Old 02-06-2009, 01:32 PM   #2596
Francis M.'s Avatar
Originally Posted by staikosn1 View Post
Ok ill try! I wanted to replace yhe oneway with dif. The dif case with pulley seems to be larger that the space bitween the bulkheads. After 1 hour the dif was placed in bulkheads i couldnt put the carbon for suspensions!
Do you understand now?
When you install the pulley on the front diff. Make sure you are just using the one side and not attaching the plastic belt guide for the other side... That is only to be used for the one way or spool... this should solve your problem with the fitment..
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 02-06-2009, 01:33 PM   #2597
staikosn1's Avatar
Send a message via MSN to staikosn1
Originally Posted by lil-bump View Post
Make sure both bearings are all the way down onto the diff before you place the diff between the front bulkheads. I had the same problem.
This sometimes happens when installing a brand new diff housing.
Pass you soon...
Im sure i placed the dif and bearings correct!!! So lil-bump what i have to do?? I cant place the front bamper stay when i the dif is all way down! the space between the bulkhead is more larger!
XRAY NT1 || RB T10 RC || FUTABA BLS || SANWA M11 ||
#FANATIX MODELS# #www.frt.gr#
staikosn1 is offline   Reply With Quote
Old 02-06-2009, 01:35 PM   #2598
Ron C.'s Avatar
staikosn1,
Let me ask you this: When you built your front diff and put the front pulley onto the diff, did you use the separate ring (part #T0258B) as how you do on a Front one-way?
If your answer to my question is YES, then that is your problem. Take that ring off and it should make the front diff fit right between your your bulkheads.
You SHOULD NOT use that ring on a front Diff. That is why it is separate from the actual front pulley.
Good luck!
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 02-06-2009, 02:31 PM   #2599
staikosn1's Avatar
Originally Posted by Ron C. View Post
staikosn1,
Good luck!
You are corect Ron C. I didnt even thought about that... Damn.... Thank you Ron C!!!
Old 02-06-2009, 02:52 PM   #2600
musti72's Avatar
actually, tire wear front vs. rear is something about the overdrive too. So for ex. when you use 24t pully with 1mm split, fronts will wear more than using 2mm split, because its dragging. and you also feel more comfortable with some overdrive at front. so, if you want your front tires to wear more equal to rears;
you can use less split,
use solid at front,
some softer tires at front, or harder at rear. maybe f37 r42. i havent tried this but makes sence since the car has understeer.
musti72 is offline   Reply With Quote
Old 02-06-2009, 09:57 PM   #2601
asw7576's Avatar
I prefer driving a car with rear tire is rotating faster than front ( kind of 2wd ). I accomplised that by using 24T front side pulley and 20T rear center pulley ( pulled from MRX4 ). I use 40 shore rear and 37 front to minimise the chance of rear tire getting smaller than front's after 30 or 45 minutes final. This is also help to reduce understeering in my car.
In the past, I get sucks driving feeling after 20 minutes driving. I notice the problem when rear tires have same diameter as front's, eventhough I already start with 4mm split.
Old 02-07-2009, 12:29 AM   #2602
Send a message via MSN to xtopher_aaron
use solid at front,
This does make alot of sense about the tire compound. But looks like i got conned at a LHS a few days ago. I was adament about getting 37f and 40r.. But the guy insisted it was the other way around. So I thought he knew better since im quite a newbie to this, but it just made basic sense to me, I may have not been with RC's long, but im a huge motorsport fan..
I think I maye just leave on the 40f and get a 42r to match it, and keep the 37r and get another 35f for spares.. I'll practice with the harder ones first..
Thanks all!
Mugen Seiki MTX-4R || LRP Z.12R Spec 4 || LRP Pipes || Spektrum DX3R (Coming Soon) ||
xtopher_aaron is offline   Reply With Quote
Old 02-07-2009, 02:46 AM   #2603
getpip's Avatar
Thanks all!
Hi..
Dont get fixated on this... different people run different tyres depending on many factors.
Run what you have and see what you think... If you are are inexperienced you probably wont be able to tell much difference and those tyres wont last very long at all anyway... about an hour of running is as much as you can expect.
I would say this however ...
I am sure that you, like most others, will eventually want to run the 24t front pulley.. the most effective way to do this is with a 2.5mm offset.
Save up for a tyre truer, Integy do a manual one which I believe is really cheap in the US (Under $100) It will be one of your best purchases if you get serious.
regards Pip
getpip is offline   Reply With Quote
Old 02-07-2009, 03:17 PM   #2604
gentleman81's Avatar
whats the difference in the two Acer bearing kits??? for the mtx4 and R
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 02-07-2009, 03:48 PM   #2605
Trader Rating: 21 (100%+)
mtx4r-INCLUDES: Four 12 x 18mm bearings
Four 10 x 15mm bearings
Eight 6 x 13mm bearings
Two 5 x 10mm flanged bearings
Seven 5 x 8mm bearings
Two 12 x 5 x 4mm bearings
Four 10 x 6 x 3mm bearings
mtx4-INCLUDES: Four 12 x 18mm bearings
VA_Racer is offline   Reply With Quote
Old 02-07-2009, 10:41 PM   #2606
so you get more for your money with the R kit? they are the same price right now
Old 02-08-2009, 04:54 AM   #2607
getpip's Avatar
They are the same kit check the website ....
http://www.acerracing.com/catalog/Mugen-21-1.html
Check out my blog: www.pipskiracing.blogspot.com
Old 02-08-2009, 06:43 PM   #2608
yea i looked at the site, i was finding out why there is a R kit part number and a regular MTX4 kit number.
Old 02-08-2009, 07:24 PM   #2609
ira
ira's Avatar
Trader Rating: 18 (100%+)
I use the Ceramic Nitride Pro Series on all of my car kits, they are the best on the market. If your not sure about the kit don't think twice, just get them and you want be disappointed!!!
RC AMERICA, XRAY, FUTABA, O.S. ENGINES, BYRON FUELS, SPEEDWORLD RACEWAY, HOBBICO, MATRIX TIRES...
ira is offline   Reply With Quote
Old 02-09-2009, 03:53 AM   #2610
getpip's Avatar
Good point .. maybe it was a marketing thing for when the car was first released or maybe it comes with R decals or something?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
