Old 12-01-2008, 08:17 PM   #2326
MugenDrew's Avatar
Trader Rating: 30 (100%+)
Buy the kit from ACER. When and if you need spares( which you will) get them from avidbearings.
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 12-02-2008, 01:21 AM   #2327
shokyo's Avatar
keep it up frens...lots of thing i had learn from here...
FB= Yuneef Shokyo
~///~ Futaba 3PDF FM 75.67Mhz + Futaba 3PKS 2.4 GHz ~///~
~///~ Mugen Seiki MTX-4R + LRP spec 3 je(dah jual), STS DX3R, OS SPEED TUNED (dah barai),Picco edo (dah barai), Picco IDM (dah barai), Nova Max (dah jual), Nova NS3,Nova 353 09, Nova .12 3ST 09 ~///~~///~ Serpent 960 + Nova Flash .21 ~///~
shokyo is offline   Reply With Quote
Old 12-02-2008, 04:21 PM   #2328
Francis M.'s Avatar
Congratulations to Mike Swauger taking the win at brazil....
http://www.redrc.net/2008/11/swauger...lo-champs-rd6/
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 12-03-2008, 05:07 AM   #2329
slow_rock's Avatar
Originally Posted by ira View Post
Are the bearings ceramic? The best Ceramic bearing I used ( Tested ) are the ACER Racing!!!
what the different?..
slow_rock is offline   Reply With Quote
Old 12-03-2008, 06:02 AM   #2330
MugenDrew's Avatar
They weigh less. This benefit is two fold because the bearings are rotating weight and the bearings in your up-rite's are unsprung weight.
They offer less rolling resistance which frees up power. The power that was being consumed to over come the weight and resistance of steel is now being used to push the car.
Old 12-03-2008, 07:19 AM   #2331
lil-bump's Avatar
Trader Rating: 83 (100%+)
Speaking of unsprung weight. Has anyone ever had the plastic wheel hexs go bad. I'm thinking of switching back to the plastic hexes. I believe it saves almost 8 grams of unsprung weight.
Any comments????
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 12-03-2008, 09:20 AM   #2332
asw7576's Avatar
Any comments????
Pass you soon...
I think alluminium wheel hex will stand side way impact much2 better than plastic wheelhex. With plastic wheel hex, the pin might collapsed on side way impact, making the wheelhex rubbing the bearing, thus wobbling. Don't forget, the bearing might be hot during racing period and cause wheel hex wobbling.
I guess alluminium wheel hex is still the best optional equipment for racing competition.
Old 12-03-2008, 10:11 AM   #2333
lil-bump's Avatar
Thanks for your comments
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 12-03-2008, 10:59 AM   #2334
MugenDrew's Avatar
If you have access to a drill press you can drill them on axis at tho six points. Remember the clamping screw is only there to hold it on when the wheels off.
The biggest problem I have seen with the plastic hexes, you cant hammer the wheel nuts on...
Old 12-03-2008, 12:15 PM   #2335
lil-bump's Avatar
I take it you mean drilling the hexes on the flats? Size drill bit???
Elliott Hart
Serpent America
Desoto Racing Team
Old 12-03-2008, 05:00 PM   #2336
MugenDrew's Avatar
If the hex was laying on a surface with the face that contacts the wheel, if you took a wheel off and looked directly at it, if you were looking at a six sided stop sign. This would be flat on the table of the drill press. The backside with the step in it to make sure the hex only contacts the inner race of the bearing would be facing the ceiling.
The size of the drill bit I don't remember. The last set I made are on my pit guys car and he is 130 miles away. What I did to determine the size of the drill bit was to measure from the I.D.(the hole for the axle) to the tip of the drive face of the hex. Subtracted two millimeter from this to obtain the drill bit side.
I only drilled the two points 90 degs. to the screw this size. The other four points sizes varied after replacing the steel screw with a ti one to maintain balance. I use a magnetic prop balancer for balancing.
What you just said I did not even think about. The drive flats could also be drilled to further reduce weight with out sacrificing support to the drive area of the wheel hub. !BITCHIN!...YBSlow fire up that CNC
Big Ol [email protected]$ to lil Bump, thanks
Old 12-05-2008, 09:02 AM   #2337
BiggDogg33's Avatar
Send a message via Yahoo to BiggDogg33
Originally Posted by Ron C. View Post
BiggDogg33,
Here are the list of parts differentiating the MTX-4 kit with the MTX-4R:
1. Aluminum Wheel Hub : Part# T0142
2. Front Lower Arm : Part# T0151-B
3. Rear Upper Arm Mount : Part# T0161
4. Front Upright (2) : Part# T0164
5. Front Universal Joint : Part# T0245
6 .Front Belt (Rubber) : Part# T0268
7. Rear Belt (Rubber) : Part# T0269
8. Side Belt (Rubber) : Part# T0270
9. Rear Universal Joint : Part# T0274
10. Front One-Way Drive Axle : Part# T0276
11. Ventilated Brake Disk : Part# H0369
12. Aluminum Engine Mount : Part# T0717
As far as where to purchase them : www.kamikazetoysandhobbies.com . I suggest calling them direct at (714) 997-8697
Hope this helps,
Thanks alot!!!
BiggDogg33 is offline   Reply With Quote
Old 12-05-2008, 10:34 AM   #2338
Ron C.'s Avatar
BiggDogg33,
Hope this helps,
Originally Posted by BiggDogg33 View Post
Thanks alot!!!
You're welcome.
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 12-05-2008, 04:19 PM   #2339
Seisick's Avatar
Any comments????
Pass you soon...
3 years using plastic hexes, just make sure to rotate them
and use a shim between it and the bearing, no problems whatsoever
except with certain foam brands where the fit is too tight and
when you release the tire, it will draw the plastic hexe
cheers
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 12-05-2008, 11:32 PM   #2340
gentleman81's Avatar
Any comments????
Pass you soon...
i hit too much stuff, and they always used to end up crammed into my rims. so i went metal, alum, and im good.
drilling them, man, that would be a good amount of work?
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
