worries to the universals.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 03-13-2010, 08:16 PM   #3552
ira
ira's Avatar
Trader Rating: 18 (100%+)
Hi all
Thks in advance.
Luís Cortez
Start with 50 front and 50 rear.
RC AMERICA, XRAY, FUTABA, O.S. ENGINES, BYRON FUELS, SPEEDWORLD RACEWAY, HOBBICO, MATRIX TIRES...
ira is offline   Reply With Quote
Old 03-16-2010, 03:47 PM   #3553
Francis M.'s Avatar
50/50 front and rear....
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 03-16-2010, 05:25 PM   #3554
rmdhawaii's Avatar
What type of traction/bite is 50/50 diff oil good for? How long have you guys been running with equal oil front and rear? When you go up or down in weight, do you make it the same (i.e. 30/30, 10/10, etc...) or different?
Old 03-16-2010, 05:51 PM   #3555
Francis M.'s Avatar
I tried it either late last year or early this year...
50/50 on good traction and 30/30 on lower traction...
I've never tried 10/10... I'm guessing that the last alternative would be 30/10
The car turns in great with the 50/50 set up and it does not diff out like I thought it would.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
