Old 08-01-2009, 07:26 PM   #3211
JRGTR's Avatar
Send a message via MSN to JRGTR
Originally Posted by Riketsu View Post
I just wouldnt recommend a picco engine for a new person. I would stick to OS or Novarossi.
The JP first line is a great engine to start with.
OS XZ stock can also be a very good option.
thats right, picco react diffrent depending on the climte , the setting for each race will change too much. on the other side nova base like rb,jp,max and also the novas and os are more friendly to tune
MTX5/Novarossi engines!
Byron's Racing Fuels/Airtronics
Matrix tires
www.pitlanehobby.com
JRGTR is offline   Reply With Quote
Old 08-01-2009, 10:04 PM   #3212
Thanks guys.. Ok it either the the 353/08 http://www.rcmart.com/catalog/rc-muf...n-p-29004.html or the O.S .12 xz http://cgi.ebay.com/New-O-S-Max-12-X...d=p3286.c0.m14with 1040 sethttp://cgi.ebay.com/NEW-O-S-T-1040SC...3286.m20.l1116
Opinions or gladly welcomed
Nupe05 is offline   Reply With Quote
Old 08-02-2009, 04:06 PM   #3213
JRGTR's Avatar
Originally Posted by Nupe05 View Post
for starting os xz with 1040 pipe and header, when some exp. adquired and need moore speed try novarossi 353 with a 2602 max power pipe , but if you want to know the dark side of the force try a max power xxl3 with 2602 pipe and you will know the true nature of the force
Matrix tires
Old 08-02-2009, 08:05 PM   #3214
me want the dark side lol..
Old 08-04-2009, 06:15 AM   #3215
StewartFan20's Avatar
Are there any MTX-4R drivers out there, that went to the GLC, willing to share their setup
Devil Dog Racing | HobbyTown USA (Kansas City,North) | Fastlane Raceway | Matrix Tires
Someday, I hope to be the man my dog thinks I am.
StewartFan20 is offline   Reply With Quote
Old 08-04-2009, 07:05 AM   #3216
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Yeah, and also what pinion/spurs were used? And how bout tire wear?
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 08-04-2009, 08:16 AM   #3217
Send a message via AIM to jeff whiting
My daughter and I raced the GLC. This was our first time to this track. Loran finished 5th in the B and I finished 7th. Our cars were good and Loran logged our whole setup. I will scan it in and post it here. I will say now that we used the kit gearing and with our NovaRossi 353 09's, this was just right. Tire wear for us in practice and Friday's quals was about 1.5mm for warm up and a five minute qual. Saturday's qual's we only saw about 1mm of tire wear and just a bit more on the left rear. We ran BSR 38 fronts and 42 rears. In the B main (only 20 minutes long) tire wear was pretty low and I miss read the track and should have started with a smaller tire. Our cars peaked too late. We started with 60.5 rears and 58 fronts. More later. It's a great track and the program ran smoothly.
Jeff
Thanks to our sponsors: Desoto Racing, Serpent, Ielasi Tuned, HobbyWing, Byron's Fuel, Matrix Tires, Protoform, Futaba, www.LEFComplex.com
jeff whiting is offline   Reply With Quote
Old 08-04-2009, 09:03 AM   #3218
lil-bump's Avatar
Trader Rating: 83 (100%+)
38f's and 42 r's are the ticket at toledo. If you like a little push you can use 40 fronts. I started the main with 57.5 front and 58.7 rears. I ran the c main only 15 minutes. Car came off at 56.2 fronts and 57.5 rears. My set-up could have been better. So I won't post it.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 08-04-2009, 11:17 AM   #3219
JRGTR's Avatar
YEAH!!!
If some one post some set-up sheets of GLC Toledo of MTX-4R that will be awsome!!! special to the new commers of Puerto Rico to The Nats
Matrix tires
Old 08-04-2009, 12:50 PM   #3220
Riketsu's Avatar
Can you please post it so we have an idea what to do to our cars? Also, if you think it could've been better, please note what would you have done to your car to improve the setting. Or atleast describe what you did not like about your car during the main.
Old 08-04-2009, 07:48 PM   #3221
Here is the setup we ran at this years GLC. The cars were good but there is more in them. I think a little more tire work and I would have liked to try 600 oil in the rear when the traction was up. Like I said earlier, I should have started us out on smaller tires and we should have pused harder at the start but that's the way it goes. Onto the Nats.
JEFF
Old 08-04-2009, 08:27 PM   #3222
lil-bump's Avatar
I ran 40 front and 42 rears for the main and during quals I ran the 38f and 42 r's; I ran harder fronts so I cut my tires lower to get the car in the sweet spot sooner during the main. I wanted my car to rotate better; I believe I ran too much rear toe (4 deg) I think I should have used 2.5 to 3 degrees(my rear end was super planted) I add some droop to the rear to get the car to dive more into the turn this worked; but only during moderate to fast corners. I wish I would have used the 138'b rather than the 164's I like the way the 138b's turn in. I had other problems also; my two speed springs wore out once I changed the springs this was fine. All in all my car was decent but it could have been alot faster. The two spots on the track you want to concour is the sweeper and coming onto the crosstown into the carousel. If your car is good in these two areas you will turn fast laps
Elliott Hart
Serpent America
Desoto Racing Team
Old 08-04-2009, 10:31 PM   #3223
Chemical X's Avatar
Trader Rating: 16 (100%+)
Anyone have a good baseline setup for Crystal Park?
Thanks,
Tom
Chemical X is offline   Reply With Quote
Old 08-04-2009, 11:26 PM   #3224
Team Kamikaze's Avatar
Thanks,
Tom
Tom,
Anybody that races in Crystal park will help you with a good baseline set up, so just come on down, you will be surprised how helpful the locals are, make sure you buy us Lunch okay? j/k or you can check with SOLOARTIST he is the founder and the "GURU" of MTC
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 08-05-2009, 12:18 AM   #3225
Chemical X's Avatar
Originally Posted by Team Kamikaze View Post
Tom,
Lunch? Don't you mean beer?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
