Old 02-25-2009, 12:25 PM   #2731
getpip's Avatar
Originally Posted by Francis M. View Post
Titanium Pivot Balls..... I think that alone should get you close to your goal.
This doesnt save as much as you'd think ... i just did it and saved only about 25gms.... it does however come off the right places as unsprung weight.
IMO the best way to save this much weight is by using a lipo rx battery ... (and regulator) however this comes off in the wrong place .. low and in the middle .... I did it anyway!
Check out my blog: www.pipskiracing.blogspot.com
getpip is offline   Reply With Quote
Old 02-25-2009, 12:32 PM   #2732
Francis M.'s Avatar
This is where I cut weight.....
1) TI pivot balls
2) TI screw set A / ti screws everywhere except under the chasis
Ybslow also makes TI two speed shaft and a Light weight midshaft...
If you guys want to spend the extra $$$ you can get ceramic bearings...
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 02-25-2009, 12:37 PM   #2733
getpip's Avatar
Originally Posted by ViperSkull View Post
Hey Guys,
I have a really bad and unknown problem going on with my car. Every single race i do i strip both 1st and 2nd gear. I have tried many things to fix this problem but nothing has worked. I have put brand new bearings in my engine. put brand new bearings in my clutch bell, have made sure my engine is square and meshed properly(done this many times), changed my EPA so that it doesn't pull the engine under throttle and brake, checked the bearing in the 2 speed housing, redone my clutch setup and made sure i had little end play, only 0.4mm. I have pretty much done everything i think. I just had a race meeting on sunday and i stripped 5 spur gears. What could be the problem? Maybe the clutch bell is warped??
Thanks,
Tim
Most of what has already been said seems good advice ...
In addition I suggest getting yourself a one peice engine mount... I use the Yeah racing part and have never stripped a gear.
Old 02-25-2009, 12:44 PM   #2734
lil-bump's Avatar
Trader Rating: 83 (100%+)
Originally Posted by NiTrO BoOsTeR View Post
hey guys, i need to drop about 80-100 grams on my MTX4-r its about 1850 and i need it to be just a bit more than 1725 and was wondering what is the best way to do it.
Mitchell
The TI screws on the top only saves a nice chunk of weight 15-20g's
Also take a look at your body If you have an elaborate paint scheme with a ton of paint. For example an unpainted and trimmed Protoform 3.1 Mazda weighs in at about 107g's. I once had a painted body that weighed 160 grams.
I normally weigh my car without the body and shoot for a weight of 1625 gr.
then I place the body on and recheck the weight. I try to keep my painted bodies under 120 gm's
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 02-25-2009, 03:46 PM   #2735
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
I missed your drive, I was watching the 8th scales going around the track....
See you at CP this weekend?
you should, have some crap to deal with
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 02-25-2009, 03:59 PM   #2736
Francis M.'s Avatar
I'll see at CP...
Old 02-25-2009, 05:16 PM   #2737
NiTrO BoOsTeR's Avatar
Thanks for all your advice it realy helps.
Mitchell
Serpent 733 - RB T10rc - Ko Helios EX-10
Serpent 733 - Novarossi 3SCT Tuned
============== SERPENT the only way ============
==== Pro Buggy Rc, Pitsworth - for all my RC needs =====
NiTrO BoOsTeR is offline   Reply With Quote
Old 02-25-2009, 06:07 PM   #2738
tony montana's Avatar
Trader Rating: 66 (100%+)
I have bad luck with ti screws. I usually use tony's screws althou I know they add weight but they dont strip
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 02-25-2009, 07:59 PM   #2739
Francis M.'s Avatar
Strip on plastic?
Old 02-26-2009, 04:22 AM   #2740
asw7576's Avatar
R U promoting tony's screws ? ..... yeah, they are tough ones.
I use tamiya and mugen seiki titanium screws since long time ago. One trick to prolong the life of titanium screws : never open Ti screws with worn out tool's tip. I usually replace my tool tip's every two years max. ( Hudy 2mm and 1.5mm tip ).
Old 02-26-2009, 08:43 PM   #2741
Arahawak's Avatar
Trader Rating: 32 (100%+)
1) TI pivot balls
Above are good weight savers.. also Lipos if you wanna. With Lipos, you might have to add some weights so as not to disrupt the CG that much.
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 02-27-2009, 10:24 AM   #2742
Ron C.'s Avatar
So did my drive last sunday make you laugh?
I gave you the part number. Not sure what you're waiting for....
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 02-27-2009, 10:28 AM   #2743
duku's Avatar
Default ex 10
hi guys..
jus wondering if any of u guys out there use a ko propo ex10 helios..
i have a ques for u guys...
everytime i press the full throttle down the straight the car suddenly steers off without touching the steering wheel...
this almost cost me my car when it suddenly turned away at full speed down the straight and crashing into the fence...when i got there my batt pack was disconnected from the throttle servo and when i took it out, the servo wire melted...
what was the cause of the car steering off whenever i pressed full speed and why did the servo burn???
i need help guys
Kyosho Evolva 07
KO EX-10
Max .21 XL9
duku is offline   Reply With Quote
Old 02-27-2009, 10:51 AM   #2744
lil-bump's Avatar
Originally Posted by duku View Post
hi guys..
i need help guys
Sounds like the wire shorted at some point in time. Maybe the wire got cut or rubbed against something.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 02-27-2009, 10:21 PM   #2745
asw7576's Avatar
hi guys..
i need help guys
1. make sure the gold connectors / pins are cleaned, in order to produce clean signal from receiver to servo all the time. Use electric motor sprays to clean the pins.
2. take care the servo and antenna wire. Occasionally use shock's silicone oil to soften the wire skin.
3. make sure the rx crystal still in good condition. If you aren't sure, I suggest to replace it now.
4. Use thick rubbery double tape to place the receiver. I know KO propo receiver hates vibration. Unlike sanwa, which is stronger receiver for vibrations.
5. Use Y wire extension, so you plug & unplug the electrical power from Y wire extension instead of doing it directly from receiver's pins. ( If one day the connections are loose, simply replace the Y wire extension ).
6. In your case, you need to replace the servo completely. Buy new servo like PDS-2367.
7. Set your maximum end point adjustment through your radio. When maximum turning point is already set, the servo won't get burnt. Same with maximum throttle and brake position. Set them correctly, so the servo won't get burnt.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
