Old 02-11-2009, 01:12 PM   #2641
JayL's Avatar
I run all my belts loose as it free's up the car. I have also noticed guys that run the side belt tight tend to throw it when the tap a wall.
I use the brake adj you indicate to tune my brakes for the track when running a one-way. I tighten the knob until I have perfect drag brakes.
JayL is offline   Reply With Quote
Old 02-11-2009, 02:15 PM   #2642
lil-bump's Avatar
Trader Rating: 83 (100%+)
Originally Posted by xtopher_aaron View Post
Random questions incoming!!!
1. How hard do you guys set your brakes to? Im referring to that adjustment on the car on top of the throttle servo (sorry I dont know whats it called)
2. Belt tension, how much tension is needed? is stiffer better or looser? Should I aim for loose or stiff?
Thanks in advance guys..
Chris,
I set my belts loose. These are considered timing belts not friction belts. If you over tighten your belts is will cause unwanted drag. Same as the above post. I like to set my breaks mechanically first; then I fine tune them with brake expo.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 02-11-2009, 03:50 PM   #2643
Trader Rating: 21 (100%+)
Anybody ever use 3racing spur gears?
VA_Racer is offline   Reply With Quote
Old 02-11-2009, 03:54 PM   #2644
Seisick's Avatar
anyone has tried these bands?
http://cgi.ebay.com/Side-MTX-4-High-...1%7C240%3A1318
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 02-11-2009, 04:10 PM   #2645
Originally Posted by Seisick View Post
Yes I have used them and they work really good. Only problem is I haven't had one break. When I had one go the teeth stripped on the belt but didn't break.
Old 02-11-2009, 07:02 PM   #2646
kcrunchone's Avatar
Chris,
Q 1
Brakes ??? Whats that ??? Nah seriously every track is different, for brakes. Even the time of day and the amount of traction can change your adjustment on the brakes, so just test and go, that is pretty simple to rectify on the fly by a pitman just tighten or loosen on the car...
Q 2
Belt tension will also for me depend on a few things traction, how worn the belt is, how long the main is, but on the average I would tell you to start off mid point. To me it seems as if rubber belts have a more cohesive power transfer when they are not as tight, To tight especially on the rear can tend to snap the rear around if you pop the throttle, some people I have seen like that rear sway and can use it to thier advantage.
Rick Hill
"Failure Is Not An Option"
kcrunchone is offline   Reply With Quote
Old 02-11-2009, 07:11 PM   #2647
kcrunchone's Avatar
The 3racing gears are OK but they require a really perfect mesh, if your engine shifts or your mesh is off the first contact you have the gears are done. I have been using them for a long time now. A good friend of mine Saul turned me on to them, he was using them and had noting but good things to say about them, to me they seemed to have less wear issues on smooth tracks but a bumpy or low traction track they are not my first choice.
Rick Hill
Old 02-11-2009, 07:51 PM   #2648
lil-bump's Avatar
I've tried those belts and I was not impressed. I found they only last about half as long. If it were me; buy the mugen belts. IMHO
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 02-11-2009, 07:56 PM   #2649
quietstorm76's Avatar
Chris,
Loose belts always. If the pulleys and belts are good they won't slip.
Brakes, well that depends on how fast I'm going at the end of the straight. I run enough brakes so I can brake as late as possible but still make the turn.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 02-11-2009, 08:56 PM   #2650
Send a message via MSN to xtopher_aaron
Thanks for the help guys..
Belt tension = Loose is better
Brakes = Match every track..
Got it !!
Mugen Seiki MTX-4R || LRP Z.12R Spec 4 || LRP Pipes || Spektrum DX3R (Coming Soon) ||
xtopher_aaron is offline   Reply With Quote
Old 02-11-2009, 10:54 PM   #2651
asw7576's Avatar
Got it !!
I think belt tension stiffness is debate-able. .... I prefer my car's belt tension is rather stiff but not too stiff. Loose belt tension can cause missing teeth if you accidentally hit a wall.
I use Armor All Original Protectant to clean scrub the belt after use. Some of my car's belts are already 4 years old now
Old 02-12-2009, 06:31 AM   #2652
4 years? Legendary !! What do you use to scrub down the belt ? toothbrush ? and can i just use something like WD40 to spray on the belts n then toothbrush them ?
Old 02-12-2009, 08:01 AM   #2653
JetMD's Avatar
I think WD-40 is debatable. I personally have used it just prior to a race and it has a very noticable affect on loosening up the drivetrain. My friend's think, and I somewhat agree that it does seem to shorten the life of the belt. I guess there is some give and take with that. I have never tried armor all but it does interest me. If it gives the "free-ness" without loss of life, sounds like a win/win.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 02-12-2009, 08:53 AM   #2654
asw7576's Avatar
I usually use a clean bath towel ( that I don't use anymore ) to wipe the belt clean. Dip the towel into armor all liquid and start wiping ( by pinching ) the belt. When the towel is dirty, I change to another section that is still clean, and restart the process again.
I also notice the groove inside the pulley's teeth are cleaner too with armor all treatment. Less prone to see the dirt stuck within the pulley's teeth.
Old 02-12-2009, 09:28 AM   #2655
staikosn1's Avatar
Send a message via MSN to staikosn1
Originally Posted by getpip View Post
No...
If you look at the box .. there is a long edge and a short edge.
On the Xray the long edge mounts along the top deck ...
On the MTX the two holes on the short edge align perfectly with the holes in the top deck.... these are the holes I have used to mount mine.
If anyone wants pics of this let me know.
Get some pics if you can plz!!!!
XRAY NT1 || RB T10 RC || FUTABA BLS || SANWA M11 ||
#FANATIX MODELS# #www.frt.gr#
staikosn1 is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
