Old 07-06-2007, 08:10 PM   #196
wallyedmonds's Avatar
Originally Posted by Artificial-I View Post
I run the 3racing chassis , cheaper , heavier , lower cg. Works like a charm.
oh ya my chassis is the kanak and its kinda like the 3 racing one.
but really any 4mm chassis is good
the mugen one you cant us a 1peace motor mount,but really do you need one and if you run a sirio motor you cant.
and for the striping gears
its mesh you got to mesh tight,and the age of the gears,tho they my look good there not
its just like in the old days with 32 pitch gears in elc offroad,
and also chassis flex
well thats what i think but i could be wrong but iv never striped a gear on a mugen car before.
happy racing
wallyedmonds is offline   Reply With Quote
Old 07-11-2007, 07:44 AM   #197
va_connoisseur's Avatar
Send a message via Yahoo to va_connoisseur
Well I finally got the car together, engine/pipe installed and wires neatly tucked behind the servos. I will take it out to the track this weekend and see how she does. I went with the RB Concepts V12 R3 engine and pipe combo. I was told I should go up one tooth on my 1st and 2nd spur gear.
Will that give me more top end or better low end? Thanks.
va_connoisseur is offline   Reply With Quote
Old 07-11-2007, 09:17 AM   #198
Car Breaker's Avatar
1 tooth up on spur mean better tourque but reduce top speed
Car Breaker is offline   Reply With Quote
Old 07-11-2007, 09:49 AM   #199
That makes sense. As a novice driver, I need something that is more controllable. I have ordered a set of steal pinions as well. For you guys that have the lightened parts from 3Racing or RDlogics, have you seen a performance advantage?
Old 07-11-2007, 01:38 PM   #200
I have titanium pivot ball (Kfactory) , hollow main shaft(Skyline racing) and lightweight gear housing. I think that serve me well. I am a parking lot driver which mean traction isn't too good, I have more then enough punch at the low end (too much when my tyre wear out)
Old 07-11-2007, 02:17 PM   #201
JetMD's Avatar
One of my most recent hop-ups that I really like is the rdlogics vented/slotted brake rotor and mugen teflon pads. This, along with the solid front diff. are a great combination at 301. The stock brakes on the 4 fade really fast and when you need them most, they won't be there. Personally, I think lightened parts are just bling and you should spend your money on the 4mm chassis, and front CVD's. Just my opinion.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 07-11-2007, 02:22 PM   #202
I have the 4R so it came with CVDs but the 4mm chassis was something I have heard is a good investment. I'm running a solid on the front. I'm just anxious to get out there with you guys and start running.
Old 07-11-2007, 02:56 PM   #203
Roger's Avatar
Hey guys. Thanks for your responses about the 4mm chassis. I think i'l be running the stock 3mm chassis just to try out a few things. Here's a pix of my car I just finished. Thanks Mike, Robbie, and Harry
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 07-11-2007, 06:05 PM   #204
what i use is
rear upper arm mount # t0161
4mm rear damper stay 4mm #t0508
mugen blade rear sway bar
alm t0150B and t0150C
k factory rear light shaft
ti front shaft
kanack 4mm chassis
1.2x1 front shock pistons
1.1x2 rear shock pistons
mugen break disk H0369
front lower arm #T0151-B
front upright #T0164 2
and T0138 sometimes
and i mostly always use light blue shock springs.
Old 07-11-2007, 07:46 PM   #205
JetMD's Avatar
For the money, the R is the best bet. You picked the right one. I would try the stock chassis first to see if you strip gears. If not, you're fine. If you do, get the 4mm. I have the 3 racing 4mm from rcmushroom which is half the price of the mugen and works great for me.
U like my avitar pic? It's sweet! Thanks!
www.vorra.org
MINO Racing
Old 07-11-2007, 08:49 PM   #206
get the 4mm chassis
and if you insist on running a spool your cvd's will where more and your belts too.
not to many guy's up here run spools anymore and low and behold the lap times are getting faster.
and ya a 1way has faster corner speed but you can traction roll
what im trying to say is try different things and see what happens
but a 4mm chassis is the best thing to run. as for striped gears check this out.
http://www.nitrokb.com/mtx4/
Old 07-11-2007, 11:48 PM   #207
FF25510's Avatar
Hi Roger,
very good looking car what's that thing on the pipe, is it workable?
tks
FF25510 is offline   Reply With Quote
Old 07-12-2007, 01:50 AM   #208
Roger's Avatar
Originally Posted by FF25510 View Post
Hi Roger,
tks
Its just some self sealing silicon tape wrap.
Old 07-12-2007, 06:51 AM   #209
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
hey guys after some Mugen shocks for my G4S, would luv to know where i can buy a set from? any links would help!
cheers
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 07-12-2007, 11:21 AM   #210
rmdhawaii's Avatar
cheers
try http://www.nitrohouse.com
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
