Old 10-22-2008, 08:03 PM   #2206
Originally Posted by Artificial-I View Post
I never had a problem with it in my car , race after race after race. (short track) Then took the exact same car , same setup , motor etc etc to a large grippy track with long straights and the gear stripped in about 10 minutes of during a fool around test session.
But anyhow Ive been out of the scene for a little , from what I saw mugen has new gears....not to beat a dead horse if it has been but are these effective for the stripping issue, were they made for the issue?
Different gears won't fix a stripping issue. There's a physical reason why gears strip. Too many variables to point the finger at one thing, but if you mesh right, lock tight, and keep things on the rear bulkhead tight, you really shouldn't have issues. I've stripped gears, but every time I've found a different culprit. But it seems it's not just the mugens that have this issue, RRR, NT1, TM, they all strip if something isn't right. So to say one brand of car has gear stripping issues is kinda like saying $hit doesn't stink.
Baedarlboo is offline   Reply With Quote
Old 10-22-2008, 08:29 PM   #2207
I too was plagued with gear stripping problems when I first got my mugen. I solved it by using longer screws to bolt the engine down. I do believe that mugen needs to revisit those screws. 8mm is not strong enough to hold our new powerfull .12 mills. I use a 10mm screw and that helped more than just getting the new gears and the new two speed clutch shoe/springs set. The only few times now that I strip gears is basiclally when my engine shifts due to not tightening it correctly or a big stone gets in there. I also use a very tight mesh. I follow the same messh technique a lot of gurus use.
I raced for two days hard this past weekend and no gear strip problems.
SasonRC is offline   Reply With Quote
Old 10-22-2008, 09:50 PM   #2208
gentleman81's Avatar
tru, this car needs to be rock hard solid to avoid this, and when the cars started using the .8 gears, is when the issue began. even the .8 gears on the mtx3 stripped.
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 10-23-2008, 05:17 AM   #2209
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Exactly what he said . I bought my mugen used and im pretty sure it was sold because he couldnt figure it out. Now i have 3 racedays on it with no problems...Thats 50 minutes of qualifies and 30 minutes of mains. This doesnt count all my practice laps amd i broke in a new engine. Small or big track I dont think it makes a difference. I ran 2 days at a smaller track and this past weekend at 301 in MD which is big and all was fine.
Keep your car tight and everything will be fine
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 10-23-2008, 07:12 AM   #2210
musti72's Avatar
i have two another solutions. first, if you are using the stock engine mounts, be sure that the bottom surfaces of the engine mounts are parallel, so all the four corners of the mounts sit same time to the chassis. if only 3 of them are touching at the same time, recheck the mounts.
another issue is, when you are tigtening the rear side belt pulley to the shaft, be sure that there is nearly 1mm space between pulley and bulkhead so the shaft could play a little side to side. after that, adjust your rear belt pulley so its straight when the space of the shaft is on the spur side. by doing this, when the belt finds the right place of the shaft, spur gears are able to move a little bit and this doesnt stress them.
these should help.
hope that u understood my english
musti72 is offline   Reply With Quote
Old 10-23-2008, 07:40 PM   #2211
tony montana's Avatar
Trader Rating: 66 (100%+)
nitrobeast, actually I never stripped a gear on that particluar 4r. It was a used mtx4 that I had the problem with. How did you like 301 raceway? Place is awesome isnt it
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 10-24-2008, 09:20 AM   #2212
howardns's Avatar
anybody know the weight difference between the mugen 3mm and 4mm chassis ?
Serpent Cobra GT
Homestead RC Raceway
howardns is offline   Reply With Quote
Old 10-24-2008, 04:04 PM   #2213
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
My r40 never had one issue. I only replaced gears due to sand wear from the florida environment.
Artificial-I is offline   Reply With Quote
Old 10-24-2008, 04:06 PM   #2214
Moderator
I had about 4-5 guys with the 3 and they loved it and ran it all around florida then they went with the 4 and stripped over and over and over. Were talking owners of companies , now team serpent drivers and so on. These guys were the top of the charts and all left the mtx-4 in one weekend after it came out.
But not bashing the car I love it just still shocking to see it always talked about even months and months after its release.
Old 10-24-2008, 05:05 PM   #2215
yeah mugen needs to fix this problem
Old 10-24-2008, 06:27 PM   #2216
quietstorm76's Avatar
I too ran the 3. It was a used car and I ran the car from march 2006 to march 2007(bought a 4). I honestly can't remember stripping a gear. I do remember running the same spur gears for months and only changed them because they looked really beat up. The 4 uses the same spur gears as the 3, so why is the 4 stripping like hell.
What changed in the drivetrain going from the 3 to the 4? I think the answer is there.
I still love Mugen but damn that s$%t is annoying.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 10-24-2008, 06:28 PM   #2217
NiTrO BoOsTeR's Avatar
well it seems to be touch and go with the gears striping, because i have run the Mtx4 upgraded to an R and i have never striped a gear and i have just completed 2 seasons with a second hand car.
Serpent 733 - RB T10rc - Ko Helios EX-10
Serpent 733 - Novarossi 3SCT Tuned
============== SERPENT the only way ============
==== Pro Buggy Rc, Pitsworth - for all my RC needs =====
NiTrO BoOsTeR is offline   Reply With Quote
Old 10-24-2008, 06:28 PM   #2218
lil-bump's Avatar
Trader Rating: 83 (100%+)
Not sure how much the stock 3mm chassis weighs but the mugen 4mm weighs in at 105 grams. The stock I think was around the mid to high 90's
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 10-24-2008, 06:30 PM   #2219
You are so lucky. All I can say
Primary Weapon: ?
Secondary Weapon: ?
Old 10-24-2008, 06:48 PM   #2220
just a stupid question are u guys using a 1 piece engine mount cause that is what im using, dunno if it makes a difference, also i have a little bit of play in my gears just so they spin freely without bind, and also my clutch bell has rubbed against the 2 speed housing and it doesnt make a difference (just my experience and something i have read in this forum as a possible cause)
also at the track i run at no1 strips gears i have run both .7hp and 1.4hp and it doesnt make any difference and its the same with the other racers
Mitchell
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
