Old 09-28-2008, 09:24 AM   #2116
There is a rumor that they are going to release a new car next year...
Yokomo BD7 2016/Lrp 4.5T/Ko Propo
Yokomo BD7 2015/Lrp 10.5T/Ko Propo
Wascheck is offline   Reply With Quote
Old 09-28-2008, 11:30 PM   #2117
CraigM's Avatar
Trader Rating: 34 (100%+)
I don't often write these up so I thought I'd post it for others. I used this setup over the weekend to win a nitro event at my local track, which is quite small and technical with medium grip. I was on hard tyres because we were doing a 30 min final, I normally used 37F/40R. Here's a vid showing the size and layout of the track: http://au.youtube.com/watch?v=jrYk-4zKicg
Front Suspension:
Track width: 199mm
Ride height: 5mm
Camber: -1.5
Upper arm spacer: 2mm
Toe angle: out 1
Rebound stop: 1mm
Bump stop: None
Upper arm position: 1mm
Upright: T0164 with 1mm spacer
Solid spool
A ackerman
Sway bar: halfway between flat and diagonal
Rear suspension:
Track Width: 200mm
Ride height: 6mm
Camber: -3.5
Toe angle: in 2.5
Rebound stop: 4mm
Bump stop: None
Lower arm position: Bottom hole
Upright spacer: 1mm
Roll bar: blade type horizontal
Upper arm position: T0161 in the top hole
Wheel hub spacer: 0mm
Rear diff: 30,000
Front shocks:
Piston: Stock
Oil: 600
Spring: Purple
Position: Middle
Rear shocks:
Piston: Stock
Oil: 600
Spring: Light Blue
Position: Third hole from the bottom
Tyres:
Front: Twister 40sh 59mm
Rear: Twister 42sh 61mm
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 09-29-2008, 03:21 AM   #2118
Arahawak's Avatar
Trader Rating: 32 (100%+)
Nice track! You guys run both gas and electric on this track? coz the video shows an electric race.
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 09-29-2008, 05:21 AM   #2119
stefan's Avatar
Send a message via AIM to stefan
I just got pretty reliable information that Mugen is about to hire a new, very reputable designer for their onroad cars in January.
If this works out, then we should see some interesting new developments there
And no, I can't tell you yet who it is
stefan is offline   Reply With Quote
Old 09-29-2008, 08:08 AM   #2120
BLKNOTCH's Avatar
Send a message via MSN to BLKNOTCH
Front Suspension:
Track width: 199mm
Ride height: 5mm
Camber: -1.5
Toe angle: out 1
Rebound stop: 1mm
Bump stop: None
Solid spool
A ackerman
Rear suspension:
Track Width: 200mm
Ride height: 6mm
Camber: -3.5
Toe angle: in 2.5
Rebound stop: 4mm
Bump stop: None
Upright spacer: 1mm
Rear diff: 30,000
Front shocks:
Piston: Stock
Oil: 600
Spring: Purple
Position: Middle
Rear shocks:
Piston: Stock
Oil: 600
Spring: Light Blue
Tyres:
This set up works great as it is the one I have been using and the car is a point and shoot rocket. What side pulley are you running? 24 or 25?
Sean
HB/HPI Racing | Morgan Fuels | HOBBYWING | Airtronics | REDS Racing | HRP | Hobby Revolution | Team N.E.R.D.
BLKNOTCH is offline   Reply With Quote
Old 09-29-2008, 08:36 AM   #2121
G87z's Avatar
See I have a dilemma on what car I want to purchase at the end of the season. I currently run the MTX-3. I am looking to stay away from the serpent. Xray has not really gotten my attention either. I have narrowed it down to the new Kyosho Evo 2 WC that will be released in OCT. Or the Mugen MTX4-R. I would hate to purchase the MTX4-R and have a new kit released within a 6 month time frame. I have always run mugen so I am partial to them, but the new Kyosho Evo2 WC really has me looking at them.
any ideas?
Thanks,
Team Shepherd USA / Picco Engines / Sanwa / Matrix Tires / Byrons Fuel / SRC
G87z is offline   Reply With Quote
Old 09-29-2008, 09:16 AM   #2122
BLKNOTCH's Avatar
any ideas?
Thanks,
I will say I have run the MTX3 and it was a great car but mid way threw this season I switched up to the MTX4R and let me tell you this car is awsome in so many ways. It is very easy to work with since the uprights are removable unlike the MTX3 and the handling is much MUCH better then the 3. I mad the switch and went from a mid B main racer to a solid A main racer with one of the top times at my track. As far as a new kit being released in the next 6 months I don't see that happening and really there isn't much that they are going to improve on as the car already runs awesome.
Good luck with what you decide.
Sean
Old 09-29-2008, 11:12 AM   #2123
gentleman81's Avatar
why use the T0164 upright, i thought that it was used for high traction?
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 09-29-2008, 08:26 PM   #2124
CraigM's Avatar
Yeah we race both, night racing which is EP only was supposed to use a more technical layout but they tried the nitro layout and loved it. I race both (my cars the white one in the vid) so it suits me. We'll be running a new layout for both starting next pointscore
I haven't tried the other one. The setup is adapted from a Mike Swauger setup where he used the T0164 and shorter arm geometry. I extended the arms and lowered the rear RC and it was fine, I might try the knuckles next
Sean
It's the 24. Glad you like the setup (assume you got it off the mugen forum), results-wise it's certainly been very good for me. TBH I was sceptical about the 600wt shock oil at first, it does suck a little of the responsiveness out of the car but it's super fast and really predictable.
Old 09-29-2008, 08:35 PM   #2125
Suspended
any ideas?
Thanks,
Make sure you buy plenty of second gear spurs. The MTX4 eats them for breakfast, lunch and dinner.
the_geeky is offline   Reply With Quote
Old 09-29-2008, 08:42 PM   #2126
CraigM's Avatar
any ideas?
Thanks,
The Evo 2 drives really nice and the drivetrain is super smooth (thank the updated clutch and 2 speed). I got one to tide me over until the mtx5 comes out and its very impressive on the track, however the quality of the plastics and the fit and finish are nothing on mugen or xray. I've had my mugen over a year and the grub screws in the plastic sway bar holder havent stripped, I used my RRR at 1 meet and one of them is gone. Same with the exhaust holder.
So yeah, the evo2 is probably a little better, but I think from a wear and tear perspective it wont last half as long as mugen. My 2c would be to go xray
Old 09-29-2008, 09:18 PM   #2127
BLKNOTCH's Avatar
I have been using this setup for just over a month now but I am using 500wt in the front and the car is just awesome.
Sean
Old 09-29-2008, 09:43 PM   #2128
Arahawak's Avatar
Question:
How do i make the bodyshell to have higher downforce but yet comply with the rules for 200mm?
I only know the easy way out by having a bigger wing, but that would contravene the rules right?
Old 09-29-2008, 09:45 PM   #2129
Arahawak's Avatar
You? haha just kidding..
its about time.. has the MTX4 been around for that long? 3 years? How time flies!!!
Old 09-29-2008, 09:52 PM   #2130
Arahawak's Avatar
any ideas?
Thanks,
I say if you have the extra, be like CraigM.. he runs both.
Actually.. my thoughts is that if what stefan says is correct, i still say 6months is a long time to enjoy the car. If they design the car in Jan 09, it prob take another few months to get it to production. Going with the trend, IF there is new car, it prob out in late '09. so you can get plenty of fun till then. If I were you, i would still get it if you are partial to Mugen.
However, it be nice to try something new if you haven. I know it may sound cliche, but get whatever you fancy and just enjoy the hobby.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
