Old 10-05-2008, 06:25 PM   #2161
B-DAWG's Avatar
Hey guys I'm having the stripped gear problem but I think it's my mesh more than anything. Problem is I wanted to stock up on a few and I can't find them anywhere instock. MUGT0252 (59T) and MUGT0255 (53T).
Spektrum DX3R
Revo - RB Mods OS .18 TZ
RC8 - RB Mods OS .21 Vspec
Mugen MTX4R - OS speed .12 TZ
TC5 - Mamba Max 5700Kv
B-DAWG is offline   Reply With Quote
Old 10-05-2008, 06:42 PM   #2162
CraigM's Avatar
Trader Rating: 34 (100%+)
I've ran a 1040 pipe with my spec II and it's been great, I've just got the 1050 now and it seems pretty good too, though I didn't make run time the one heat I've used it. The max 2602 (I think) is supposed to be better for run time but I cant find them anywhere
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-05-2008, 07:17 PM   #2163
B-DAWG's Avatar
Are the MUGTO252 and the MUGT0280 the same? Also the MUGT0255 and the MUGT0283 the same also?
Spektrum DX3R
Old 10-05-2008, 07:31 PM   #2164
Target's Avatar
They have actually released new versions under different part numbers
http://www.mugenseiki.com/t0279_284-e.htm
Target is offline   Reply With Quote
Old 10-05-2008, 08:12 PM   #2165
Team Kamikaze's Avatar
The MUGT0283 and MUGT0280 are the new versions (w/ new material) of the MUGT0255 and MUGT0252.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 10-06-2008, 08:44 AM   #2166
musti72's Avatar
hi guys, i have a problem with my shock absorbers. i fill them, wait for the air bubbles, etc. and slowly tighen the cap. when its full tightened, i compress the shock shaft, and it rebounds all the way down quickly. after 30mins of racing, i compress it and there is a little rebound, like 3mm. i open the shock, and see that in the diaphram(membrane) there is no space, the air has gone. how can i prevent this? should i put foams in it, or somebody told me that he used 2-3 orings for that. what should i do?
thanks in advance
musti72 is offline   Reply With Quote
Old 10-06-2008, 10:28 AM   #2167
Trader Rating: 20 (100%+)
Send a message via AIM to Jamie Fredericks Send a message via MSN to Jamie Fredericks
Where are you guys getting parts for the MTX4? I need to get some new CVD bones and a front sway bar but it seems the only place is nitro house. Any thoughts on more good places?
Jamie Fredericks is offline   Reply With Quote
Old 10-06-2008, 10:31 AM   #2168
nitrobeast's Avatar
Trader Rating: 41 (100%+)
www.ashfordhobby.com
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 10-06-2008, 02:46 PM   #2169
Seisick's Avatar
RB 2604, goes very well also
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 10-06-2008, 03:36 PM   #2170
thanks in advance
I have the same problem.
Mugen MTX4-R
MM Red Dot Evo3
RB R3
Mugen MBX6
RB C6BBT
RB WS7II
sllo is offline   Reply With Quote
Old 10-06-2008, 03:49 PM   #2171
chippy's Avatar
Originally Posted by madjack View Post
I run the spec II, good motor with tons of top end. It seems best for big tracks and can be thirsty with the wrong pipe.
Mugen 2501 pipe works well for med to large tracks with good fuel economy
chippy is offline   Reply With Quote
Old 10-06-2008, 04:39 PM   #2172
lil-bump's Avatar
Trader Rating: 83 (100%+)
thanks in advance
The way I do my shocks is I fill it almost to the top and then I pump the shocks with the top off. Then I place them in my shock pump vacuum to remove any air(not really needed) then I screw the cap on very very slowly making sure the excess fluid has time to leave the shock thru the vent hole. Before the cap is fully closed (slowly) push the shock shaft half way up into the shock body and then continue closing the cap slowly. Once I'm done my shock has very little rebound about 3/16 of an inch. The key is that the shock should not have alot of internal pressure(ie alot of rebound). If done correctly the shock should have the same amount resistance thru-out the entire travel of the shock shaft with very little rebound. After this is done then I mount the (2) shocks in my Losi shock tool which checks the balance of the two shocks to ensure they have the same amount of rebound. It may
take a couple of tries to get it right.
Hope this helps
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 10-07-2008, 05:32 AM   #2173
nitrobeast's Avatar
Default stripped gears
I bought this car used of someone here on rctech. It looked to be in very good condition and almost new like he said. First day out with it, no problem. Second day out with it 3 stripped gears. The first day out with it i think i didnt have a problem because i went over the car before i took it out.
Here is what i did and it worked for me this past weekend.
Replaced the 2nd gears shoes with the new one. Make sure the gap is not too big between the shoes and housing.
Made sure all screws were tight after every race, especially in the rear bulk head.
I ran 2 practice tanks, a little more then 5 minutes each. 3 qualifies at 5 min each and a 10 minute a-main without a single problem. I also broke in a motor, 15 tanks before this past weekend.
I figured i would post this because i know how it feels to be let down.
Rui Goncalves
Old 10-07-2008, 08:48 AM   #2174
G87z's Avatar
Hey Rui,
It was nice to see people coming down to bluediamond. I also just picked up a MTX4-R off of the forums. I will be putting it down for the first time this upcoming weekend. time to retire my MTX-3. haha 5 years of service out of it has been enough. I will also be breaking in a motor this week as I threw a rod in the main and it destroyed the case and everything.
Team Shepherd USA / Picco Engines / Sanwa / Matrix Tires / Byrons Fuel / SRC
G87z is offline   Reply With Quote
Old 10-08-2008, 04:45 AM   #2175
I bought the kawahara K-877 REAR BRACE
where are the two o-rings go?
Mugen MTX4-R
MM Red Dot Evo3
RB R3
Mugen MBX6
RB C6BBT
RB WS7II
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
