Old 05-15-2009, 08:08 AM   #2956
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
the trick to the stripping of 2nd spurs is to buy the steel pinions, the club leader at our club in South Australia is leading with top 3 MTX-4R following his top one position!
The Key is and his success is to run steel pinions, since the change never again did he strip a gear!
I hope this tip helps for you all!
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 05-15-2009, 08:18 AM   #2957
lil-bump's Avatar
Trader Rating: 83 (100%+)
Originally Posted by spenzalii View Post
I'm running 18/24 on the pinion and 59/53 on the spur with my Ninja. I believe a few JPs run something similar.
Thanks for the info. I'm running a Nova 3sct. I was going to start with 18/24 on the pinion and 60/54 on the spur. But your advise gives me a starting point. thanks again.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 05-15-2009, 11:11 AM   #2958
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
thanks for the good info guys, i will go with 24
Originally Posted by jgreen View Post
if you use the 24 tooth you need a 2mm split on your tires
rear 60mm front 58mm.
if you use the 25 tooth its even 1 to 1 front to rear but i think
the tire wear is more!
Tag is offline   Reply With Quote
Old 05-15-2009, 03:25 PM   #2959
gentleman81's Avatar
Originally Posted by Tag View Post
hi all, i am in the process of rebuilding my mtx-4 ( not the R ) , gave it a good clean and replaced needed plastic parts , anyways, i noticed the new pully set i bought comes with 24 T and 25 T side pullys, it has been a while since the car was build i forgot which pully i should use ? what's the differecen btw 24 compared with 25 Ts ?
thanks for the help
isnt there a performance difference too?
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 05-16-2009, 09:46 PM   #2960
Yus Rossi's Avatar
Red face Option Parts
hi,
Im from Kuala Lumpur Malaysia and hoping you could suggest any shop in Australia sell option parts for MTX4R. I gues its cheaper there...
Yus Rossi is offline   Reply With Quote
Old 05-16-2009, 10:53 PM   #2961
Trader Rating: 28 (100%+)
Hey mate,
I think the smaller toothed pully on the side gives you front overdrive
http://www.mugenseiki.com/mtx4-overdriveratio.pdf
Btw with the gears I stopped stripping them because a mate notices I had too much gap between the 2 speed shoe and the housing, it was engaging too hard.
Ashley Cobb is offline   Reply With Quote
Old 05-17-2009, 03:51 AM   #2962
Hey All Mugen Friends,
Well after some hard thinking and options in the selection between what 1/10th car kit i was gonna buy i ended going for the Mugen MTX-4R as most of my club mates run the car kit and seem to do very well.
My option did range from:
Serpent 720 2009
Kyosho V-One RRR Evo 2
NT1
Mugen MTX-4R....
Well i bought the car from www.amainhobbies.com and its on its way, finally i can start thinking of building and get back into racing.
Not going to ask for any tips as i think its best to read through the forum and talk to my club boys for there setup.
Look forward in sharing some news, tips and racing photos and videos with you all in the near future!
Regards
Frankie
Old 05-17-2009, 04:05 AM   #2963
Uga
Uga's Avatar
Kodak Hodak, you have made a good choice, welcome to the club
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 05-17-2009, 06:31 AM   #2964
SuperstarBG's Avatar
sorry gent i've been working a lot lately and not been on the pc. yes there is a performance difference with the 25 tooth side pulley. i found if gives it more front bite. i like it much better than the 24. i use a millimeter and 1/2 front to rear tire split.
as for taking the 2 spider gears and the bar out of the diff i was talking to art carbonell at the starting of this last forgass season about how much smaller they kyosho and xray diffs. thats when he told me that he had taken that out of his diff and that it made the car much smoother all the way around, especially under hard braking.
Team Shepherd USA, Novarossi, Byrons fuel, Airtronics, Mico Racing and EDS Tools.
SuperstarBG is offline   Reply With Quote
Old 05-17-2009, 08:41 AM   #2965
Trader Rating: 21 (100%+)
So basically you are talking about taking the top bar and the two gears out of the diff? And if you are running a front diff can you do it there also?
VA_Racer is offline   Reply With Quote
Old 05-17-2009, 08:52 AM   #2966
lil-bump's Avatar
I have not tried it, but plan on it You'll have to go with thicker diff fluid to achieve the same diff action. Also make sure your diff is shim properly with only two spyder gears you could strip the diff under hard acceleration
Elliott Hart
Serpent America
Desoto Racing Team
Old 05-17-2009, 02:21 PM   #2967
yes you can with both. just add a little more diff fluid
Old 05-17-2009, 02:25 PM   #2968
Originally Posted by lil-bump View Post
I have not tried it, but plan on it You'll have to go with thicker diff fluid to achieve the same diff action. Also make sure your diff is shim properly with only two spyder gears you could strip the diff under hard accellaration
try it lil bump, i got a Max XXL 3 and can yank the trigger with the best of them havent stripped one yet
Old 05-17-2009, 02:36 PM   #2969
lil-bump's Avatar
OH I will!!!!
Elliott Hart
Serpent America
Desoto Racing Team
Old 05-17-2009, 02:40 PM   #2970
Trader Rating: 18 (100%+)
Default Mugen MTX4R
I have had my Mugen for a couple of years now, and upgraded it to the
MTX4R, and have had countless engine,pipe combos in it, and I bet I can count on one hand how many spur gears I have stripped.
If the chassis plate is tweaked, gear mesh off,bent layshaft, any number of things can cause you to strip spur gears.
I also have a couple of Kyosho RRRs, and one of the spur gears stripped every time I ran it. I found the bearings in the lay shaft gritty, and the lay shaft itself slightly bent. This was well over a year ago, and even now, the Mugen and both RRRs have not stripped gears in over a year, and I run all three cars every weekend.
Check your bearings, shafts, engine alignment, radio plate.
There must be something you have over looked, or not thought of checking.
[COLOR="Red"][FONT="Comic Sans MS"][/FONT][/COLOR]BRC358http://www.kamikazercracing.com
nearest barstool
brc358 is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
