Old 04-15-2009, 07:53 AM   #2866
ntc3freak's Avatar
Hey guys! I finally received my kit after a month of waiting
Anyway,what is the stock set-up in regards to the shock oil? And is it just me or does the kit not come with any shock oil?
ntc3freak is offline   Reply With Quote
Old 04-15-2009, 09:11 AM   #2867
lil-bump's Avatar
Trader Rating: 83 (100%+)
Standard shock oil is 600 weight. Yes it comes with this oil plus 10000 wht diff oil
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 04-15-2009, 12:09 PM   #2868
gentleman81's Avatar
yea small bottles, look for them, they should be there
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 04-15-2009, 02:58 PM   #2869
ntc3freak's Avatar
Oh so that's what the bottle is for
There was no indication in the manual to use that one so I had no idea what to do with it
Anyway,at the front do u guys prefer to use One-way or Spool? And is the stock rear diff oil okay to start with? Or is it too thin?
Old 04-15-2009, 03:01 PM   #2870
use the spool you
will love it
infernoman2008 is offline   Reply With Quote
Old 04-15-2009, 03:24 PM   #2871
Francis M.'s Avatar
I almost always use 30,000 rear diff and 50,000 once in a while.....
I also like using the spool over the oneway especially since my local track changed to a more technical infield... You might also consider a front diff, I use a 50/50 mix of 500,000 and 100,000 for the front diff....
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 04-15-2009, 09:52 PM   #2872
Big Midget's Avatar
Trader Rating: 100 (100%+)
Nice Mugen MTX-4 For Sale:
http://www.rctech.net/forum/r-c-item...ml#post5690554
UltralineHobbies.com
Ultraline Raceway Topeka Ks
Dee & Mee Hobbies RickyRacer Lidz,Absolute Tattoo,Fuzzy Dice Decals
Big Midget is offline   Reply With Quote
Old 04-16-2009, 07:14 AM   #2873
Taffyjnr5's Avatar
Trader Rating: 32 (100%+)
I have only ever used 100K in the front diff what does the thicker front diff oil do?.................
Sworkz EVOII LE/Hobbywing/Protek
Roche Rapid F1/Hobbywing/LRP
Taffyjnr5 is offline   Reply With Quote
Old 04-16-2009, 08:12 AM   #2874
Francis M.'s Avatar
It puts the power down a little better.... It also stays a little more consistent in longer mains or hot weather....
Old 04-16-2009, 10:36 AM   #2875
JayL's Avatar
makes it closer to a spool...
JayL is offline   Reply With Quote
Old 04-16-2009, 07:02 PM   #2876
tony montana's Avatar
Trader Rating: 66 (100%+)
use the spool, it is dialed in the car
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 04-17-2009, 04:30 AM   #2877
ntc3freak's Avatar
Hey guys,I have a question for u guys. What are the steps u use to remove n reassemble the front axle (be it spool,diff,or one way) from n into the car?
Here's my steps :
1) Remove both the upper arm holder.
2) Remove the upper bulkhead with the shocktower (disconnected the schocks beforehand)
3) Remove the upper deck!
Now,I'm new with the car,but surely this isn't how it's meant to be? It took me nearly 5 minutes just to take out the spool! I didn't think I'd need to remove the upper deck,but the belt was so tight on the spool that I had to remove the upper deck n then it was possible to free the spool from the belt.
And putting it on was the same! I tried with the upper deck on,but it seems that the belt was so tight it would've taken massive amount of force to force it in. So again I had to remove the upper deck,then align the spool's pulley with the belt,then pull it towards the bulkhead and consequently tightening the belt tension.
So is this how everyone does it? Or am I just doing something wrong or am missing something?
Old 04-17-2009, 04:54 AM   #2878
JetMD's Avatar
When dealing with the spool, if you pull the pins out like you were making it a one-way, you can pull the diff cups out, and then pull the spool out of the top. When you're dealing with the front diff, you have to pull the upper deck up to get it in, obviously, because it's much bigger. I usually just take out the screws in the front of the deck, 4 I think, and that give you just enough slack to get the diff in and out. And, since you can't pull the diff cups out of the diff, it does require more disassembly of the front-end.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 04-17-2009, 05:21 AM   #2879
Trader Rating: 28 (100%+)
Re- removing front axle, I undo the 4 screws out of the front idler axle housing and the front battery tray screw, gives you the slack on the belt to get it out.
Also I've found you just need to undo the front 2 top deck screws and the steering post screw, and loosen the back 2 to get the axle/diff out. You don't need to completely remove the top deck.
Ashley Cobb is offline   Reply With Quote
Old 04-19-2009, 06:13 PM   #2880
i have a question what diff weight should i use in the rear diff ? also what would 50k diff fluid do in the rear diff. thanks
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
