Old 03-11-2009, 07:52 PM   #2806
Arahawak's Avatar
Trader Rating: 32 (100%+)
Originally Posted by 808bgdog View Post
Howzit people, has anyone had any problems with mounting a crf josh cyrul edition in their car. The carb is hitting my brake disc, I tried to move the carb around and there are other issues with the positions. If anyone has a solution or fix can you share...Aloha
Try shimming your engine mounts.
If you do not want to shim, move the carb till it does not hit the brake disc. I am guessing if you do that, you cannnot fully open because the other end of the throttle will hit you top deck or fuel tank right? In that case, you might want to shave parts of the top deck.
I did that when i was trying out the RB Matrix. The engine is low on CG!
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 03-11-2009, 07:53 PM   #2807
Arahawak's Avatar
Originally Posted by staikosn1 View Post
The NT1 has an ubelievable rolling pushing only with the hand....Can that happene with the mtx4???
Mine rolls smoothly!! w/o creamic bearings.
Old 03-11-2009, 09:45 PM   #2808
JetMD's Avatar
When properly cared for, most cars will roll easily. I took the bearings out of my old mtx4, pulled the seals out, cleaned the grease out of the bearings, lubed them with oil, and re-installed. I also used wd-40 to soften my belts which helped alot but i've been told that armour all works better because it doesn't shorten the life of the belts. I'm going to try that this year.
After doing all that, a very experienced racer was helping me with my car and asked if I had ceramic bearings in it. I told him no and he said that he thought it rolled better than a car with ceramics.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 03-11-2009, 10:12 PM   #2809
gentleman81's Avatar
yo let me drop of my bearings with u, i tried cleaning one last year and i mangled the seal
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 03-11-2009, 10:41 PM   #2810
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
just bought me a mtx4r guys... should i put ceramic bearings in it? also anything i need to know about the car? im so excited about racing onroad.. also where is the best place to buy parts at for the mugen and to get tires and buy motors for these cars? Also what would be a good engine to buy? i thought about a os tz anything wrong with that motor?
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 03-11-2009, 10:56 PM   #2811
Francis M.'s Avatar
If you don't have a lhs... Go with an online shop such as Kamikaze Hobbies and Ashford Hobbies.
Ceramics is not necessary but it is definitely a worth it upgrade......
As for motors I suggest the JP firstline or JL racing.....Just make sure you buy the matching pipe for the motors...
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 03-11-2009, 11:12 PM   #2812
Thanks guys I'll try to cut out the top deck.....
808bgdog is offline   Reply With Quote
Old 03-11-2009, 11:58 PM   #2813
Arahawak's Avatar
The rubber belts are soft enough and rolls fine and smooth.
If you are using the utheren (bad spelling), armour all is a good fix.
Old 03-13-2009, 12:12 AM   #2814
JetMD's Avatar
You need to use an x-acto knife to get the seal out. Just be careful if you break the tip off, make sure you get the piece out. Other than that, it just takes time and patience.
www.vorra.org
MINO Racing
Old 03-13-2009, 01:27 AM   #2815
staikosn1's Avatar
Send a message via MSN to staikosn1
What I have to do to the car for better coasting??
XRAY NT1 || RB T10 RC || FUTABA BLS || SANWA M11 ||
#FANATIX MODELS# #www.frt.gr#
staikosn1 is offline   Reply With Quote
Old 03-13-2009, 01:42 AM   #2816
NiTrO BoOsTeR's Avatar
read what has been typed above its all there.
Serpent 733 - RB T10rc - Ko Helios EX-10
Serpent 733 - Novarossi 3SCT Tuned
============== SERPENT the only way ============
==== Pro Buggy Rc, Pitsworth - for all my RC needs =====
NiTrO BoOsTeR is offline   Reply With Quote
Old 03-14-2009, 02:17 PM   #2817
along with what is above, adjust your brakes so they dont drag, unless that is what you want. some people use drag brake.
Old 03-14-2009, 02:26 PM   #2818
what did u use to clean the bearings? and what oil did u put back in them?
i have some tri-flo...?
Old 03-14-2009, 05:20 PM   #2819
ViperSkull's Avatar
Default Lipo flat pack
Hey guys, I'm in the need for a new receiver battery for my car. I'm not too sure what battery i'm supposed to get and i was also thinking of making it a lipo. Any help??
Cheers,
Tim
BRCCC Wynnum
Mugen MTX4-R/Novarossi Max Power/Mugen Pipe/Futaba 3PK/Spektrum HRS System
*For Sale, CT4S with a heap of parts*
ViperSkull is offline   Reply With Quote
Old 03-14-2009, 05:57 PM   #2820
lil-bump's Avatar
Trader Rating: 83 (100%+)
I clean my bearings with brake cleaner and the RPM bearing blaster. I re-lube them with Boca lightening lube. great stuff...
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
