Old 05-31-2009, 05:36 PM   #3016
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Originally Posted by Seisick View Post
the collect from the kit works perfectly
if you know how to assembly properly the clutch should give you no problems
check the nt1 setup book to adjust the clutch
in the worst case, shims of 3x4.9 should do the trick
good luck
The colour of the collect i got with the kit was BLACk - correct? as other collects are GOLD, ill try to use the collect with the kit, but it just wont budge the flywheel any closer down....
I knew something wasnt right when i added way tooo many shims and still it locked up - technically the bolt on the last section should bottom out inside the crank shaft?
Will speak to a good mate that will assist in fixing the problem!
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 05-31-2009, 05:50 PM   #3017
Seisick's Avatar
yes, it is black
but on my tz the flywheel goes lower than your pic,
aldo the cap head screw should bottom out only if the spacer
is well adjusted, that is why i switched to a screw 2mm smaller in length.
good luck
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 05-31-2009, 06:35 PM   #3018
Trader Rating: 28 (100%+)
I have a brass collet that I use, I never used the mugen one.
It was probably for a ninja engine and maybe the crankshaft is a tiny bit longer.
This is the best article I've read on setup of a centax clutch. obviously its a serpent but its still worth a read.
http://www.serpent.com/news/10534/Bu...-Clutches.html
Ashley Cobb is offline   Reply With Quote
Old 05-31-2009, 09:24 PM   #3019
spenzalii's Avatar
Send a message via AIM to spenzalii
This may be a very silly question, but did you put the weights in the correct way? I couldn't tell from the pictures. I only ask because that's what I did the first time I tried to set up a centax clutch. I felt rather small afterward, but it never hurts to ask!
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 05-31-2009, 10:28 PM   #3020
weights? LOL i never placed any, am i supose to as the manual did not say to add weights!
I did notice there are a few grub screws left in my kit still..... how many weights do you all use one in each shoe?
Old 05-31-2009, 11:00 PM   #3021
I think he means the flywheel/clutch weights.
As for grub screws, I have actually drilled my weights out slighty, not added more weight.
Cheers
Old 05-31-2009, 11:37 PM   #3022
PROVK's Avatar
Trader Rating: 14 (100%+)
Frankie, shave a little of the back of the collet by sanding it on some emery cloth.
I had to do the same on my 1/8, had me stumped too for a while
George V
Mugen Seiki
Max Power Engines GRP Tires Nitro X Fuels "Mugen Blend"
www.rrcsa.org.au
PROVK is offline   Reply With Quote
Old 05-31-2009, 11:45 PM   #3023
okay i might try that but easy to just get a shorter collect off ROB! hehehehehe
Old 06-01-2009, 01:12 AM   #3024
MaDaGAS CAR's Avatar
Send a message via MSN to MaDaGAS CAR
yer frankie i did the same with my back then mega zx12 it works some butch but it works lol
btw i think the bug has biten
MuGeN powered by MAX POWER !!!!
MaDaGAS CAR is offline   Reply With Quote
Old 06-01-2009, 04:26 AM   #3025
asw7576's Avatar
What is the effect of cutting exhaust stinger short ?
I cut my exhaust stinger because long stinger often get bent.
Is it more rpm with shorter stinger ?
Old 06-01-2009, 11:14 AM   #3026
JayL's Avatar
super super crank down the flywheeel bolt, on my tz with the stock collet I had to break out the BIG car tools ratchet and crank hard then boom the flywheel seated fully on the collet and I had room to shim.
JayL is offline   Reply With Quote
Old 06-01-2009, 06:16 PM   #3027
Ill give it a try tonight..... i am sure it just a bit more man power needed
Old 06-01-2009, 06:58 PM   #3028
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Dude... Just remove some shims before the bearings and it wont lock up after you have tightened the screw...
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 06-01-2009, 07:10 PM   #3029
PROVK's Avatar
What happens when it locks up with no shims installed?
George V
Mugen Seiki
www.rrcsa.org.au
Old 06-01-2009, 07:22 PM   #3030
jgreen's Avatar
go back 12 post and click on the link.
great info!
mugen MTX4R,DM1 Spec X 2
jgreen is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
