Old 03-06-2009, 11:10 AM   #2791
Seisick's Avatar
Originally Posted by CL View Post
Does anyone know where I get get a one piece solid spool that is not made from aluminum? I just think the one-way/spool that came with the MTX4R is too heavy. I know that Kyosho made one for their sedan.
UHMM, A FRIEND OF MINE, USES MTX4RS SPOOL ON HIS RRR,
I WILL ASK HIM IF HE CAN USES HIS RRR ONE WAY ON HIS MTX4
IF THAT IS THE CASE, THEN YOU CAN PURCHASE RRR ONE PIECE SPOOL
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 03-06-2009, 11:41 AM   #2792
touringdriver's Avatar
Trader Rating: 15 (100%+)
does anyone know if a mtx3 front spool will fit in a mtx4?
Proudly Sponsored by: Mr. Crash Racing, RickyRacer lidz & Ebay..
Rock Chalk Jayhawks
2014 Subway Cup & Dee and Mees On-road Race Schedule:
http://www.rctech.net/forum/kansas-m...l#post11891510
touringdriver is offline   Reply With Quote
Old 03-06-2009, 05:56 PM   #2793
NiTrO BoOsTeR's Avatar
i got a quick question, are the Alloy parts that 3Racing make lighter than stock plastic.
Serpent 733 - RB T10rc - Ko Helios EX-10
Serpent 733 - Novarossi 3SCT Tuned
============== SERPENT the only way ============
==== Pro Buggy Rc, Pitsworth - for all my RC needs =====
NiTrO BoOsTeR is offline   Reply With Quote
Old 03-06-2009, 10:32 PM   #2794
asw7576's Avatar
I don't think so.
Alumunium parts are always heavier than original plastic parts.
Btw, if you insist to slim down, you can shave some weights by using : titanium screws, lipo batts, titanium pivot balls, and 3mm chassis.
Old 03-06-2009, 10:36 PM   #2795
asw7576's Avatar
No, the length is different. MTX3 use wider front spool, and I think the number of teeth are different too.
Old 03-07-2009, 01:11 AM   #2796
I was just checking, because im planning on lightning it up and im getting the ti plilow balls, and all that so i was just checking another way to lighten it up.
Mitchell
Old 03-07-2009, 12:15 PM   #2797
staikosn1's Avatar
Send a message via MSN to staikosn1
I dont have a Hudy or other set up station,and i want to play with the camber,toe etc,how can i do that?
XRAY NT1 || RB T10 RC || FUTABA BLS || SANWA M11 ||
#FANATIX MODELS# #www.frt.gr#
staikosn1 is offline   Reply With Quote
Old 03-07-2009, 11:59 PM   #2798
gentleman81's Avatar
its gonna be hard to be accurate, if you want to be serious and know what settings are doing what, invest in one. you can buy a cheap camber gauge that will just rest on the tires in relation to the ground. to try and eyeball toe with a ruler is for the birds, plus you will want to get a droop and ride height gauge also. the ride height will effect your camber adjustments
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 03-08-2009, 01:12 AM   #2799
stefan's Avatar
Send a message via AIM to stefan
Originally Posted by staikosn1 View Post
how can i do that?
By buying a setup system!
If you have the funds to run JP engines, you should be able to afford a setup system.
The fastest engine won't do you any good if your car is not adjusted correctly.
stefan is offline   Reply With Quote
Old 03-08-2009, 03:06 AM   #2800
staikosn1's Avatar
Thats for sure....
Old 03-10-2009, 11:55 PM   #2801
Default problem with cyrul crf in mtx4r
Howzit people, has anyone had any problems with mounting a crf josh cyrul edition in their car. The carb is hitting my brake disc, I tried to move the carb around and there are other issues with the positions. If anyone has a solution or fix can you share...Aloha
808bgdog is offline   Reply With Quote
Old 03-11-2009, 02:46 PM   #2802
i dont have that motor but in the past when i had issues i rotated the carb until it hit the upper deck, and dremeled out a knoch, now i can drop in any motor. it isnt as bad as it sounds
Old 03-11-2009, 02:59 PM   #2803
staikosn1's Avatar
The NT1 has an ubelievable rolling pushing only with the hand....Can that happene with the mtx4???
Old 03-11-2009, 04:00 PM   #2804
do u mean the car coasts well when pushed?
xrays have always had good fit and finish.
i believe the mtx will do it, but the belts are a bit tight when new
Old 03-11-2009, 04:31 PM   #2805
Trader Rating: 21 (100%+)
If that is what you mean, mine coast just fine.
VA_Racer is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
