Old 11-05-2008, 11:26 AM   #2296
musti72's Avatar
for brakes, there is a tip from mike swauger:
use one of the pad black(stock), and the other one yellow(teflon)
for rear shafts, i use dogbones and put one susp. o ring to the diff side. no problem at all.
musti72 is offline   Reply With Quote
Old 11-05-2008, 05:41 PM   #2297
T-ROY22's Avatar
musti72
any configuration work better than the other black-inside, yellow-outside or vise-versa?
T-ROY!
Mugen Seiki USA,Enneti Tyres, Murnan Modifieds, Airtronics USA
T-ROY22 is offline   Reply With Quote
Old 11-05-2008, 05:52 PM   #2298
G87z's Avatar
Anyone try the MBX6 pads yet? the pre mounted type? They almost look like the kyosho APP pads.
From what I have read the Kyosho pads are supposed to work really well.
I am going to give the MBX6 pads a try.
Team Shepherd USA / Picco Engines / Sanwa / Matrix Tires / Byrons Fuel / SRC
G87z is offline   Reply With Quote
Old 11-06-2008, 05:55 AM   #2299
Seisick's Avatar
Originally Posted by NitroWD View Post
any difference whether u put the o rings in the diff cups or wheel cups?
orings in the diff cups should be used as the hits usually comes from the wheel
if no orings are available, fuel tubing can be used to your desired length
always use the shim spacer in before the wheel hexe, it will also help reduce
the chance of dogbone poping out
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 11-06-2008, 08:36 AM   #2300
lil-bump's Avatar
Trader Rating: 83 (100%+)
Originally Posted by Francis M. View Post
How much does your car weight? I have the airtronics servos with alum heat sink. to offset the extra weight from the servo I installed MSR light weight pulley adapters, ti pivot balls, and the ti screw set from mugen upper screws only, mugen alum 2 peice engine mount and I am barely making legal weight.....
Hey Franci,
I found where I picked up the extra weight. My battery wire had broke internally to the Insulation so once I fixed it I covered the entire bttery with Glass tape;well I guess I got a little carried away with the tape and My battery wound up weighing 130 grams. Which is about 30 grams over without the tape. Right now in race fashion, I'm sitting at 1746 grams without the Ti screws I'll install them tonight if possible. This is with a mugen 4mm chassis. I'm not a weight fanatic I just like to keep the car in the lower half of the spektrum. When I started my car was around 1850 grams
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 11-06-2008, 06:03 PM   #2301
gentleman81's Avatar
Originally Posted by SOLOARTIST 702 View Post
whats up you got your boot off your foot saw you at cap class. booted up doin good i hope
yea, what up dawg! im back turn marshalling like a pro!
it was a definate few days to remember.
limpping up and down that ramp was sweeet.
i will be seeing you next year fa SHO!
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 11-06-2008, 06:05 PM   #2302
i used them on the insides, near the diffs. you could use them both places if it doesnt bind it up. put them in, set your ride height and squish the susp to see.
Old 11-06-2008, 06:07 PM   #2303
Originally Posted by sadil View Post
I apologize for being random, but I was wondering if anyone knew the dimensions of the MTX4 two speed input shaft (T0232). Im mainly interested in its diameter. Furthermore, has anyone converted their Mugen MTX4 or MTX3 into single speed rather then two speed? Its a little project im working on. Thanks in advance.
Sarosh
go to TBSlow.com (i think) he should have dimensions since he makes his own shhhhhhhh
Old 11-08-2008, 08:43 AM   #2304
musti72's Avatar
i think it doesnt matter.
Old 11-08-2008, 08:51 AM   #2305
Team Kamikaze's Avatar
Sarosh
2 speed shaft diameter measurement is 6 mm.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 11-10-2008, 07:10 PM   #2306
lil-bump's Avatar
I need a little advice. What aspect of the car can I change that will allow me to carry more speed thru a sweeper. I find myself lifting thru sweepers.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 11-10-2008, 08:16 PM   #2307
ira
ira's Avatar
Trader Rating: 18 (100%+)
What weight rear diff fluid ? Try 50,000 in the rear, you can also limit the front droop.
RC AMERICA, XRAY, FUTABA, O.S. ENGINES, BYRON FUELS, SPEEDWORLD RACEWAY, HOBBICO, MATRIX TIRES...
ira is offline   Reply With Quote
Old 11-10-2008, 08:51 PM   #2308
lil-bump's Avatar
What's up Ira,
I'm the one that left my truer at Leisure. I normally run 30k in the rear; I ran once with 100k in the front and 50k in the rear (toledo track) and to me my car would not rotate as well. But I'll will give it shot. I would like to come thru the sweeper without lifting but not full throttle. Don't get me wrong; some of it is just nerves. But I find the car pushes just a little if I don't lift.
That was first idea was to decrease front droop, the next thing I was going to try was more caster.
Maybe I should ask this question. What type of throttle are you suppose to use coming thru a sweeper???
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 11-10-2008, 09:22 PM   #2309
ira
ira's Avatar
Is this at the Toledo track? I have a realy good set-up for that track.
If you are talking about the Toledo track, it's all about the way you setup for the sweeper. You can go thru the sweeper with out lifting, but if you miss you will pay for it!!!
Later,
Ira
P.S. Is it cold there yet, shur is here.
Old 11-10-2008, 09:43 PM   #2310
lil-bump's Avatar
Later,
Ira
Colder than a witches tit.
I would like to take a peek at your toledo setup.
I actually like the spool at toledo, But I want try a diff.
I think your right; It's all about how you setup before the sweeper. I watched Josh Cyrul he has mastered that sweeper. I believe the correct line is to start slightly high on the line cut the sweeper tight (just missing that inside board) then slowly bend the rest of the sweeper to setup for the 180.
But you have to be man enough or sponsered enough to take that sweeper that tight
Elliott Hart
Serpent America
Desoto Racing Team
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
