Old 09-17-2009, 03:20 AM   #3301
stefan's Avatar
Send a message via AIM to stefan
Hey guys,
does anyone here know if the Xray NT1 clutchbell fits on the MTX4?
If so, will the Mugen pinions fit the Xray clutchbell?
Cheers.
stefan is offline   Reply With Quote
Old 09-17-2009, 05:40 PM   #3302
Seisick's Avatar
Originally Posted by stefan View Post
Hey guys,
Cheers.
i believe they're not since the rrr and the mtx4 are not compatible and the nt1 and the rrr are!
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 09-17-2009, 10:30 PM   #3303
stefan's Avatar
Thank you
Old 09-19-2009, 08:56 PM   #3304
Send a message via MSN to rat-400
Default need help new to this
hi all i just bought a mugen mtx4r putting nova 353 race and the stuff on it just wondering whats the best battery that i use on it going to be using digital servos i wan t something not to heavy thank you
rat-400 is offline   Reply With Quote
Old 09-19-2009, 09:33 PM   #3305
JRGTR's Avatar
Send a message via MSN to JRGTR
1600 battery is ok to the digital servos if you want to try a lipo 2200 is lighter but you need a voltage regulator to mantain your receiver and system working at 6.0 volts, benefit run all day without recharge! but handling a lipo could be risky, I use lipos without any problems(touching wood)
MTX5/Novarossi engines!
Byron's Racing Fuels/Airtronics
Matrix tires
www.pitlanehobby.com
JRGTR is offline   Reply With Quote
Old 09-20-2009, 05:35 PM   #3306
Trader Rating: 16 (100%+)
DOes anyone know if the xray 2-speed clutch set is compatible with the MTX4r. My clutch has worn and the local hobbyshop only has the NT1 2-speed clutch in stock.
panda_oz is offline   Reply With Quote
Old 09-20-2009, 05:53 PM   #3307
I am thinking about buying a MTX-4R but I am worried about the availability of spare parts since the model is a bit old and not so popular as an NT1 for example. So I would like to ask you if you think I would be able to find the spare parts I need even through the internet. I would also like to ask you what is the ready to run weight of a MTX-4R without any option parts. Do you think that this car is reliable? Because I have heard a lot about stripping gears etc...
Do you know if Mugen is about to release a new model next year?
panayos is offline   Reply With Quote
Old 09-20-2009, 06:33 PM   #3308
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
I am pretty sure something is cooking...
Having a car that not strips gears is like winning a lottery... Anyone can strip a gear when you least expect it.
Parts availability shouldnt be too hard. It would be easier to answer that question if you tell us where you are from.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 09-21-2009, 03:28 AM   #3309
I live in Greece and here the mtx is not very popular. That's why I am a bit worried about the spare parts. I want to be sure that even if I need the last small spacer of my car I will be able to find it (at least through the internet). I really hate it when you can't find what you need.
Old 09-21-2009, 04:37 AM   #3310
MTX4's parts is easily available on rcmart.com
denieru is offline   Reply With Quote
Old 09-21-2009, 07:54 AM   #3311
Send a message via MSN to Zacharopoulos
hey guys
i am also having problems with my 2nd gear!! I stip the 2nd gear spurs the one after the other.
Any suggestions??
Some of the things that wouldn't be the "fix" is
1. Gear mesh (always right)
2. New pinions
3. 2nd gear housing ball bearing
4. bulkheads and no overtighten screws
5. i also use 4mm chassis.
any suggestions??
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Zacharopoulos is offline   Reply With Quote
Old 09-21-2009, 09:06 AM   #3312
CurveTracer's Avatar
Default 2nd gear strip
I addressed the following items to solve my gear stripping problem, I also have a 4mm chassis.
1. Use the longest screws (12 + mm) that will fit in the holes for the rear bulkhead left and right parts. My car had 8mm screws and they would work themselves loose frequently. Once after I had stripped 2nd gear, I checked engine mount, screws bottom/top and "aluminum" side brace, all were tight. But the rear bulkhead screws were loose, when I tightened them up, the gear mesh tightened up to the orriginal setting.
2. Ensure that the rear engine mount screws are not too long and preventing the engine attachment screws from tightening up fully. I ended up shortening the rear engine mount (chassis side) screws by 1-2 mm.
Since I made these two changes, I have not stripped a spur gear in 8 race outings.
"Yellow Jacket" Mugen MTX-6, Picco Torque
TeamNITRO RC Club, Lynwood, Illinois
CurveTracer is offline   Reply With Quote
Old 09-21-2009, 10:58 AM   #3313
Francis M.'s Avatar
Originally Posted by Zacharopoulos View Post
hey guys
Any suggestions??
2. New pinions
any suggestions??
Check the bearings in the clutch bell and make sure the clutch bell is not hitting the 2nd gear housing...
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 09-21-2009, 11:36 AM   #3314
itchy b's Avatar
hey guys
Any suggestions??
2. New pinions
any suggestions??
How old is the 2 speed shaft?
I find that they need replacing after 12-18 months of racing before they
start to strip spurs!
Im on my 3rd one since 06!
I find that once it starts stripping, if everything else checks out, the shaft where the bearings run on are worn down enough to cause this!
Since i changed it a couple of months ago, im still using the same spurs i fitted then!
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 09-21-2009, 12:51 PM   #3315
allready changed!! thanks for the try!!
@ itchy!! i was after that , you may be right , and may this be my problem!! i will check it out!!
another question , does the 2 speed shoed have direction??
can anyone post a pic or tell me??
i noticed a "mistake" at the manual , that is why i am asking!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
