Old 08-20-2009, 05:18 AM   #3271
etgdpu's Avatar
Originally Posted by stefan View Post
The car has noticeably more steering and more over all grip. Look at the springs I am running for a smooth track....
No push anymore
Thank you very much for the excellent explanation.
Enjoy your vacation and especially the Saturday. I wish I were there.
The intelligent can become anyone, anyone can not become intelligent.
etgdpu is offline   Reply With Quote
Old 08-20-2009, 08:17 AM   #3272
NitroWD's Avatar
Default Final gear ratio
what's the final gear ratio with stock spurs 59/53 and stock 17/23 pinions?
also 59/53 with 18/24 pinions?
thanks...
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 08-20-2009, 08:37 AM   #3273
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
thanks...
Internal ratio of the car is 2.15
How you get that? Divide the Rear Diff between the Brake Pulley, meaning that 41T/19T = 2.157.
Now, Divide 59/17 = 3.47 and multiplied by our 2.157 (internal ratio) = 7.486
Now, take out your calculator and get your numbers...
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 08-20-2009, 09:46 AM   #3274
NitroWD's Avatar
thanks alot bro...
Old 08-20-2009, 08:46 PM   #3275
touringdriver's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Scott Fisher View Post
As the other guys have suggested, it is probably your 1st gear one-way bearing.... However I want to ask if you are running the stock steel 2sp shaft, or an aftermarket one made of titanium or aluminum? If is isn't steel, the shaft may wear in the spot that the 1st gear one-way rides and that will also cause the problem you describe.
the shaft looks to be fine. its the mtx4, and this winter i want to convert it to the r. will the mtx3 1st gear one way fit the mtx4? i have a complete mtx3 that hasn't been raced all summer. thanlks again guys for all your input.
Proudly Sponsored by: Mr. Crash Racing, RickyRacer lidz & Ebay..
Rock Chalk Jayhawks
2014 Subway Cup & Dee and Mees On-road Race Schedule:
http://www.rctech.net/forum/kansas-m...l#post11891510
touringdriver is offline   Reply With Quote
Old 08-20-2009, 08:50 PM   #3276
also on the one way, could i use mugen shock oil? or does in need to be thinner? like a 15 or 20 wt. shock oil.
Rock Chalk Jayhawks
Old 08-20-2009, 09:05 PM   #3277
Francis M.'s Avatar
I suggest using the Serptent one way oil or use AE diff lube/clear in color....
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 08-21-2009, 11:05 AM   #3278
JRGTR's Avatar
Send a message via MSN to JRGTR
also hudy sells a goog one way lube!
MTX5/Novarossi engines!
Byron's Racing Fuels/Airtronics
Matrix tires
www.pitlanehobby.com
JRGTR is offline   Reply With Quote
Old 08-21-2009, 12:13 PM   #3279
Riketsu's Avatar
Hey guys, I am selling a belt lot on eBay from all the belts I change before mains just to be safe.
Old 08-22-2009, 12:02 PM   #3280
JRGTR's Avatar
Ok guys, although I am on my way out the door to go on vacation, here are a few pics, which are unfortunately not that brilliant, sorry.
The holes in the radio plate are elongated side to side by about 3 mm on each side. To allo the radio plate to move sideways, you need to put a distance tube (see the brass piece inside the strut) that is a fraction longer than the radio plate is thick. This way you can crank down on the strut without locking the radio plate.
Now when everything works, the radio plate will be able to move side to side, but not back and forth.
Move your left side of the roll bar further out on the radio plate, so the strut has room to move.
The same thing is done on the other side, but because of the carb link it's hard to see.
Also, you have to counter sink the holes for you rear tank screws to get them level with the radio plate.
Hope this helps.
I am off to vacation now with a short stop in Lostallo on Saturday
Oh, btw, if you look closely, you can see the adjustment screw in my front one way. With this screw I can adjust my one way gradually from fully open to fully locked and anywhere in between.
can you post more info about the adjusting screw of the one way, here on PR one of the locals make this mod 2 years ago on a Kyosho one way and he told us that is Imposible to do it with only one screw
Thanks!
Matrix tires
Old 08-24-2009, 12:42 AM   #3281
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
hey guys, mugen fans - look i really keen to hear your thoughts on the front diff, is it worth going to gain quicker times and better steering and easier on front belts?
Also how many destroy the front plastic pulley near the steering ackerman?
I have done one in the last 3 meets, and is it any better to go alloy to prevent this prob.
I have been running a 2mm tire split and so far it looks still healthy but i am sure it will have same issues.
So front diff or not is the question and alloy gears on the rubber belts?
cheers
Frankie
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 08-24-2009, 01:59 AM   #3282
NitroWD's Avatar
Default spring rates
anyone got the spring rates (lbs/in) for the front and rear 1.7mm light blue and 1.8mm blue springs?
Old 08-24-2009, 03:11 AM   #3283
asw7576's Avatar
cheers
Frankie
got some foto ?
I think the diff unit in your car is vibrating.....
Old 08-24-2009, 05:25 AM   #3284
JRGTR's Avatar
Originally Posted by asw7576 View Post
got some foto ?
or maybe wrong pulley aligment cause it have about 1mm of play to tha left or right, also check the bearings or the plastic mount of the middle shaft
Matrix tires
Old 08-24-2009, 10:41 AM   #3285
JayL's Avatar
the round plastic eccentrics that the outdrive bearing fit into wear QUICK! I bet those are all sloppy worn
I am on my original front belt and pulley after 3 years of hard racing
The front diff with front arms slammed and short upper kawahara arms is the way...
JayL is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
