Like Tree1Likes
Mugen MTX-4R
Old 11-12-2009, 09:58 AM
  #3376
xlamontx's Avatar
Trader Rating: 15 (100%+)
It's been a couple of years since the last time I bought Mugen parts but, NitroHouse had a good selection of MTX-4 parts in stock.
xlamontx is offline
Old 11-20-2009, 11:11 AM
  #3377
CanyonCarverR1's Avatar
Default Front diff
Well, I assembled a front diff but when I tried to install it, I found that it is too wide. It's as if the shoulder that the right bearings sits next to needs to be machined down so the bearing can move about 2mm towards the middle. Anybody got a better solution?
CanyonCarverR1 is offline
Old 11-20-2009, 11:36 AM
  #3378
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Default diff assembly
hey the same issue happened with me i did grind down the insert and i don't remember if you have to grind the bulkhead or not. i solved that problem by buying a KYOSHO good luck
Speedypeterb is offline
Old 11-20-2009, 11:55 AM
  #3379
For which Kyosho car did you buy one for? I was able to get mine to fit by machining ~2mm from where the right side bearing fits on the diff.
Old 11-20-2009, 03:24 PM
  #3380
Seisick's Avatar
are the eccentrics in the right position?
Seisick is offline
Old 11-20-2009, 04:26 PM
  #3381
Yep!
Old 11-20-2009, 07:44 PM
  #3382
Trader Rating: 21 (100%+)
Look at the manual real good. When you install the pully on the diff housing, you don't use the end piece that you glue on to the pully like you do if you use the oneway. A couple of us had the same issue till we finally figured it out.
VA_Racer is offline
Old 11-21-2009, 06:11 AM
  #3383
lil-bump's Avatar
Trader Rating: 89 (100%+)
+1
lil-bump is offline
Old 11-21-2009, 10:56 AM
  #3384
rai913's Avatar
Default diff cups
Does anyone know which diff cups to use and the part numbers for the washers for making a front diff? I was just trying to order the parts but came up with two different part numbers mugt0261 or mugt0277. The manuel says mugt0261 but i do have the original mtx4.
Ryan
rai913 is offline
Old 11-21-2009, 11:31 AM
  #3385
these are the diff cups to use for the front diff T0202
VA_Racer is offline
Old 11-21-2009, 01:22 PM
  #3386
lil-bump's Avatar
Ryan
Neither... You need to use The To-202. The washers come with the diff gears (C0-222a)
lil-bump is offline
Old 11-25-2009, 03:38 AM
  #3387
How many you guys planning switch away from mtx4 to the new car that coming out recently?
rranger is offline
Old 11-25-2009, 05:56 AM
  #3388
choisan's Avatar
no and never.
choisan is offline
Old 11-25-2009, 07:24 AM
  #3389
G87z's Avatar
What new car came out from Mugen recently?
G87z is offline
Old 11-25-2009, 03:12 PM
  #3390
lil-bump's Avatar
Ditto!!!!
lil-bump is offline
