Mugen MTX-4R
#2551
Care to explain in a bit more detail your adjustable oneway solution? Sounds interesting...
#2552
we have also cut the front bulkheads behind the arms , works great makes car rotate better
#2553
Anyone looking to unload a new or like new mrx4x, have a 07' wc evolva fully hopped up to trade email if interesed, i ran like 6 times, wanna check my options [email protected] Not to spam!
#2555
Anyone knows about the team orion servos??
Does they worth the money??
#2557
i do not have a camera at this time. i took a dremmel and cut 2mm off front bulkhead behind arm and then add 2mm shim in front of arm and behind front sway bar
#2558
So you did this to the lower front arm? This would also then effect the total caster, and shorten your wheel base. Am I assuming right?
#2559
You shouldn't cut the bulkhead, there's not enough meat there. You are weakening the bulkhead too much. I cut 2,5 mm off the front a-arm.
#2561
Sure, you need to change the caster clips accordingly. And shortening the wheel base is exactly why this is done, although just as Stefan explained, most people cut the arms instead.
#2562
I saw you are already using sanwa m11 radio.
why don't you buy sanwa servos ?
I'm using sanwa vx and vz in mtx4 and mrx4r respectively.
( becareful people ...., vx and vz are not digital servos, thus they are not suitable for futaba hrs receiver !! ).
I have two Sanwa WRX on which I just changed the wires. After seeing how they are built, they are waaay overpriced.
#2563
..and if you insist on having the full range of caster adjustment (which you don't need) you simply cut the upper arm as well....
#2564
#2565
I see how things are heading now. Pretty cool
