Old 02-23-2009, 05:10 AM   #2701
stefan's Avatar
Send a message via AIM to stefan
Originally Posted by brc358 View Post
I picked up a couple of the NT1 receiver boxes but have not had time to install them yet.
Did you have to drill a hole in the radio plate for this to adapt?
thanks
Nope, you actually have to drill two holes into the box' lid and then you can use the original holes in the top deck.
stefan is offline   Reply With Quote
Old 02-23-2009, 07:24 AM   #2702
Trader Rating: 18 (100%+)
Default Mugen MTX4R
Good deal, I will look at it later today.
thanks much
[COLOR="Red"][FONT="Comic Sans MS"][/FONT][/COLOR]BRC358http://www.kamikazercracing.com
nearest barstool
brc358 is offline   Reply With Quote
Old 02-23-2009, 11:02 AM   #2703
aaron2u's Avatar
Trader Rating: 47 (100%+)
Default MTX4R Gear Selection
I just traded for a used car from RC Tech, it arrived and needs new spurs. It has 17/23 pinions. If I'm looking at this right, to match, I keep the same blocks, right?
So for 17/23, I can run either 60/54, 59/53, or 58/52?
Also, on the MTX4r, the chassis is supposed to be completely flat, or have a slight bend in the middle at the carrying handle? The middle is lower than the rest of the car, but it's symmetrical across the chassis...
Thanks guys! I'm looking forward to thumbing through the 67 pages for MTX reading when I get a chance.
Happy Nitros,
Aaron
Pick me!
aaron2u is offline   Reply With Quote
Old 02-23-2009, 11:42 AM   #2704
Ron C.'s Avatar
Originally Posted by touringdriver View Post
guys i've been racing a mtx3 for the last 2 years. i just purchased a mtx4 yesterday, my questions is: is there much parts interchangable between the 2. i have new 3 universals, arms, spur and clutch pinions. and also is there alot of differences between the mtx4 and the mtx4r? i couldn't find a good used r. and is the mtx4 upgradable to the r? thanks for any insight, opinions answers and help.
Touringdriver,
Between the 3 and the 4 car, the front universals are the same but the rears are different, the arms and pinions are also different.
The MTX-4 is very upgradeable to be an MTX-4R: The difference are:
- T0142 Aluminum Wheel Hubs
- T0151-B Front Lower Arm
- T0161 Rear Upper Arm Mount
- T0164 Front Uprights (2)
- T0245 Front Universal Joint
- T0268 Front Belt (Rubber)
- T0269 Rear Belt (Rubber)
- T0270 Side Belt (Rubber)
- T0274 Rear Universal Joint
- T0276 Front One-Way Drive Axle
- H0369 Ventilated Brake Disk
- T0717 Aluminum Engine Mount
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 02-23-2009, 12:11 PM   #2705
spenzalii's Avatar
Send a message via AIM to spenzalii
Happy Nitros,
Aaron
On the spur/pinions combo: The gears the car uses are 0.8 pitch. The diameter of the spur gears doesn't change with an increase or decrease of the number of teeth, unlike the standard 1.0 gears. So, you can run the 17 tooth pinion with either the 60,59, or 58 spur (and likewise on the 23 tooth pinion)
Hope that helps!
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 02-23-2009, 12:47 PM   #2706
aaron2u's Avatar
Thanks... So mesh isn't affected if I swap? If I pick any of the 3 listed for the 17, and then any 3 listed for the 23, mesh doesn't change? I looked at it as the gap between had to match proportionally somewhat.
No wonder why the holes in the chassis are so small. THanks! It is slowly sinking in...
Pick me!
Old 02-23-2009, 01:03 PM   #2707
tony montana's Avatar
Trader Rating: 66 (100%+)
ok guys Im back with nitro touring again. Got a mtx4 that has been upgraded to a 4r. Anyone have a good setup for 301 raceway to start of with. And what foams. Where is a good place to order stuff now since c whits is closed. I had a mtx4r before put never raced it at 301 just practiced with it. So The whole racing thing is gonna be new to me with on road.
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 02-23-2009, 01:25 PM   #2708
nitrodude's Avatar
Tires?
http://www.kamikazetoysandhobbies.co...ucts.php?cat=9
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 02-23-2009, 02:45 PM   #2709
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
These places are all a bit closer to you with good choices and very fair pricing.
World famous GRP tires: (on page 2)
http://ashfordhobby.com/SearchResult.aspx?CategoryID=10
World Champion ATS/Twister tires:
http://www.twistertiresusa.com/index...n9s260b42fh9c3
A few good choices available here:
http://www.winnerscirclerc.com/index...52ca8128f328ce
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 02-23-2009, 08:00 PM   #2710
spenzalii's Avatar
The 0.8 gears are different than the 1.0 gears. With the 1.0 gears, the diameter goes up when a tooth is added. So you had to keep the same tooth split between 1st and 2nd gear. With the 0.8 gears, the diameter stays the same. The teeth on the gears get thinner (best way to explain it) to get more teeth in the same diameter spur gear. This gives you a greater range to tune your gearing, but makes having the gear mesh much more critical.
Old 02-23-2009, 10:54 PM   #2711
touringdriver's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Ron C. View Post
Touringdriver,
thanks a bunch for all the info. any suggestions for gearing a mtx4 with track size 120 x 60. tight turns? racing a o.s. .12tz 5 port.
Proudly Sponsored by: Mr. Crash Racing, RickyRacer lidz & Ebay..
Rock Chalk Jayhawks
2014 Subway Cup & Dee and Mees On-road Race Schedule:
http://www.rctech.net/forum/kansas-m...l#post11891510
touringdriver is offline   Reply With Quote
Old 02-23-2009, 11:10 PM   #2712
Francis M.'s Avatar
17-23 with 60-54 spur is a good starting point or 16-22 depending on tire diameter....
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 02-23-2009, 11:17 PM   #2713
aaron2u's Avatar
Boy, times r a changin... Thanks for the info! I was checking out the car earlier and kinda came up with a sure fire way to set the mesh. Remove the outer gear, set the mesh, and put the gear back on, recheck the mesh. Any variance, repeat...
Pick me!
Old 02-23-2009, 11:21 PM   #2714
aaron2u's Avatar
Originally Posted by gentleman81 View Post
nice!
I'm sure it's in here... Here's the part number for the NT1 receiver box. 336000 through Nexus. Bad news is, I just order the last two...
Pick me!
Old 02-24-2009, 12:54 AM   #2715
ViperSkull's Avatar
Default gear stripping
Hey Guys,
I have a really bad and unknown problem going on with my car. Every single race i do i strip both 1st and 2nd gear. I have tried many things to fix this problem but nothing has worked. I have put brand new bearings in my engine. put brand new bearings in my clutch bell, have made sure my engine is square and meshed properly(done this many times), changed my EPA so that it doesn't pull the engine under throttle and brake, checked the bearing in the 2 speed housing, redone my clutch setup and made sure i had little end play, only 0.4mm. I have pretty much done everything i think. I just had a race meeting on sunday and i stripped 5 spur gears. What could be the problem? Maybe the clutch bell is warped??
Thanks,
Tim
BRCCC Wynnum
Mugen MTX4-R/Novarossi Max Power/Mugen Pipe/Futaba 3PK/Spektrum HRS System
*For Sale, CT4S with a heap of parts*
ViperSkull is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
