Old 03-26-2009, 09:30 AM   #2851
spenzalii's Avatar
Send a message via AIM to spenzalii
Originally Posted by abul View Post
hi racers...i need to ask tips for my mtx4r to make it more "faster and stable" hahaha...any tips from the pros?
1: regarding belt tension? - does it make any diff on my driving when i set for too loose or too tight? front/ side/ rear...
2: do i really need to go for lipo batt instead of nimh (weight issue)?
3: on the sharp corner track, do u prefer to use diff or spool/solid on the front?
4: last but not least...any tips to make your car faster on corner? (because base on what my "GURU" said "overtake them on corners" because you normally have more corners than a straight lines...
thanx...
I'm far from a pro, but I can suggest a few things:
1. Belts. Try to find a happy medium. Too loose and they may skip and wear the teeth down. Too tight and you create excess drag. I like to run them just this side of loose (start the front and rear in the stock loose setting and adjust as they wear in).
2. Lipo. You'll get 50 different answers on this one. If weight is a concern, you could probably offset the difference with a brass battery pack and lead weights. More troubling would be making sure your electronics and voltage regulator can handle it. As I said, you'll get plenty of people saying why or why not to run lipos, so I'm not even going there...
3. Most of the people at my track are running the spool up front, and don't seem to have a problem cornering. You could also try a diff with 100k oil up front, as some have had success there. Not sure how many people are still running the one way.
4. Practice practice and practice...
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 04-03-2009, 07:09 AM   #2852
abul's Avatar
hello again!
anyone can help me using the 1/10 setup tools?....what i need to do first before i put the car on that setup tools?...ride height first?...with new tire?...droop first?...others?....if somebody can list down the steps for me ....
abul is offline   Reply With Quote
Old 04-03-2009, 01:39 PM   #2853
gentleman81's Avatar
send me ur email i have it in word form, u dont need to use the values that are in my document. but follow the steps in the order and then u input your own values. get a starting point from someone at ur track
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 04-04-2009, 11:09 AM   #2854
go to team xray web site they have how to set up a car
infernoman2008 is offline   Reply With Quote
Old 04-06-2009, 05:00 AM   #2855
Taffyjnr5's Avatar
Trader Rating: 32 (100%+)
I also use the NT-1 setup booklet and find it quite usefull........
Sworkz EVOII LE/Hobbywing/Protek
Roche Rapid F1/Hobbywing/LRP
Taffyjnr5 is offline   Reply With Quote
Old 04-06-2009, 01:53 PM   #2856
Francis M.'s Avatar
hello again!
1) Set track width with race tires
2) Set ride height
3) Set camber
4) Set toe
5) Set droop
6) Recheck Track width....
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 04-06-2009, 02:23 PM   #2857
rcrevolution's Avatar
Send a message via AIM to rcrevolution
are the rumors around a mtx5 just rumors or will we see a new kit this year?
rcrevolution is offline   Reply With Quote
Old 04-07-2009, 05:17 AM   #2858
abul's Avatar
Default thanx a lot
thanx a lot to all mugen "drivers" that willing to help me...
wi sh i can fine tune my car silky smooth....yeah..thanx again
Old 04-07-2009, 05:17 AM   #2859
abul's Avatar
Default thanx a lot
wish i can fine tune my car silky smooth....yeah..thanx again
Old 04-12-2009, 09:40 AM   #2860
what is the setting for the clutch gap and spring tenion thanks
Old 04-12-2009, 10:53 AM   #2861
Francis M.'s Avatar
Just use the thrust bearing shield to set the clutch gap...
Start with 9.6 spring tension with MSR spring and adjust for feel.....
Old 04-12-2009, 07:26 PM   #2862
JRGTR's Avatar
Send a message via MSN to JRGTR
Yeahhh!!! Good topic!!!
MTX5/Novarossi engines!
Byron's Racing Fuels/Airtronics
Matrix tires
www.pitlanehobby.com
JRGTR is offline   Reply With Quote
Old 04-12-2009, 09:55 PM   #2863
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
hello again!
The steps to set up are
1)Down stop
2)Track width
3)Ride height
4)Camber
5)Caster
6)Toe
7)Tweak
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 04-13-2009, 07:04 PM   #2864
87stanggt's Avatar
can some one tell me part numbers for newer style spur gears???
>GQ Racing Products
>Blue Diamond
>Team Deceptaconz!
87stanggt is offline   Reply With Quote
Old 04-13-2009, 07:12 PM   #2865
Francis M.'s Avatar
T0279-T0281 1st gear 58-60
T0282-T0284 2nd gear 52-54
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
